Zebra DS22 barcode scanner (not sure where to post in here)
Hi guy,
Not sure if any of you guys will be able to here, but can't hurt to ask.
Can anyone assist me is setting up a zebra DS22 barcode scanner to ignore all letters and just display the numbers when scanning.
For instance a serial number of a TV is UKS12345678F
The letters are necessary for other people, but not to me when booking items in via barcode. Just the numbers I need.
So how can I set up my scanner to do this?
I've looked online and it goes on and on about configuration files and specific this and that..it too complicated for me to digest.
Thanks in advance guys.
I'd be shocked if you can make the scanner do that. Make your application do it after you receive the scan.
I think this is possible if you use the Zebra 123Scan tool but I don't have a scanner on hand to test it out. These instructions might not be exact for your situation so read everything first.
Download and install the core scanner driver:
Download and install 123Scan:
Connect to your scanner, create a new rule under Modify Data, define rules to replace characters with nothing.
