In xyChart there is Candlestick renderer. By default it is red or green depending on Open/Close difference sign. Is it possible to change these colors?
Changing of the fill and stroke colors takes no effekt.
You should be able to use deriveFieldsFromData to make this work. You’d use deriveFieldsFromData.fill.color and set it to whatever key has the color value in your data. The manual has an example of it with a Gantt chart.
Hey @djs , could you reshare the manual link, as I am trying to configure a diverging graph using the candlestick xy chart. where I set the high and open with the same value and close and low with the same value. Basically, this generates the diverging graph, whereas I also need to differentiate the diverging bars with a specific color. Could you anyone share your thoughts to achieve this.
Thanks, in prior.
Does the link not work for you? It still works for me. Try this one.
