Series Json
"name": "Area 3",
"label": {
"text": "Area 3"
"visible": true,
"hiddenInLegend": false,
"defaultState": {
"visible": true
"data": {
"source": "DB",
"x": "T_stamp",
"y": "Area 3"
"xAxis": "T_stamp",
"yAxis": "val",
"zIndex": 0,
"tooltip": {
"enabled": true,
"text": "Count: [bold]{valueY}[/] Faults",
"cornerRadius": 3,
"pointerLength": 4,
"background": {
"color": "#fafafa",
"opacity": 1
"render": "column",
"column": {
"open": {
"x": "",
"y": ""
"appearance": {
"fill": {
"color": "#FFA056",
"opacity": 1
"stroke": {
"color": "#E72955",
"opacity": 1,
"width": 1
"width": null,
"height": null,
"stacked": true,
"deriveFieldsFromData": {
"fill": {
"color": "",
"opacity": ""
"stroke": {
"color": "",
"opacity": "",
"width": ""
"heatRules": {
"enabled": false,
"max": "#FE1810",
"min": "#0CA3FB",
"dataField": "time"
"name": "Area 1",
"label": {
"text": "Area 1"
"visible": true,
"defaultState": {
"visible": true
"data": {
"source": "DB",
"x": "T_stamp",
"y": "Area 1"
"xAxis": "T_stamp",
"yAxis": "val",
"zIndex": 0,
"tooltip": {
"enabled": true,
"cornerRadius": 3,
"pointerLength": 4,
"background": {
"color": "#fafafa",
"opacity": 1
"render": "column",
"column": {
"open": {
"x": "",
"y": ""
"appearance": {
"fill": {
"color": "#56A0FF",
"opacity": 1
"stroke": {
"color": "#E72955",
"opacity": 1,
"width": 1
"width": null,
"height": null,
"stacked": true,
"fill": {
"color": "",
"opacity": ""
"stroke": {
"color": "",
"opacity": "",
"width": ""
"heatRules": {
"enabled": false,
"max": "#FE1810",
"min": "#0CA3FB",
"dataField": "time"
"name": "CIP 32",
"label": {
"text": "CIP 32"
"visible": true,
"defaultState": {
"visible": true
"data": {
"source": "DB",
"x": "T_stamp",
"y": "CIP 32"
"xAxis": "T_stamp",
"yAxis": "val",
"zIndex": 0,
"tooltip": {
"enabled": true,
"cornerRadius": 3,
"pointerLength": 4,
"background": {
"color": "#fafafa",
"opacity": 1
"render": "column",
"column": {
"open": {
"x": "",
"y": ""
"appearance": {
"fill": {
"color": "#AC00AC",
"opacity": 1
"stroke": {
"color": "#E72955",
"opacity": 1,
"width": 1
"width": null,
"height": null,
"stacked": true,
"fill": {
"color": "",
"opacity": ""
"stroke": {
"color": "",
"opacity": "",
"width": ""
"heatRules": {
"enabled": false,
"max": "#FE1810",
"min": "#0CA3FB",
"dataField": "time"
"name": "FM 26",
"label": {
"text": "FM 26"
"visible": true,
"defaultState": {
"visible": true
"data": {
"source": "DB",
"x": "T_stamp",
"y": "FM 26"
"xAxis": "T_stamp",
"yAxis": "val",
"zIndex": 0,
"tooltip": {
"enabled": true,
"cornerRadius": 3,
"pointerLength": 4,
"background": {
"color": "#fafafa",
"opacity": 1
"render": "column",
"column": {
"open": {
"x": "",
"y": ""
"appearance": {
"fill": {
"color": "#56FFA0",
"opacity": 1
"stroke": {
"color": "#E72955",
"opacity": 1,
"width": 1
"width": null,
"height": null,
"stacked": true,
"fill": {
"color": "",
"opacity": ""
"stroke": {
"color": "",
"opacity": "",
"width": ""
"heatRules": {
"enabled": false,
"max": "#FE1810",
"min": "#0CA3FB",
"dataField": "time"
"name": "Area 4",
"label": {
"text": "Area 4"
"visible": true,
"defaultState": {
"visible": true
"data": {
"source": "DB",
"x": "T_stamp",
"y": "Area 4"
"xAxis": "T_stamp",
"yAxis": "val",
"zIndex": 0,
"tooltip": {
"enabled": true,
"cornerRadius": 3,
"pointerLength": 4,
"background": {
"color": "#fafafa",
"opacity": 1
"render": "column",
"column": {
"open": {
"x": "",
"y": ""
"appearance": {
"fill": {
"color": "#FFFF00",
"opacity": 1
"stroke": {
"color": "#E72955",
"opacity": 1,
"width": 1
"width": null,
"height": null,
"stacked": true,
"fill": {
"color": "",
"opacity": ""
"stroke": {
"color": "",
"opacity": "",
"width": ""
"heatRules": {
"enabled": false,
"max": "#FE1810",
"min": "#0CA3FB",
"dataField": "time"
"name": "CIP 31",
"label": {
"text": "CIP 31"
"visible": true,
"defaultState": {
"visible": true
"data": {
"source": "DB",
"x": "T_stamp",
"y": "CIP 31"
"xAxis": "T_stamp",
"yAxis": "val",
"zIndex": 0,
"tooltip": {
"enabled": true,
"cornerRadius": 3,
"pointerLength": 4,
"background": {
"color": "#fafafa",
"opacity": 1
"render": "column",
"column": {
"open": {
"x": "",
"y": ""
"appearance": {
"fill": {
"color": "#A0FF56",
"opacity": 1
"stroke": {
"color": "#E72955",
"opacity": 1,
"width": 1
"width": null,
"height": null,
"stacked": true,
"fill": {
"color": "",
"opacity": ""
"stroke": {
"color": "",
"opacity": "",
"width": ""
"heatRules": {
"enabled": false,
"max": "#FE1810",
"min": "#0CA3FB",
"dataField": "time"
"name": "CIP 33",
"label": {
"text": "CIP 33"
"visible": true,
"defaultState": {
"visible": true
"data": {
"source": "DB",
"x": "T_stamp",
"y": "CIP 33"
"xAxis": "T_stamp",
"yAxis": "val",
"zIndex": 0,
"tooltip": {
"enabled": true,
"cornerRadius": 3,
"pointerLength": 4,
"background": {
"color": "#fafafa",
"opacity": 1
"render": "column",
"column": {
"open": {
"x": "",
"y": ""
"appearance": {
"fill": {
"color": "#FFD700",
"opacity": 1
"stroke": {
"color": "#E72955",
"opacity": 1,
"width": 1
"width": null,
"height": null,
"stacked": true,
"fill": {
"color": "",
"opacity": ""
"stroke": {
"color": "",
"opacity": "",
"width": ""
"heatRules": {
"enabled": false,
"max": "#FE1810",
"min": "#0CA3FB",
"dataField": "time"
"name": "Area 5",
"label": {
"text": "Area 5"
"visible": true,
"defaultState": {
"visible": true
"data": {
"source": "DB",
"x": "T_stamp",
"y": "Area 5"
"xAxis": "T_stamp",
"yAxis": "val",
"zIndex": 0,
"tooltip": {
"enabled": true,
"cornerRadius": 3,
"pointerLength": 4,
"background": {
"color": "#fafafa",
"opacity": 1
"render": "column",
"column": {
"open": {
"x": "",
"y": ""
"appearance": {
"fill": {
"color": "#0000FF",
"opacity": 1
"stroke": {
"color": "#E72955",
"opacity": 1,
"width": 1
"width": null,
"height": null,
"stacked": true,
"fill": {
"color": "",
"opacity": ""
"stroke": {
"color": "",
"opacity": "",
"width": ""
"heatRules": {
"enabled": false,
"max": "#FE1810",
"min": "#0CA3FB",
"dataField": "time"
"name": "Area 2",
"label": {
"text": "Area 2"
"visible": true,
"defaultState": {
"visible": true
"data": {
"source": "DB",
"x": "T_stamp",
"y": "Area 2"
"xAxis": "T_stamp",
"yAxis": "val",
"zIndex": 0,
"tooltip": {
"enabled": true,
"cornerRadius": 3,
"pointerLength": 4,
"background": {
"color": "#fafafa",
"opacity": 1
"render": "column",
"column": {
"open": {
"x": "",
"y": ""
"appearance": {
"fill": {
"color": "#FFA056",
"opacity": 1
"stroke": {
"color": "#E72955",
"opacity": 1,
"width": 1
"width": null,
"height": null,
"stacked": true,
"fill": {
"color": "",
"opacity": ""
"stroke": {
"color": "",
"opacity": "",
"width": ""
"heatRules": {
"enabled": false,
"max": "#FE1810",
"min": "#0CA3FB",
"dataField": "time"
"name": "All",
"label": {
"text": "All"
"visible": true,
"defaultState": {
"visible": true
"data": {
"source": "DB",
"x": "T_stamp",
"y": "All"
"xAxis": "T_stamp",
"yAxis": "val",
"zIndex": 0,
"tooltip": {
"enabled": true,
"cornerRadius": 3,
"pointerLength": 4,
"background": {
"color": "#fafafa",
"opacity": 1
"render": "column",
"column": {
"open": {
"x": "",
"y": ""
"appearance": {
"fill": {
"color": "#56A0FF",
"opacity": 1
"stroke": {
"color": "#E72955",
"opacity": 1,
"width": 1
"width": null,
"height": null,
"stacked": true,
"fill": {
"color": "",
"opacity": ""
"stroke": {
"color": "",
"opacity": "",
"width": ""
"heatRules": {
"enabled": false,
"max": "#FE1810",
"min": "#0CA3FB",
"dataField": "time"
"name": "Area 6",
"label": {
"text": "Area 6"
"visible": true,
"defaultState": {
"visible": true
"data": {
"source": "DB",
"x": "T_stamp",
"y": "Area 6"
"xAxis": "T_stamp",
"yAxis": "val",
"zIndex": 0,
"tooltip": {
"enabled": true,
"cornerRadius": 3,
"pointerLength": 4,
"background": {
"color": "#fafafa",
"opacity": 1
"render": "column",
"column": {
"open": {
"x": "",
"y": ""
"appearance": {
"fill": {
"color": "#AC00AC",
"opacity": 1
"stroke": {
"color": "#E72955",
"opacity": 1,
"width": 1
"width": null,
"height": null,
"stacked": true,
"fill": {
"color": "",
"opacity": ""
"stroke": {
"color": "",
"opacity": "",
"width": ""
"heatRules": {
"enabled": false,
"max": "#FE1810",
"min": "#0CA3FB",
"dataField": "time"
"name": "Systems",
"label": {
"text": "Systems"
"visible": true,
"defaultState": {
"visible": true
"data": {
"source": "DB",
"x": "T_stamp",
"y": "Systems"
"xAxis": "T_stamp",
"yAxis": "val",
"zIndex": 0,
"tooltip": {
"enabled": true,
"cornerRadius": 3,
"pointerLength": 4,
"background": {
"color": "#fafafa",
"opacity": 1
"render": "column",
"column": {
"open": {
"x": "",
"y": ""
"appearance": {
"fill": {
"color": "#56FFA0",
"opacity": 1
"stroke": {
"color": "#E72955",
"opacity": 1,
"width": 1
"width": null,
"height": null,
"stacked": true,
"fill": {
"color": "",
"opacity": ""
"stroke": {
"color": "",
"opacity": "",
"width": ""
"heatRules": {
"enabled": false,
"max": "#FE1810",
"min": "#0CA3FB",
"dataField": "time"
