I have a few charts that have data bound to a Named Query. When the chart updates, sometimes the chart won’t properly show the line and it looks like it’s doing a zig-zag pattern (like it’s appending the bound data rather than replacing it.
Below is a picture of what I mean. That green data line is supposed to be a single line between two points. I don’t know if this is a bug or I’m missing something.
Would it be possible to post the query here, so we can see if spot anything obvious?
Yes I can do that, but I also remembered that the data binding for the XY Chart is not a simple named query.
In my View, I have a custom parameter that grabs the data using a named query (picture below)
Then, I can use that parameter multiple places (so I don’t have to keep running/polling the same Named Query from multiple sources). The XY Chart is one of those places. I’m using a Property binding that binds to that previous Custom Parameter than using a transform script to organize the data for the binding (see below).
day_data_dict = {}
day_data = []
day_counter = 0
for row in value:
row_date_parse = system.date.parse(row["time"])
row_date = [
system.date.getMonth(row_date_parse) + 1,
system.date.getDayOfMonth(row_date_parse),
system.date.getYear(row_date_parse)
downtime = row["downtime_minutes"]
palletizer = row["palletizer_number"]
date_string = "{0}/{1}/{2}".format(row_date[0], row_date[1], row_date[2])
# First entry
if len(day_data) == 0:
day_data_dict = {
"date": date_string,
"count1": 1 if palletizer == 1 else 0,
"downtime1": downtime if palletizer == 1 else 0,
"count2": 1 if palletizer == 2 else 0,
"downtime2": downtime if palletizer == 2 else 0
day_data.append(day_data_dict)
else:
row_idx = 0
date_exists = False
# Loop through the existing data (that has at least one row in it)
for date_row in day_data:
if date_string == date_row["date"]:
date_exists = True
break
row_idx += 1
# If the date matches the date in the row, increment the frequency counter
if date_exists:
counter1 = day_data[row_idx]["count1"]
counter2 = day_data[row_idx]["count2"]
current_downtime1 = day_data[row_idx]["downtime1"]
current_downtime2 = day_data[row_idx]["downtime2"]
day_data_dict = {
"count1": counter1 + 1 if palletizer == 1 else counter1,
"downtime1": current_downtime1 + downtime if palletizer == 1 else current_downtime1,
"count2": counter2 + 1 if palletizer == 2 else counter2,
"downtime2": current_downtime2 + downtime if palletizer == 2 else current_downtime2,
day_data[row_idx] = day_data_dict
row_idx += 1
# If the date does not match, create a new date entry
else:
day_data_dict = {
"downtime2": downtime if palletizer == 2 else 0,
"palletizer": palletizer
row_idx = 0
sorted_list = sorted(day_data, key=lambda x:x["date"])
return sorted_list
i am still experiencing the same issue, any luck on the solution?
