2 Things: Odd Date/Time value and multiple tables into 1 excel sheet
Hello All, I have 2 questions.
  1. There is an odd Date/Time Stamp that is being reported out into Perspective table from SQL. see picture below. When I transfer the date to a .xlsx file, it goes back to a normal format. Just in Perspective it's weird. How do I fix it.
  2. As the picture suggests, i have multiple SQL table being generated on one sheet. More for data gathering rather than actual visual analysis. How can i get all 3 tables into one sheet. I currently have a button that our resident developer assisted us with for a different report. see below. Can I use this to get all of them into one workbook? of so, how?
	startdate = self.getSibling("DateTimeInput").props.value
	startdatestr = str(startdate)
	enddate = self.getSibling("DateTimeInput_0").props.value
	enddatestr = str(enddate)
	filename = startdatestr+'-'+enddatestr+' Short Raw Data.xlsx'
	data = self.getSibling("Table").props.data
	data = system.dataset.toExcel(True, [data])
	system.perspective.download(filename,data)
It's displaying the date in epoc time. You have to add a column definition to format it as a date. The field name has to match.
Question 1:
Name the SQL field in each of the columns.0.field properties. e.g.
columns.0.field : Timestamp.
Then the rest of the properties will work.
columns.0.render : date
columns.0.dateFormat: YYYY-MM-DD
Question 2:
I have multiple SQL table being generated on one sheet.
Perspective doesn't have "sheets". Maybe you mean "view"?
You already have, according to your previous statement.
Can you clarify?
There is just one table that it will download the the above code.. do I need to add the other table data names into this part to get separate tabs in the excel sheet? P.S. I don't code.. i dabble as best and can reuse things I already have. I'm Learning :slight_smile:
e.g.
`data = self.getSibling("Table","Table 2","Table 3").props.data`
I am going to add to this for us that are not coders. There is a Property on the left that is your column properties. see picture. When you click the "+" it will look like your other columns have disappeared. Have no fear, they are there. Keep pressing the "+" until all of your other columns are visible again. Then you can change the field property information as above to change the date...
I solved question 2... i needed to create the "data" datasets and then add them into the download like shown below. :slight_smile: YAY ME!!... lol
	L1data = self.getSibling("Line 1 Data").props.data
	L2data = self.getSibling("Line 2 Data").props.data
	L3data = self.getSibling("Line 3 Data").props.data
	data = system.dataset.toExcel(True, [L1data,L2data,L3data])
