Is there a way to fire an event when the selection changes on the Perspective XYChart when “selection” is enabled? It seems like the “onSelect” event is not working. I have the XYChart and a table, and I want both selections to be linked (i.e. if the user selects a column from the XYChart, it selects the matching row in the table and vise-versa).
Hi Joe,
onSelect() wont apply here since that only works for basic text components:
Instead, try creating a Property Change Script against selection.data itself. This will allow you to review the entire json object being created/modified per selection:
https://docs.inductiveautomation.com/display/DOC81/Perspective+Property+Change+Scripts
