Attempting to open new session, but session already open for this thread
Using Ignition 7.9.2
Once a minute, every minute I get the following two errors in my log. I’m not sure what’s creating them and from what I can tell each one says the exact same thing. Any ideas?
PersistanceInterface - Attempting to open new session, but session already open for this thread.
java.lang.Exception: null
at com.inductiveautomation.ignition.gateway.localdb.PersistenceInterfaceImpl.getSession(PersistenceInterfaceImpl.java:63)
at com.inductiveautomation.ignition.gateway.localdb.PersistenceInterfaceImpl.getSession(PersistenceInterfaceImpl.java:46)
at com.inductiveautomation.ignition.gateway.sqltags.tagproviders.internal.InternalTagStore.openIfNot(InternalTagStore.java:1300)
at com.inductiveautomation.ignition.gateway.sqltags.tagproviders.internal.InternalTagStore.internalStoreTagValues(InternalTagStore.java:1339)
at com.inductiveautomation.ignition.gateway.sqltags.tagproviders.internal.InternalTagStore.storeTagValues(InternalTagStore.java:1248)
at com.inductiveautomation.ignition.gateway.sqltags.providers.AbstractStoreBasedTagProvider.tagValuesChanged(AbstractStoreBasedTagProvider.java:2449)
at com.inductiveautomation.ignition.gateway.sqltags.scanclasses.SimpleExecutableScanClass$ScanClassTagEvaluationContext.processAndReset(SimpleExecutableScanClass.java:1131)
at com.inductiveautomation.ignition.gateway.sqltags.scanclasses.SimpleExecutableScanClass.run(SimpleExecutableScanClass.java:920)
at com.inductiveautomation.ignition.common.execution.impl.BasicExecutionEngine$SelfSchedulingRunner.run(BasicExecutionEngine.java:511)
at com.inductiveautomation.ignition.common.execution.impl.BasicExecutionEngine$TrackedTask.run(BasicExecutionEngine.java:593)
at java.util.concurrent.Executors$RunnableAdapter.call(Unknown Source)
at java.util.concurrent.FutureTask.run(Unknown Source)
at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.access$201(Unknown Source)
at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.run(Unknown Source)
at java.util.concurrent.ThreadPoolExecutor.runWorker(Unknown Source)
at java.util.concurrent.ThreadPoolExecutor$Worker.run(Unknown Source)
at java.lang.Thread.run(Unknown Source)
Config - Error storing tag values.
simpleorm.utils.SException$Error: Transaction already committed, need begin.
at simpleorm.sessionjdbc.SSessionJdbc.checkBegunThread(SSessionJdbc.java:335)
at simpleorm.sessionjdbc.SSessionJdbc.rollback(SSessionJdbc.java:388)
at com.inductiveautomation.ignition.gateway.localdb.PersistenceInterfaceImpl.getSession(PersistenceInterfaceImpl.java:64)
You should upgrade to 7.9.5. It looks like the internal DB’s access system (designed to be single-threaded) is overrunning itself; so there are multiple transactions happening at the same time on different cursors. There’s a fix for this in 7.9.5.
Thanks Paul, I’ll check and find out if that’s an option they’re willing to take
I recently started having a similar issue. I assumed it’s a syntax error in one of my named queries, but I haven’t found it yet…
>Config	18Apr2018 16:57:46	Error storing tag values.
at simpleorm.sessionjdbc.SSessionJdbc.checkBegunThread(SSessionJdbc.java:353)
at simpleorm.sessionjdbc.SSessionJdbc.rollback(SSessionJdbc.java:408)
at com.inductiveautomation.ignition.gateway.localdb.PersistenceInterfaceImpl.getSession(PersistenceInterfaceImpl.java:57)
at com.inductiveautomation.ignition.gateway.localdb.PersistenceInterfaceImpl.getSession(PersistenceInterfaceImpl.java:44)
at com.inductiveautomation.ignition.gateway.sqltags.tagproviders.internal.InternalTagStore.openIfNot(InternalTagStore.java:1303)
at com.inductiveautomation.ignition.gateway.sqltags.tagproviders.internal.InternalTagStore.internalStoreTagValues(InternalTagStore.java:1341)
at com.inductiveautomation.ignition.gateway.sqltags.tagproviders.internal.InternalTagStore.storeTagValues(InternalTagStore.java:1250)
at com.inductiveautomation.ignition.gateway.sqltags.providers.AbstractStoreBasedTagProvider.tagValuesChanged(AbstractStoreBasedTagProvider.java:2433)
at com.inductiveautomation.ignition.gateway.sqltags.scanclasses.SimpleExecutableScanClass$ScanClassTagEvaluationContext.processAndReset(SimpleExecutableScanClass.java:1136)
at com.inductiveautomation.ignition.gateway.sqltags.scanclasses.SimpleExecutableScanClass.run(SimpleExecutableScanClass.java:896)
at com.inductiveautomation.ignition.common.execution.impl.BasicExecutionEngine$SelfSchedulingRunner.run(BasicExecutionEngine.java:483)
at com.inductiveautomation.ignition.common.execution.impl.BasicExecutionEngine$TrackedTask.run(BasicExecutionEngine.java:565)
>PersistenceInterface	18Apr2018 16:57:46	Attempting to open new session, but session already open for this thread.
at com.inductiveautomation.ignition.gateway.localdb.PersistenceInterfaceImpl.getSession(PersistenceInterfaceImpl.java:56)
I wouldn’t worry about something that you’ve done - with an internal DB error, I would recommend going straight to support to get things straightened out. That’s not a situation that should happen in normal operation.
Hi, We’ve got the same error ‘‘Attempting to open new session, but session already open for this thread’’. We couldn’t create a new tags or delete ancient tags. We’ve only restart the Ignition Gateway and the problem was resolved.
