I am having issues with restoring a Gateway to a new machine. (Ignition 8.1.22).
I do this regularly on our Ignition 7.9 gateways without issue. I run into problems when doing this on version 8. All the settings move over as expected and everything outside of AD appears to work correctly. I have compared the new machine with a working one and they seem to have the same settings and users.
Not sure what I am missing. Any insight would be appreciated.
[profileName=AD Internal] Primary LDAP connection failed: connecting to secondary "ldaps://........."
Both the primary and secondary fail immediately when trying to login or using the "verify a user Source" function on the gateway. We use our AD for controlling access to our designers.
I can still log in via a default user source and have checked the settings, which match the server that is still working with AD. (On the same Ignition version)
Is it possible that there is a config setting or something that needs to be changed for AD to work after installing the backup on a fresh Ignition install?
You have SSL enabled, which means the root/CA cert being used to sign the AD server certificate almost certainly needs to be added to Ignition's trusted certificates.
