XY Chart - Overwriting 24 hour "date" format
Hi
I am currently facing a format issue on the Y-axis and the related bullets where I would like to display the average duration of tasks in an XY chart. Everything works perfectly, at least with the bullets, as long as I stay within the 24-hour format. However, if a task takes, for example, 29:11 (hh:mm), the graph (bullets) only shows "05:11". Ignition Perspective cuts off after 24 hours, which makes the display incorrect.
I also tried setting the value of "render:" to "value". However, the format "##:##" is not applied then.
Instead of "50:00", it shows "5000:5000" on the Y-Axes.
I have tried various formatting tricks and passed the average time with an SQL-Script both as INT, VARCHAR, and as "55:00" (see pic below) and "5500". All without success...
To sum up: How can I display a "##:##" format, as in "hh:mm", on the bullets and on the Y-axis?
Has anyone ever had the same problem?
Thank you in advance!
The XY Chart component is based on AM Charts. You can find their documentation in Formatting dates and Formatting date and time. I don't think there's anything in there to help you. You might have to convert to decimal hours and just display as a number.
One last chance: Have a look at Formatting strings. I offered this a solution to forcing numbers to be used as category strings in my answer to Populate Pie Chart from table data - #3 by Alejandro_Alaco.
I noticed that the chart behaves strangely when both axes are set to dates.
Try setting the X-axis as a category and the Y-axis as date. Keep format as D'D': HH'H': mm'M' . Only trick is "D"
Sample for quick reference
XY Chart
    "type": "ia.chart.xy",
    "version": 0,
    "props": {
      "xAxes": [
          "name": "monthX",
          "label": {
            "enabled": true,
            "text": "Month",
            "color": ""
          "visible": true,
          "tooltip": {
            "enabled": true,
            "text": "",
            "cornerRadius": 3,
            "pointerLength": 4,
            "background": {
              "color": "",
              "opacity": 1
          "inversed": false,
          "render": "category",
          "category": {
            "break": {
              "enabled": false,
              "startCategory": "",
              "endCategory": "",
              "size": 0.05
          "date": {
            "baseInterval": {
              "enabled": false,
              "timeUnit": "hour",
              "count": 1,
              "skipEmptyPeriods": false
            "range": {
              "max": "",
              "min": "",
              "useStrict": false
            "break": {
              "enabled": false,
              "startDate": "",
              "endDate": "",
              "size": 0.05
            "inputFormat": "yyyy/MM/dd",
            "format": "yyyy/MM/dd"
          "value": {
            "range": {
              "max": "",
              "min": "",
              "useStrict": false
            "logarithmic": false,
            "break": {
              "enabled": false,
              "startValue": 0,
              "endValue": 100,
              "size": 0.05
            "format": "#,###.##"
          "appearance": {
            "opposite": false,
            "inside": false,
            "labels": {
              "color": "",
              "opacity": 1,
              "rotation": 0,
              "verticalCenter": "middle",
              "horizontalCenter": "middle"
            "grid": {
              "color": "",
              "opacity": 1,
              "dashArray": "",
              "minDistance": 60,
              "position": 0.5
            "font": {
              "size": "",
              "weight": 500
      "yAxes": [
          "name": "durationY",
          "label": {
            "enabled": true,
            "text": "Duration",
            "color": ""
          "visible": true,
          "tooltip": {
            "enabled": true,
            "text": "",
            "cornerRadius": 3,
            "pointerLength": 4,
            "background": {
              "color": "",
              "opacity": 1
          "inversed": false,
          "render": "date",
          "category": {
            "break": {
              "enabled": false,
              "endCategory": "",
              "size": 0.05
          "date": {
            "baseInterval": {
              "enabled": true,
              "timeUnit": "hour",
              "count": 1,
            "range": {
              "max": "",
              "min": "",
              "useStrict": false
            "break": {
              "enabled": false,
              "startDate": "",
              "endDate": "",
              "size": 0.05
            "inputFormat": "HH:mm",
            "format": "D'D': HH'H': mm'M'"
          "value": {
            "range": {
              "max": "",
              "min": "",
              "useStrict": false
            "break": {
              "enabled": false,
              "startValue": 0,
              "endValue": 100,
              "size": 0.05
          "appearance": {
            "opposite": false,
            "inside": false,
            "labels": {
              "color": "",
              "opacity": 1,
              "rotation": 0,
            "grid": {
              "color": "",
              "opacity": 1,
              "dashArray": "",
              "minDistance": null,
              "position": 0.5
            "font": {
              "size": "",
              "weight": 500
      "series": [
          "name": "Sample",
          "label": {
            "text": "Sample"
          "visible": true,
          "hiddenInLegend": false,
          "defaultState": {
            "visible": true
          "data": {
            "source": "example",
            "x": "month",
            "y": "avgTime"
          "xAxis": "monthX",
          "yAxis": "durationY",
          "zIndex": 0,
          "tooltip": {
            "enabled": true,
            "text": "{name}: [bold]{valueY}[/]",
            "cornerRadius": 3,
            "pointerLength": 4,
            "background": {
              "color": "",
              "opacity": 1
          "render": "line",
          "candlestick": {
            "open": {
              "x": "",
              "y": ""
            "high": {
              "x": "",
              "y": ""
            "low": {
              "x": "",
              "y": ""
            "appearance": {
              "fill": {
                "color": "",
                "opacity": 1
              "stroke": {
                "color": "",
                "opacity": 1,
                "width": 1
              "stacked": false,
              "deriveFieldsFromData": {
                "fill": {
                  "color": "",
                  "opacity": ""
                "stroke": {
                  "color": "",
                  "opacity": "",
                  "width": ""
              "heatRules": {
                "enabled": false,
                "max": "",
                "min": "",
                "dataField": ""
          "column": {
            "open": {
              "x": "",
              "y": ""
            "appearance": {
              "fill": {
                "color": "",
                "opacity": 1
              "stroke": {
                "color": "",
                "opacity": 1,
                "width": 1
              "stacked": false,
              "width": null,
              "height": null,
                "fill": {
                  "color": "",
                  "opacity": ""
                "stroke": {
                  "color": "",
                  "opacity": "",
                  "width": ""
              "heatRules": {
                "enabled": false,
                "max": "",
                "min": "",
                "dataField": ""
          "line": {
            "open": {
              "x": "",
              "y": ""
            "appearance": {
              "connect": true,
              "tensionX": 1,
              "tensionY": 1,
              "minDistance": 0.5,
              "stroke": {
                "width": 3,
                "opacity": 1,
                "color": "",
                "dashArray": ""
              "fill": {
                "opacity": 0,
                "color": ""
              "bullets": [
                  "enabled": true,
                  "render": "label",
                  "width": 10,
                  "height": 10,
                  "label": {
                    "text": "{avgTime}",
                    "position": {
                      "dx": 0,
                      "dy": 0
                  "fill": {
                    "color": "",
                    "opacity": 1
                  "stroke": {
                    "color": "",
                    "opacity": 1,
                    "width": 1
                  "rotation": 0,
                  "tooltip": {
                    "enabled": true,
                    "cornerRadius": 3,
                    "pointerLength": 4,
                    "background": {
                      "color": "",
                      "opacity": 1
                    "fill": {
                      "color": "",
                      "opacity": ""
                    "stroke": {
                      "color": "",
                      "opacity": "",
                      "width": ""
                    "rotation": ""
                  "heatRules": {
                    "enabled": false,
                    "max": 100,
                    "min": 2,
                    "dataField": ""
          "stepLine": {
            "open": {
              "x": "",
              "y": ""
            "appearance": {
              "connect": true,
              "tensionX": 1,
              "tensionY": 1,
              "minDistance": 0.5,
              "stroke": {
                "width": 3,
                "opacity": 1,
                "color": "",
                "dashArray": ""
              "fill": {
                "opacity": 0,
                "color": ""
              "bullets": [
                  "enabled": true,
                  "render": "circle",
                  "width": 10,
                  "height": 10,
                  "label": {
                    "text": "{value}",
                    "position": {
                      "dx": 0,
                      "dy": 0
                  "fill": {
                    "color": "",
                    "opacity": 1
                  "stroke": {
                    "color": "",
                    "opacity": 1,
                    "width": 1
                  "rotation": 0,
                  "tooltip": {
                    "enabled": true,
                    "cornerRadius": 3,
                    "pointerLength": 4,
                    "background": {
                      "color": "",
                      "opacity": 1
                    "fill": {
                      "color": "",
                      "opacity": ""
                    "stroke": {
                      "color": "",
                      "opacity": "",
                      "width": ""
                    "rotation": ""
                  "heatRules": {
                    "enabled": false,
                    "max": 100,
                    "min": 2,
                    "dataField": ""
      "dataSources": {
        "example": [
            "avgTime": "05:24",
            "month": "2023-09"
            "avgTime": "19:38",
            "month": "2023-10"
            "avgTime": "33:37",
            "month": "2023-11"
            "avgTime": "54:50",
            "month": "2023-12"
    "meta": {
      "name": "XYChart"
    "position": {
      "x": 131,
      "y": 29.5,
      "height": 741,
      "width": 652
    "custom": {}
I like the approach of counting the days insted of solely using the "HH:mm" Format - Great Job Ujwal!
But how did you manage to display Bullets in the "HH:mm" Format?
Mine is just not being "digested" properly although the SQL Script is returning
And Bullet Format under Series is simply set to "{name}: [bold]{valueY}":
    "name": "Liegezeit",
    "label": {
      "text": "Ø Liegezeit je Monat"
    "visible": true,
    "defaultState": {
      "visible": true
    "data": {
      "source": "Daten_DLZ_Liegezeit",
      "x": "Monat",
      "y": "Durchschnittliche_Zeit"
    "xAxis": "Monat",
    "yAxis": "Durchschnittliche_Zeit",
    "zIndex": 0,
    "tooltip": {
      "enabled": true,
      "text": "",
      "cornerRadius": 3,
      "pointerLength": 4,
      "background": {
        "color": "",
        "opacity": 1
    "render": "line",
    "candlestick": {
      "open": {
        "x": "",
        "y": ""
      "high": {
        "x": "",
        "y": ""
      "low": {
        "x": "",
        "y": ""
      "appearance": {
        "fill": {
          "color": "",
          "opacity": 1
        "stroke": {
          "color": "",
          "opacity": 1,
          "width": 1
        "stacked": false,
          "fill": {
            "color": "",
            "opacity": ""
          "stroke": {
            "color": "",
            "opacity": "",
            "width": ""
        "heatRules": {
          "enabled": false,
          "max": "",
          "min": "",
          "dataField": ""
    "column": {
      "open": {
        "x": "",
        "y": ""
      "appearance": {
        "fill": {
          "color": "#811c1f",
          "opacity": 1
        "stroke": {
          "color": "",
          "opacity": 0,
          "width": 0
        "width": null,
        "height": null,
        "stacked": true,
          "fill": {
            "color": "",
            "opacity": ""
          "stroke": {
            "color": "",
            "opacity": "",
            "width": ""
        "heatRules": {
          "enabled": false,
          "max": "",
          "min": "",
          "dataField": ""
    "line": {
      "open": {
        "x": "",
        "y": ""
      "appearance": {
        "connect": true,
        "tensionX": 1,
        "tensionY": 1,
        "minDistance": "0.5",
        "stroke": {
          "width": 3,
          "opacity": 1,
          "color": "#FFCC00",
          "dashArray": ""
        "fill": {
          "color": "",
          "opacity": 0
        "bullets": [
            "enabled": true,
            "render": "circle",
            "width": 10,
            "height": 10,
            "label": {
              "text": "{value}",
              "position": {
                "dx": 0,
                "dy": 0
            "tooltip": {
              "enabled": true,
              "text": "{name}: [bold]{valueY}",
              "cornerRadius": 3,
              "pointerLength": 4,
              "background": {
                "color": "",
                "opacity": 1
            "fill": {
              "color": "#FFCC00",
              "opacity": 1
            "stroke": {
              "color": "",
              "width": 1,
              "opacity": 1
            "rotation": 0,
              "fill": {
                "color": "",
                "opacity": ""
              "stroke": {
                "color": "",
                "opacity": "",
                "width": ""
              "rotation": ""
            "heatRules": {
              "enabled": false,
              "max": 100,
              "min": 2,
              "dataField": ""
    "stepLine": {
      "open": {
        "x": "",
        "y": ""
      "appearance": {
        "connect": true,
        "tensionX": 1,
        "tensionY": 1,
        "minDistance": 0.5,
        "stroke": {
          "width": 3,
          "opacity": 1,
          "color": "",
          "dashArray": ""
        "fill": {
          "color": "",
          "opacity": 0
        "bullets": [
            "enabled": true,
            "render": "circle",
            "width": 10,
            "height": 10,
            "label": {
              "text": "{value}",
              "position": {
                "dx": 0,
                "dy": 0
            "tooltip": {
              "enabled": true,
              "cornerRadius": 3,
              "pointerLength": 4,
              "background": {
                "color": "",
                "opacity": 1
            "fill": {
              "color": "",
              "opacity": 1
            "stroke": {
              "color": "",
              "width": 1,
              "opacity": 1
            "rotation": 0,
              "fill": {
                "color": "",
                "opacity": ""
              "stroke": {
                "color": "",
                "opacity": "",
                "width": ""
              "rotation": ""
            "heatRules": {
              "enabled": false,
              "max": 100,
              "min": 2,
              "dataField": ""
    "name": "Messzeit",
    "label": {
      "text": "Ø Messzeit je Monat"
    "visible": true,
    "defaultState": {
      "visible": true
    "data": {
      "source": "Daten_DLZ_Messzeit",
      "x": "Monat",
    "xAxis": "Monat",
    "zIndex": 0,
    "tooltip": {
      "enabled": true,
      "text": "{name}:[bold]{valueY.formatNumber(\"#\")} HH:mm",
      "cornerRadius": 3,
      "pointerLength": 4,
      "background": {
        "color": "",
        "opacity": 1
    "render": "line",
    "candlestick": {
      "open": {
        "x": "",
        "y": ""
      "high": {
        "x": "",
        "y": ""
      "low": {
        "x": "",
        "y": ""
      "appearance": {
        "fill": {
          "color": "",
          "opacity": 1
        "stroke": {
          "color": "",
          "opacity": 1,
          "width": 1
        "stacked": false,
          "fill": {
            "color": "",
            "opacity": ""
          "stroke": {
            "color": "",
            "opacity": "",
            "width": ""
        "heatRules": {
          "enabled": false,
          "max": "",
          "min": "",
          "dataField": ""
    "column": {
      "open": {
        "x": "",
        "y": ""
      "appearance": {
        "fill": {
          "color": "#811c1f",
          "opacity": 1
        "stroke": {
          "color": "",
          "opacity": 0,
          "width": 0
        "width": null,
        "height": null,
        "stacked": true,
          "fill": {
            "color": "",
            "opacity": ""
          "stroke": {
            "color": "",
            "opacity": "",
            "width": ""
        "heatRules": {
          "enabled": false,
          "max": "",
          "min": "",
          "dataField": ""
    "line": {
      "open": {
        "x": "",
        "y": ""
      "appearance": {
        "connect": true,
        "tensionX": 1,
        "tensionY": 1,
        "stroke": {
          "width": 3,
          "opacity": 1,
          "color": "#0D3D75",
          "dashArray": ""
        "fill": {
          "color": "",
          "opacity": 0
        "bullets": [
            "enabled": true,
            "render": "circle",
            "width": 10,
            "height": 10,
            "label": {
              "text": "{value}",
              "position": {
                "dx": 0,
                "dy": 0
            "tooltip": {
              "enabled": true,
              "cornerRadius": 3,
              "pointerLength": 4,
              "background": {
                "color": "",
                "opacity": 1
            "fill": {
              "color": "#0D3D75",
              "opacity": 1
            "stroke": {
              "color": "",
              "width": 1,
              "opacity": 1
            "rotation": 0,
              "fill": {
                "color": "",
                "opacity": ""
              "stroke": {
                "color": "",
                "opacity": "",
                "width": ""
              "rotation": ""
            "heatRules": {
              "enabled": false,
              "max": 100,
              "min": 2,
              "dataField": ""
    "stepLine": {
      "open": {
        "x": "",
        "y": ""
      "appearance": {
        "connect": true,
        "tensionX": 1,
        "tensionY": 1,
        "minDistance": 0.5,
        "stroke": {
          "width": 3,
          "opacity": 1,
          "color": "",
          "dashArray": ""
        "fill": {
          "color": "",
          "opacity": 0
        "bullets": [
            "enabled": true,
            "render": "circle",
            "width": 10,
            "height": 10,
            "label": {
              "text": "{value}",
              "position": {
                "dx": 0,
                "dy": 0
            "tooltip": {
              "enabled": true,
              "cornerRadius": 3,
              "pointerLength": 4,
              "background": {
                "color": "",
                "opacity": 1
            "fill": {
              "color": "",
              "opacity": 1
            "stroke": {
              "color": "",
              "width": 1,
              "opacity": 1
            "rotation": 0,
              "fill": {
                "color": "",
                "opacity": ""
              "stroke": {
                "color": "",
                "opacity": "",
                "width": ""
              "rotation": ""
            "heatRules": {
              "enabled": false,
              "max": 100,
              "min": 2,
              "dataField": ""
    "name": "Gesamtzeit",
    "label": {
      "text": "Ø Gesamtzeit je Monat"
    "visible": true,
    "defaultState": {
      "visible": true
    "data": {
      "source": "Daten_DLZ_Gesamtzeit",
      "x": "Monat",
    "xAxis": "Monat",
    "zIndex": 0,
    "tooltip": {
      "enabled": true,
      "cornerRadius": 3,
      "pointerLength": 4,
      "background": {
        "color": "",
        "opacity": 1
    "render": "line",
    "candlestick": {
      "open": {
        "x": "",
        "y": ""
      "high": {
        "x": "",
        "y": ""
      "low": {
        "x": "",
        "y": ""
      "appearance": {
        "fill": {
          "color": "",
          "opacity": 1
        "stroke": {
          "color": "",
          "opacity": 1,
          "width": 1
        "stacked": false,
          "fill": {
            "color": "",
            "opacity": ""
          "stroke": {
            "color": "",
            "opacity": "",
            "width": ""
        "heatRules": {
          "enabled": false,
          "max": "",
          "min": "",
          "dataField": ""
    "column": {
      "open": {
        "x": "",
        "y": ""
      "appearance": {
        "fill": {
          "color": "#811c1f",
          "opacity": 1
        "stroke": {
          "color": "",
          "opacity": 0,
          "width": 0
        "width": null,
        "height": null,
        "stacked": true,
          "fill": {
            "color": "",
            "opacity": ""
          "stroke": {
            "color": "",
            "opacity": "",
            "width": ""
        "heatRules": {
          "enabled": false,
          "max": "",
          "min": "",
          "dataField": ""
    "line": {
      "open": {
        "x": "",
        "y": ""
      "appearance": {
        "connect": true,
        "tensionX": 1,
        "tensionY": 1,
        "stroke": {
          "width": 3,
          "opacity": 1,
          "color": "#C53625",
          "dashArray": ""
        "fill": {
          "color": "",
          "opacity": 0
        "bullets": [
            "enabled": true,
            "render": "circle",
            "width": 10,
            "height": 10,
            "label": {
              "text": "{value}",
              "position": {
                "dx": 0,
                "dy": 0
            "tooltip": {
              "enabled": true,
              "cornerRadius": 3,
              "pointerLength": 4,
              "background": {
                "color": "",
                "opacity": 1
            "fill": {
              "color": "#C53625",
              "opacity": 1
            "stroke": {
              "color": "",
              "width": 1,
              "opacity": 1
            "rotation": 0,
              "fill": {
                "color": "",
                "opacity": ""
              "stroke": {
                "color": "",
                "opacity": "",
                "width": ""
              "rotation": ""
            "heatRules": {
              "enabled": false,
              "max": 100,
              "min": 2,
              "dataField": ""
    "stepLine": {
      "open": {
        "x": "",
        "y": ""
      "appearance": {
        "connect": true,
        "tensionX": 1,
        "tensionY": 1,
        "minDistance": 0.5,
        "stroke": {
          "width": 3,
          "opacity": 1,
          "color": "",
          "dashArray": ""
        "fill": {
          "color": "",
          "opacity": 0
        "bullets": [
            "enabled": true,
            "render": "circle",
            "width": 10,
            "height": 10,
            "label": {
              "text": "{value}",
              "position": {
                "dx": 0,
                "dy": 0
            "tooltip": {
              "enabled": true,
              "cornerRadius": 3,
              "pointerLength": 4,
              "background": {
                "color": "",
                "opacity": 1
            "fill": {
              "color": "",
              "opacity": 1
            "stroke": {
              "color": "",
              "width": 1,
              "opacity": 1
            "rotation": 0,
              "fill": {
                "color": "",
                "opacity": ""
              "stroke": {
                "color": "",
                "opacity": "",
                "width": ""
              "rotation": ""
            "heatRules": {
              "enabled": false,
              "max": 100,
              "min": 2,
              "dataField": ""
Unable to recreate chart using your code. Can upload the correct json?
Hi Ujwal,
sorry fot the late response...
here's the complete specification:
    "version": 0,
    "props": {
      "title": {
        "text": "Ø DLZ je Auftragsart",
        "appearance": {
          "font": {
            "size": 20,
            "weight": 1000
          "padding": {
            "bottom": 5
      "legend": {
        "position": "left",
        "markers": {
          "width": 15,
          "height": 15
        "labels": {
          "text": "[bold]{name}",
          "font": {
            "weight": 200,
            "size": 12
      "cursor": {
        "enabled": false
      "enableTransitions": true,
      "xAxes": [
          "name": "Monat",
          "label": {
            "enabled": true,
            "text": "Jahr-Monat",
            "color": ""
          "visible": true,
          "tooltip": {
            "enabled": true,
            "text": "",
            "cornerRadius": 3,
            "pointerLength": 4,
            "background": {
              "color": "",
              "opacity": 1
          "inversed": false,
          "category": {
            "break": {
              "enabled": false,
              "endCategory": "",
              "size": 0.05
          "date": {
            "baseInterval": {
              "enabled": true,
              "timeUnit": "hour",
              "count": 1,
            "range": {
              "max": "",
              "min": "",
              "useStrict": false
            "break": {
              "enabled": false,
              "startDate": "",
              "endDate": "",
              "size": 0.05
            "inputFormat": "yyyy-mm-dd kk:mm:ss",
            "format": "yyyy-mm"
          "value": {
            "range": {
              "max": "",
              "min": "",
              "useStrict": false
            "break": {
              "enabled": false,
              "startValue": 0,
              "endValue": 100,
              "size": 0.05
          "appearance": {
            "opposite": false,
            "inside": false,
            "labels": {
              "color": "",
              "opacity": 1,
              "rotation": 45,
            "grid": {
              "color": "",
              "opacity": "0.5",
              "dashArray": "10px",
              "minDistance": 60,
              "position": 0.5
            "font": {
              "size": "",
              "weight": 500
      "yAxes": [
          "name": "Durchschnittliche_Zeit",
          "label": {
            "enabled": true,
            "text": "Ø Zeit in (dd:hh:mm)",
            "color": ""
          "visible": true,
          "tooltip": {
            "enabled": true,
            "text": "",
            "cornerRadius": 3,
            "pointerLength": 4,
            "background": {
              "color": "",
              "opacity": 1
          "inversed": false,
          "render": "date",
          "category": {
            "break": {
              "enabled": false,
              "startCategory": 0,
              "endCategory": "",
              "size": 0.05
          "date": {
            "baseInterval": {
              "enabled": true,
              "timeUnit": "hour",
              "count": 1,
            "range": {
              "max": "",
              "min": "",
              "useStrict": true
            "break": {
              "enabled": false,
              "startDate": "",
              "endDate": "",
              "size": 0.05
          "value": {
            "range": {
              "max": "",
              "min": 0,
              "useStrict": false
            "break": {
              "enabled": false,
              "startValue": "",
              "endValue": "",
              "size": 0.05
            "format": "##:00",
            "formattedValue": ""
          "appearance": {
            "opposite": true,
            "inside": false,
            "labels": {
              "color": "",
              "opacity": 1,
              "rotation": 0,
            "grid": {
              "color": "",
              "opacity": 0.5,
              "dashArray": 4.4,
              "position": 0.5
            "font": {
              "size": "",
              "weight": 500
      "series": [
          "label": {
          "visible": true,
          "defaultState": {
            "visible": true
          "data": {
            "x": "Monat",
          "xAxis": "Monat",
          "zIndex": 0,
          "tooltip": {
            "enabled": true,
            "text": "",
            "cornerRadius": 3,
            "pointerLength": 4,
            "background": {
              "color": "",
              "opacity": 1
          "render": "line",
          "candlestick": {
            "open": {
              "x": "",
              "y": ""
            "high": {
              "x": "",
              "y": ""
            "low": {
              "x": "",
              "y": ""
            "appearance": {
              "fill": {
                "color": "",
                "opacity": 1
              "stroke": {
                "color": "",
                "opacity": 1,
                "width": 1
              "stacked": false,
                "fill": {
                  "color": "",
                  "opacity": ""
                "stroke": {
                  "color": "",
                  "opacity": "",
                  "width": ""
              "heatRules": {
                "enabled": false,
                "max": "",
                "min": "",
                "dataField": ""
          "column": {
            "open": {
              "x": "",
              "y": ""
            "appearance": {
              "fill": {
                "color": "#811c1f",
                "opacity": 1
              "stroke": {
                "color": "",
                "opacity": 0,
                "width": 0
              "stacked": true,
              "width": null,
              "height": null,
                "fill": {
                  "color": "",
                  "opacity": ""
                "stroke": {
                  "color": "",
                  "opacity": "",
                  "width": ""
              "heatRules": {
                "enabled": false,
                "max": "",
                "min": "",
                "dataField": ""
          "line": {
            "open": {
              "x": "",
              "y": ""
            "appearance": {
              "connect": true,
              "tensionX": 1,
              "tensionY": 1,
              "stroke": {
                "width": 3,
                "opacity": 1,
                "color": "#FFCC00",
                "dashArray": ""
              "fill": {
                "opacity": 0,
                "color": ""
              "bullets": [
                  "enabled": true,
                  "render": "circle",
                  "width": 10,
                  "height": 10,
                  "label": {
                    "text": "{value}",
                    "position": {
                      "dx": 0,
                      "dy": 0
                  "fill": {
                    "color": "#FFCC00",
                    "opacity": 1
                  "stroke": {
                    "color": "",
                    "opacity": 1,
                    "width": 1
                  "rotation": 0,
                  "tooltip": {
                    "enabled": true,
                    "cornerRadius": 3,
                    "pointerLength": 4,
                    "background": {
                      "color": "",
                      "opacity": 1
                    "fill": {
                      "color": "",
                      "opacity": ""
                    "stroke": {
                      "color": "",
                      "opacity": "",
                      "width": ""
                    "rotation": ""
                  "heatRules": {
                    "enabled": false,
                    "max": 100,
                    "min": 2,
                    "dataField": ""
          "stepLine": {
            "open": {
              "x": "",
              "y": ""
            "appearance": {
              "connect": true,
              "tensionX": 1,
              "tensionY": 1,
              "minDistance": 0.5,
              "stroke": {
                "width": 3,
                "opacity": 1,
                "color": "",
                "dashArray": ""
              "fill": {
                "opacity": 0,
                "color": ""
              "bullets": [
                  "enabled": true,
                  "render": "circle",
                  "width": 10,
                  "height": 10,
                  "label": {
                    "text": "{value}",
                    "position": {
                      "dx": 0,
                      "dy": 0
                  "fill": {
                    "color": "",
                    "opacity": 1
                  "stroke": {
                    "color": "",
                    "opacity": 1,
                    "width": 1
                  "rotation": 0,
                  "tooltip": {
                    "enabled": true,
                    "cornerRadius": 3,
                    "pointerLength": 4,
                    "background": {
                      "color": "",
                      "opacity": 1
                    "fill": {
                      "color": "",
                      "opacity": ""
                    "stroke": {
                      "color": "",
                      "opacity": "",
                      "width": ""
                    "rotation": ""
                  "heatRules": {
                    "enabled": false,
                    "max": 100,
                    "min": 2,
                    "dataField": ""
          "candlestick": {
            "appearance": {
                "fill": {
                  "color": "",
                  "opacity": ""
                "stroke": {
                  "color": "",
                  "opacity": "",
                  "width": ""
              "fill": {
                "color": "",
                "opacity": 1
              "heatRules": {
                "dataField": "",
                "enabled": false,
                "max": "",
                "min": ""
              "stacked": false,
              "stroke": {
                "color": "",
                "opacity": 1,
                "width": 1
            "high": {
              "x": "",
              "y": ""
            "low": {
              "x": "",
              "y": ""
            "open": {
              "x": "",
              "y": ""
          "column": {
            "appearance": {
                "fill": {
                  "color": "",
                  "opacity": ""
                "stroke": {
                  "color": "",
                  "opacity": "",
                  "width": ""
              "fill": {
                "color": "#811c1f",
                "opacity": 1
              "heatRules": {
                "dataField": "",
                "enabled": false,
                "max": "",
                "min": ""
              "height": null,
              "stacked": true,
              "stroke": {
                "color": "",
                "opacity": 0,
                "width": 0
              "width": null
            "open": {
              "x": "",
              "y": ""
          "data": {
            "x": "Monat",
          "defaultState": {
            "visible": true
          "label": {
          "line": {
            "appearance": {
              "bullets": [
                    "fill": {
                      "color": "",
                      "opacity": ""
                    "rotation": "",
                    "stroke": {
                      "color": "",
                      "opacity": "",
                      "width": ""
                  "enabled": true,
                  "fill": {
                    "color": "#0D3D75",
                    "opacity": 1
                  "heatRules": {
                    "dataField": "",
                    "enabled": false,
                    "max": 100,
                    "min": 2
                  "height": 10,
                  "label": {
                    "position": {
                      "dx": 0,
                      "dy": 0
                    "text": "{value}"
                  "render": "circle",
                  "rotation": 0,
                  "stroke": {
                    "color": "",
                    "opacity": 1,
                    "width": 1
                  "tooltip": {
                    "background": {
                      "color": "",
                      "opacity": 1
                    "cornerRadius": 3,
                    "enabled": true,
                    "pointerLength": 4,
                  "width": 10
              "connect": true,
              "fill": {
                "color": "",
                "opacity": 0
              "stroke": {
                "color": "#0D3D75",
                "dashArray": "",
                "opacity": 1,
                "width": 3
              "tensionX": 1,
              "tensionY": 1
            "open": {
              "x": "",
              "y": ""
          "name": "Messzeit",
          "render": "line",
          "stepLine": {
            "appearance": {
              "bullets": [
                    "fill": {
                      "color": "",
                      "opacity": ""
                    "rotation": "",
                    "stroke": {
                      "color": "",
                      "opacity": "",
                      "width": ""
                  "enabled": true,
                  "fill": {
                    "color": "",
                    "opacity": 1
                  "heatRules": {
                    "dataField": "",
                    "enabled": false,
                    "max": 100,
                    "min": 2
                  "height": 10,
                  "label": {
                    "position": {
                      "dx": 0,
                      "dy": 0
                    "text": "{value}"
                  "render": "circle",
                  "rotation": 0,
                  "stroke": {
                    "color": "",
                    "opacity": 1,
                    "width": 1
                  "tooltip": {
                    "background": {
                      "color": "",
                      "opacity": 1
                    "cornerRadius": 3,
                    "enabled": true,
                    "pointerLength": 4,
                  "width": 10
              "connect": true,
              "fill": {
                "color": "",
                "opacity": 0
              "minDistance": 0.5,
              "stroke": {
                "color": "",
                "dashArray": "",
                "opacity": 1,
                "width": 3
              "tensionX": 1,
              "tensionY": 1
            "open": {
              "x": "",
              "y": ""
          "tooltip": {
            "background": {
              "color": "",
              "opacity": 1
            "cornerRadius": 3,
            "enabled": true,
            "pointerLength": 4,
          "visible": true,
          "xAxis": "Monat",
          "zIndex": 0
          "candlestick": {
            "appearance": {
                "fill": {
                  "color": "",
                  "opacity": ""
                "stroke": {
                  "color": "",
                  "opacity": "",
                  "width": ""
              "fill": {
                "color": "",
                "opacity": 1
              "heatRules": {
                "dataField": "",
                "enabled": false,
                "max": "",
                "min": ""
              "stacked": false,
              "stroke": {
                "color": "",
                "opacity": 1,
                "width": 1
            "high": {
              "x": "",
              "y": ""
            "low": {
              "x": "",
              "y": ""
            "open": {
              "x": "",
              "y": ""
          "column": {
            "appearance": {
                "fill": {
                  "color": "",
                  "opacity": ""
                "stroke": {
                  "color": "",
                  "opacity": "",
                  "width": ""
              "fill": {
                "color": "#811c1f",
                "opacity": 1
              "heatRules": {
                "dataField": "",
                "enabled": false,
                "max": "",
                "min": ""
              "height": null,
              "stacked": true,
              "stroke": {
                "color": "",
                "opacity": 0,
                "width": 0
              "width": null
            "open": {
              "x": "",
              "y": ""
          "data": {
            "x": "Monat",
          "defaultState": {
            "visible": true
          "label": {
          "line": {
            "appearance": {
              "bullets": [
                    "fill": {
                      "color": "",
                      "opacity": ""
                    "rotation": "",
                    "stroke": {
                      "color": "",
                      "opacity": "",
                      "width": ""
                  "enabled": true,
                  "fill": {
                    "color": "#C53625",
                    "opacity": 1
                  "heatRules": {
                    "dataField": "",
                    "enabled": false,
                    "max": 100,
                    "min": 2
                  "height": 10,
                  "label": {
                    "position": {
                      "dx": 0,
                      "dy": 0
                    "text": "{value}"
                  "render": "circle",
                  "rotation": 0,
                  "stroke": {
                    "color": "",
                    "opacity": 1,
                    "width": 1
                  "tooltip": {
                    "background": {
                      "color": "",
                      "opacity": 1
                    "cornerRadius": 3,
                    "enabled": true,
                    "pointerLength": 4,
                  "width": 10
              "connect": true,
              "fill": {
                "color": "",
                "opacity": 0
              "stroke": {
                "color": "#C53625",
                "dashArray": "",
                "opacity": 1,
                "width": 3
              "tensionX": 1,
              "tensionY": 1
            "open": {
              "x": "",
              "y": ""
          "render": "line",
          "stepLine": {
            "appearance": {
              "bullets": [
                    "fill": {
                      "color": "",
                      "opacity": ""
                    "rotation": "",
                    "stroke": {
                      "color": "",
                      "opacity": "",
                      "width": ""
                  "enabled": true,
                  "fill": {
                    "color": "",
                    "opacity": 1
                  "heatRules": {
                    "dataField": "",
                    "enabled": false,
                    "max": 100,
                    "min": 2
                  "height": 10,
                  "label": {
                    "position": {
                      "dx": 0,
                      "dy": 0
                    "text": "{value}"
                  "render": "circle",
                  "rotation": 0,
                  "stroke": {
                    "color": "",
                    "opacity": 1,
                    "width": 1
                  "tooltip": {
                    "background": {
                      "color": "",
                      "opacity": 1
                    "cornerRadius": 3,
                    "enabled": true,
                    "pointerLength": 4,
                  "width": 10
              "connect": true,
              "fill": {
                "color": "",
                "opacity": 0
              "minDistance": 0.5,
              "stroke": {
                "color": "",
                "dashArray": "",
                "opacity": 1,
                "width": 3
              "tensionX": 1,
              "tensionY": 1
            "open": {
              "x": "",
              "y": ""
          "tooltip": {
            "background": {
              "color": "",
              "opacity": 1
            "cornerRadius": 3,
            "enabled": true,
            "pointerLength": 4,
          "visible": true,
          "xAxis": "Monat",
          "zIndex": 0
      "style": {
        "margin": 5
      "dataSources": {}
    "meta": {
      "name": "xy_DLZ_Übersicht"
    "position": {
      "grow": 1,
      "basis": "1300px"
    "custom": {},
I did a few corrections in your code. I see three series are configured but only one series is sufficient for your requirement.
You have to assign y source to render the labels on chart.
XY Chart
    "version": 0,
    "props": {
      "title": {
        "appearance": {
          "font": {
            "size": 20,
            "weight": 1000
          "padding": {
            "bottom": 5
      "legend": {
        "position": "left",
        "markers": {
          "width": 15,
          "height": 15
        "labels": {
          "font": {
            "weight": 200,
            "size": 12
      "cursor": {
        "enabled": false
      "xAxes": [
          "name": "Monat",
          "label": {
            "enabled": true,
            "color": ""
          "visible": true,
          "tooltip": {
            "enabled": true,
            "text": "",
            "cornerRadius": 3,
            "pointerLength": 4,
            "background": {
              "color": "",
              "opacity": 1
          "inversed": false,
          "category": {
            "break": {
              "enabled": false,
              "endCategory": "",
              "size": 0.05
          "date": {
            "baseInterval": {
              "enabled": true,
              "timeUnit": "hour",
              "count": 1,
            "range": {
              "max": "",
              "min": "",
              "useStrict": false
            "break": {
              "enabled": false,
              "startDate": "",
              "endDate": "",
              "size": 0.05
            "format": "yyyy-mm"
          "value": {
            "range": {
              "max": "",
              "min": "",
              "useStrict": false
            "break": {
              "enabled": false,
              "startValue": 0,
              "endValue": 100,
              "size": 0.05
          "appearance": {
            "opposite": false,
            "inside": false,
            "labels": {
              "color": "",
              "opacity": 1,
              "rotation": 45,
            "grid": {
              "color": "",
              "opacity": "0.5",
              "minDistance": 60,
              "position": 0.5
            "font": {
              "size": "",
              "weight": 500
      "yAxes": [
          "label": {
            "enabled": true,
            "color": ""
          "visible": true,
          "tooltip": {
            "enabled": true,
            "text": "",
            "cornerRadius": 3,
            "pointerLength": 4,
            "background": {
              "color": "",
              "opacity": 1
          "inversed": false,
          "render": "date",
          "category": {
            "break": {
              "enabled": false,
              "startCategory": 0,
              "endCategory": "",
              "size": 0.05
          "date": {
            "baseInterval": {
              "enabled": true,
              "timeUnit": "hour",
              "count": 1,
            "range": {
              "max": "",
              "min": "",
              "useStrict": false
            "break": {
              "enabled": false,
              "startDate": "",
              "endDate": "",
              "size": 0.05
          "value": {
            "range": {
              "max": "",
              "min": 0,
              "useStrict": false
            "break": {
              "enabled": false,
              "startValue": "",
              "endValue": "",
              "size": 0.05
            "format": "##:00",
          "appearance": {
            "opposite": true,
            "inside": false,
            "labels": {
              "color": "",
              "opacity": 1,
              "rotation": 0,
            "grid": {
              "color": "",
              "opacity": 0.5,
              "dashArray": 4.4,
              "position": 0.5
            "font": {
              "size": "",
              "weight": 500
      "series": [
          "candlestick": {
            "appearance": {
                "fill": {
                  "color": "",
                  "opacity": ""
                "stroke": {
                  "color": "",
                  "opacity": "",
                  "width": ""
              "fill": {
                "color": "",
                "opacity": 1
              "heatRules": {
                "dataField": "",
                "enabled": false,
                "max": "",
                "min": ""
              "stacked": false,
              "stroke": {
                "color": "",
                "opacity": 1,
                "width": 1
            "high": {
              "x": "",
              "y": ""
            "low": {
              "x": "",
              "y": ""
            "open": {
              "x": "",
              "y": ""
          "column": {
            "appearance": {
                "fill": {
                  "color": "",
                  "opacity": ""
                "stroke": {
                  "color": "",
                  "opacity": "",
                  "width": ""
              "fill": {
                "color": "#811c1f",
                "opacity": 1
              "heatRules": {
                "dataField": "",
                "enabled": false,
                "max": "",
                "min": ""
              "height": null,
              "stacked": true,
              "stroke": {
                "color": "",
                "opacity": 0,
                "width": 0
              "width": null
            "open": {
              "x": "",
              "y": ""
          "data": {
            "x": "Monat",
          "defaultState": {
            "visible": true
          "label": {
          "line": {
            "appearance": {
              "bullets": [
                    "fill": {
                      "color": "",
                      "opacity": ""
                    "rotation": "",
                    "stroke": {
                      "color": "",
                      "opacity": "",
                      "width": ""
                  "enabled": true,
                  "fill": {
                    "color": "#0D3D75",
                    "opacity": 1
                  "heatRules": {
                    "dataField": "",
                    "enabled": false,
                    "max": 100,
                    "min": 2
                  "height": 10,
                  "label": {
                    "position": {
                      "dx": 0,
                      "dy": 0
                    "text": "{value}"
                  "render": "circle",
                  "rotation": 0,
                  "stroke": {
                    "color": "",
                    "opacity": 1,
                    "width": 1
                  "tooltip": {
                    "background": {
                      "color": "",
                      "opacity": 1
                    "cornerRadius": 3,
                    "enabled": true,
                    "pointerLength": 4,
                  "width": 10
                  "enabled": true,
                  "render": "label",
                  "width": 10,
                  "height": 10,
                  "label": {
                    "text": "[bold][red]{Durchschnittliche_Zeit}",
                    "position": {
                      "dx": 0,
                      "dy": -10
                  "fill": {
                    "color": "",
                    "opacity": 1
                  "stroke": {
                    "color": "",
                    "opacity": 1,
                    "width": 1
                  "rotation": 0,
                  "tooltip": {
                    "enabled": true,
                    "cornerRadius": 3,
                    "pointerLength": 4,
                    "background": {
                      "color": "",
                      "opacity": 1
                    "fill": {
                      "color": "",
                      "opacity": ""
                    "stroke": {
                      "color": "",
                      "opacity": "",
                      "width": ""
                    "rotation": ""
                  "heatRules": {
                    "enabled": false,
                    "max": 100,
                    "min": 2,
                    "dataField": ""
              "connect": true,
              "fill": {
                "color": "",
                "opacity": 0
              "stroke": {
                "color": "#0D3D75",
                "dashArray": "",
                "opacity": 1,
                "width": 3
              "tensionX": 1,
              "tensionY": 1
            "open": {
              "x": "",
              "y": ""
          "name": "Messzeit",
          "render": "line",
          "stepLine": {
            "appearance": {
              "bullets": [
                    "fill": {
                      "color": "",
                      "opacity": ""
                    "rotation": "",
                    "stroke": {
                      "color": "",
                      "opacity": "",
                      "width": ""
                  "enabled": true,
                  "fill": {
                    "color": "",
                    "opacity": 1
                  "heatRules": {
                    "dataField": "",
                    "enabled": false,
                    "max": 100,
                    "min": 2
                  "height": 10,
                  "label": {
                    "position": {
                      "dx": 0,
                      "dy": 0
                    "text": "{value}"
                  "render": "circle",
                  "rotation": 0,
                  "stroke": {
                    "color": "",
                    "opacity": 1,
                    "width": 1
                  "tooltip": {
                    "background": {
                      "color": "",
                      "opacity": 1
                    "cornerRadius": 3,
                    "enabled": true,
                    "pointerLength": 4,
                  "width": 10
              "connect": true,
              "fill": {
                "color": "",
                "opacity": 0
              "minDistance": 0.5,
              "stroke": {
                "color": "",
                "dashArray": "",
                "opacity": 1,
                "width": 3
              "tensionX": 1,
              "tensionY": 1
            "open": {
              "x": "",
              "y": ""
          "tooltip": {
            "background": {
              "color": "",
              "opacity": 1
            "cornerRadius": 3,
            "enabled": true,
            "pointerLength": 4,
          "visible": true,
          "xAxis": "Monat",
          "zIndex": 0
      "style": {
        "margin": 5
      "dataSources": {
        "Daten_DLZ_Messzeit": [
            "Durchschnittliche_Zeit": "12:04",
            "Monat": "2023-11"
            "Durchschnittliche_Zeit": "14:04",
            "Monat": "2023-12"
    "meta": {
      "name": "xy_DLZ_bersicht"
    "position": {
      "x": 22,
      "y": 60,
      "height": 552,
      "width": 714
    "custom": {}
Hi Ujwal,
hers's my adjusted code:
    "version": 0,
    "props": {
      "title": {
        "appearance": {
          "font": {
            "size": 20,
            "weight": 1000
          "padding": {
            "bottom": 5
      "legend": {
        "position": "left",
        "markers": {
          "width": 15,
          "height": 15
        "labels": {
          "font": {
            "weight": 200,
            "size": 12
      "cursor": {
        "enabled": false
      "xAxes": [
          "name": "Monat",
          "label": {
            "enabled": true,
            "color": ""
          "visible": true,
          "tooltip": {
            "enabled": true,
            "text": "",
            "cornerRadius": 3,
            "pointerLength": 4,
            "background": {
              "color": "",
              "opacity": 1
          "inversed": false,
          "category": {
            "break": {
              "enabled": false,
              "endCategory": "",
              "size": 0.05
          "date": {
            "baseInterval": {
              "enabled": true,
              "timeUnit": "hour",
              "count": 1,
            "range": {
              "max": "",
              "min": "",
              "useStrict": false
            "break": {
              "enabled": false,
              "startDate": "",
              "endDate": "",
              "size": 0.05
            "format": "yyyy-mm"
          "value": {
            "range": {
              "max": "",
              "min": "",
              "useStrict": false
            "break": {
              "enabled": false,
              "startValue": 0,
              "endValue": 100,
              "size": 0.05
          "appearance": {
            "opposite": false,
            "inside": false,
            "labels": {
              "color": "",
              "opacity": 1,
              "rotation": 45,
            "grid": {
              "color": "",
              "opacity": "0.5",
              "minDistance": 60,
              "position": 0.5
            "font": {
              "size": "",
              "weight": 500
      "yAxes": [
          "label": {
            "enabled": true,
            "color": ""
          "visible": true,
          "tooltip": {
            "enabled": true,
            "text": "",
            "cornerRadius": 3,
            "pointerLength": 4,
            "background": {
              "color": "",
              "opacity": 1
          "inversed": false,
          "render": "date",
          "category": {
            "break": {
              "enabled": false,
              "startCategory": 0,
              "endCategory": "",
              "size": 0.05
          "date": {
            "baseInterval": {
              "enabled": true,
              "timeUnit": "hour",
              "count": 1,
            "range": {
              "max": "",
              "min": "",
              "useStrict": false
            "break": {
              "enabled": false,
              "startDate": "",
              "endDate": "",
              "size": 0.05
            "format": "\"D'D': HH'H': mm'M\""
          "value": {
            "range": {
              "max": "",
              "min": 0,
              "useStrict": false
            "break": {
              "enabled": false,
              "startValue": "",
              "endValue": "",
              "size": 0.05
            "format": "##:00",
          "appearance": {
            "opposite": true,
            "inside": false,
            "labels": {
              "color": "",
              "opacity": 1,
              "rotation": 0,
            "grid": {
              "color": "",
              "opacity": 0.5,
              "dashArray": 4.4,
              "position": 0.5
            "font": {
              "size": "",
              "weight": 500
      "series": [
          "label": {
          "visible": true,
          "defaultState": {
            "visible": true
          "data": {
            "x": "Monat",
          "xAxis": "Monat",
          "zIndex": 0,
          "tooltip": {
            "enabled": true,
            "text": "",
            "cornerRadius": 3,
            "pointerLength": 4,
            "background": {
              "color": "",
              "opacity": 1
          "render": "line",
          "candlestick": {
            "open": {
              "x": "",
              "y": ""
            "high": {
              "x": "",
              "y": ""
            "low": {
              "x": "",
              "y": ""
            "appearance": {
              "fill": {
                "color": "",
                "opacity": 1
              "stroke": {
                "color": "",
                "opacity": 1,
                "width": 1
              "stacked": false,
                "fill": {
                  "color": "",
                  "opacity": ""
                "stroke": {
                  "color": "",
                  "opacity": "",
                  "width": ""
              "heatRules": {
                "enabled": false,
                "max": "",
                "min": "",
                "dataField": ""
          "column": {
            "open": {
              "x": "",
              "y": ""
            "appearance": {
              "fill": {
                "color": "#811c1f",
                "opacity": 1
              "stroke": {
                "color": "",
                "opacity": 0,
                "width": 0
              "stacked": true,
              "width": null,
              "height": null,
                "fill": {
                  "color": "",
                  "opacity": ""
                "stroke": {
                  "color": "",
                  "opacity": "",
                  "width": ""
              "heatRules": {
                "enabled": false,
                "max": "",
                "min": "",
                "dataField": ""
          "line": {
            "open": {
              "x": "",
              "y": ""
            "appearance": {
              "connect": true,
              "tensionX": 1,
              "tensionY": 1,
              "stroke": {
                "width": 3,
                "opacity": 1,
                "color": "#FFCC00",
                "dashArray": ""
              "fill": {
                "opacity": 0,
                "color": ""
              "bullets": [
                  "enabled": true,
                  "render": "circle",
                  "width": 10,
                  "height": 10,
                  "label": {
                    "text": "{value}",
                    "position": {
                      "dx": 0,
                      "dy": 0
                  "fill": {
                    "color": "#FFCC00",
                    "opacity": 1
                  "stroke": {
                    "color": "",
                    "opacity": 1,
                    "width": 1
                  "rotation": 0,
                  "tooltip": {
                    "enabled": true,
                    "text": "{name}: [bold]{Durchschnittliche_Zeit} HH:mm",
                    "cornerRadius": 3,
                    "pointerLength": 4,
                    "background": {
                      "color": "",
                      "opacity": 1
                    "fill": {
                      "color": "",
                      "opacity": ""
                    "stroke": {
                      "color": "",
                      "opacity": "",
                      "width": ""
                    "rotation": ""
                  "heatRules": {
                    "enabled": false,
                    "max": 100,
                    "min": 2,
                    "dataField": ""
          "stepLine": {
            "open": {
              "x": "",
              "y": ""
            "appearance": {
              "connect": true,
              "tensionX": 1,
              "tensionY": 1,
              "minDistance": 0.5,
              "stroke": {
                "width": 3,
                "opacity": 1,
                "color": "",
                "dashArray": ""
              "fill": {
                "opacity": 0,
                "color": ""
              "bullets": [
                  "enabled": true,
                  "render": "circle",
                  "width": 10,
                  "height": 10,
                  "label": {
                    "text": "{value}",
                    "position": {
                      "dx": 0,
                      "dy": 0
                  "fill": {
                    "color": "",
                    "opacity": 1
                  "stroke": {
                    "color": "",
                    "opacity": 1,
                    "width": 1
                  "rotation": 0,
                  "tooltip": {
                    "enabled": true,
                    "cornerRadius": 3,
                    "pointerLength": 4,
                    "background": {
                      "color": "",
                      "opacity": 1
                    "fill": {
                      "color": "",
                      "opacity": ""
                    "stroke": {
                      "color": "",
                      "opacity": "",
                      "width": ""
                    "rotation": ""
                  "heatRules": {
                    "enabled": false,
                    "max": 100,
                    "min": 2,
                    "dataField": ""
          "candlestick": {
            "appearance": {
                "fill": {
                  "color": "",
                  "opacity": ""
                "stroke": {
                  "color": "",
                  "opacity": "",
                  "width": ""
              "fill": {
                "color": "",
                "opacity": 1
              "heatRules": {
                "dataField": "",
                "enabled": false,
                "max": "",
                "min": ""
              "stacked": false,
              "stroke": {
                "color": "",
                "opacity": 1,
                "width": 1
            "high": {
              "x": "",
              "y": ""
            "low": {
              "x": "",
              "y": ""
            "open": {
              "x": "",
              "y": ""
          "column": {
            "appearance": {
                "fill": {
                  "color": "",
                  "opacity": ""
                "stroke": {
                  "color": "",
                  "opacity": "",
                  "width": ""
              "fill": {
                "color": "#811c1f",
                "opacity": 1
              "heatRules": {
                "dataField": "",
                "enabled": false,
                "max": "",
                "min": ""
              "height": null,
              "stacked": true,
              "stroke": {
                "color": "",
                "opacity": 0,
                "width": 0
              "width": null
            "open": {
              "x": "",
              "y": ""
          "data": {
            "x": "Monat",
          "defaultState": {
            "visible": true
          "label": {
          "line": {
            "appearance": {
              "bullets": [
                    "fill": {
                      "color": "",
                      "opacity": ""
                    "rotation": "",
                    "stroke": {
                      "color": "",
                      "opacity": "",
                      "width": ""
                  "enabled": true,
                  "fill": {
                    "color": "#811c1f",
                    "opacity": 1
                  "heatRules": {
                    "dataField": "",
                    "enabled": false,
                    "max": 100,
                    "min": 2
                  "height": 10,
                  "label": {
                    "position": {
                      "dx": 0,
                      "dy": 0
                    "text": "{value}"
                  "render": "circle",
                  "rotation": 0,
                  "stroke": {
                    "color": "#811c1f",
                    "opacity": 1,
                    "width": 1
                  "tooltip": {
                    "background": {
                      "color": "",
                      "opacity": 1
                    "cornerRadius": 3,
                    "enabled": true,
                    "pointerLength": 4,
                  "width": 10
              "connect": true,
              "fill": {
                "color": "#811C1F",
                "opacity": 0
              "stroke": {
                "color": "#811c1f",
                "dashArray": "",
                "opacity": 1,
                "width": 3
              "tensionX": 1,
              "tensionY": 1
            "open": {
              "x": "",
              "y": ""
          "name": "Messzeit",
          "render": "line",
          "stepLine": {
            "appearance": {
              "bullets": [
                    "fill": {
                      "color": "",
                      "opacity": ""
                    "rotation": "",
                    "stroke": {
                      "color": "",
                      "opacity": "",
                      "width": ""
                  "enabled": true,
                  "fill": {
                    "color": "",
                    "opacity": 1
                  "heatRules": {
                    "dataField": "",
                    "enabled": false,
                    "max": 100,
                    "min": 2
                  "height": 10,
                  "label": {
                    "position": {
                      "dx": 0,
                      "dy": 0
                    "text": "{value}"
                  "render": "circle",
                  "rotation": 0,
                  "stroke": {
                    "color": "",
                    "opacity": 1,
                    "width": 1
                  "tooltip": {
                    "background": {
                      "color": "",
                      "opacity": 1
                    "cornerRadius": 3,
                    "enabled": true,
                    "pointerLength": 4,
                  "width": 10
              "connect": true,
              "fill": {
                "color": "",
                "opacity": 0
              "minDistance": 0.5,
              "stroke": {
                "color": "",
                "dashArray": "",
                "opacity": 1,
                "width": 3
              "tensionX": 1,
              "tensionY": 1
            "open": {
              "x": "",
              "y": ""
          "tooltip": {
            "background": {
              "color": "",
              "opacity": 1
            "cornerRadius": 3,
            "enabled": true,
            "pointerLength": 4,
            "text": ""
          "visible": true,
          "xAxis": "Monat",
          "zIndex": 0
          "candlestick": {
            "appearance": {
                "fill": {
                  "color": "",
                  "opacity": ""
                "stroke": {
                  "color": "",
                  "opacity": "",
                  "width": ""
              "fill": {
                "color": "",
                "opacity": 1
              "heatRules": {
                "dataField": "",
                "enabled": false,
                "max": "",
                "min": ""
              "stacked": false,
              "stroke": {
                "color": "",
                "opacity": 1,
                "width": 1
            "high": {
              "x": "",
              "y": ""
            "low": {
              "x": "",
              "y": ""
            "open": {
              "x": "",
              "y": ""
          "column": {
            "appearance": {
                "fill": {
                  "color": "",
                  "opacity": ""
                "stroke": {
                  "color": "",
                  "opacity": "",
                  "width": ""
              "fill": {
                "color": "#811c1f",
                "opacity": 1
              "heatRules": {
                "dataField": "",
                "enabled": false,
                "max": "",
                "min": ""
              "height": null,
              "stacked": true,
              "stroke": {
                "color": "",
                "opacity": 0,
                "width": 0
              "width": null
            "open": {
              "x": "",
              "y": ""
          "data": {
            "x": "Monat",
          "defaultState": {
            "visible": true
          "label": {
          "line": {
            "appearance": {
              "bullets": [
                    "fill": {
                      "color": "",
                      "opacity": ""
                    "rotation": "",
                    "stroke": {
                      "color": "",
                      "opacity": "",
                      "width": ""
                  "enabled": true,
                  "fill": {
                    "color": "#0D3D75",
                    "opacity": 1
                  "heatRules": {
                    "dataField": "",
                    "enabled": false,
                    "max": 100,
                    "min": 2
                  "height": 10,
                  "label": {
                    "position": {
                      "dx": 0,
                      "dy": 0
                    "text": "{value}"
                  "render": "circle",
                  "rotation": 0,
                  "stroke": {
                    "color": "#0D3D75",
                    "opacity": 1,
                    "width": 1
                  "tooltip": {
                    "background": {
                      "color": "",
                      "opacity": 1
                    "cornerRadius": 3,
                    "enabled": true,
                    "pointerLength": 4,
                    "text": "{name}: [bold] {Durchschnittliche_Zeit} HH:mm"
                  "width": 10
              "connect": true,
              "fill": {
                "color": "#0D3D75",
                "opacity": 0
              "stroke": {
                "color": "#0D3D75",
                "dashArray": "",
                "opacity": 1,
                "width": 3
              "tensionX": 1,
              "tensionY": 1
            "open": {
              "x": "",
              "y": ""
          "render": "line",
          "stepLine": {
            "appearance": {
              "bullets": [
                    "fill": {
                      "color": "",
                      "opacity": ""
                    "rotation": "",
                    "stroke": {
                      "color": "",
                      "opacity": "",
                      "width": ""
                  "enabled": true,
                  "fill": {
                    "color": "",
                    "opacity": 1
                  "heatRules": {
                    "dataField": "",
                    "enabled": false,
                    "max": 100,
                    "min": 2
                  "height": 10,
                  "label": {
                    "position": {
                      "dx": 0,
                      "dy": 0
                    "text": "{value}"
                  "render": "circle",
                  "rotation": 0,
                  "stroke": {
                    "color": "",
                    "opacity": 1,
                    "width": 1
                  "tooltip": {
                    "background": {
                      "color": "",
                      "opacity": 1
                    "cornerRadius": 3,
                    "enabled": true,
                    "pointerLength": 4,
                  "width": 10
              "connect": true,
              "fill": {
                "color": "",
                "opacity": 0
              "minDistance": 0.5,
              "stroke": {
                "color": "",
                "dashArray": "",
                "opacity": 1,
                "width": 3
              "tensionX": 1,
              "tensionY": 1
            "open": {
              "x": "",
              "y": ""
          "tooltip": {
            "background": {
              "color": "",
              "opacity": 1
            "cornerRadius": 3,
            "enabled": true,
            "pointerLength": 4,
            "text": ""
          "visible": true,
          "xAxis": "Monat",
          "zIndex": 0
      "style": {
        "margin": 5
      "dataSources": {}
    "meta": {
    "position": {
      "grow": 1,
      "basis": "1300px"
    "custom": {},
now it works like a charm!
Thanks for your quick and fruitful support!
