Best way to publish non-SparkplugB MQTT data?
Hi all,
I'm looking for the best approach to put an entire tag provider (or a certain folders) to publish plain MQTT (non-SpB) on change. I currently have an on-change tag event working (script below) but I'd like to design something more scalable instead of putting scripts on each tag. I"m thinking a gateway event could do this?
Basically I'd like all the functionality of the MQTT transmitter but not have it in SparkplugB format.
Script -----
tagvalue = tag.value
system.cirruslink.transmission.publish("Chariot SCADA", tagPath, str(tagvalue.value).encode(), 0, 0)
Hi all,
Referencing this post on IA forum, and here on Cirrus Link forum, looks like if I use a custom namespace, it may be a work-around for SpB
what did you end up doing here?
Probably worth mentioning the new[ish] UNS Transmitter in MQTT Transmission, as this wasn't available at the time of this original post.
Ended up not using MQTT, MES vendor bypassed Ignition to go direct to the equipment controller with their native edge connectors. Ugh....
Thanks for the reply!
Hi @Kevin.Collins I got it working and thanks for the links.
I do have another question, I noticed in the broker when i send a temperature for example, there are two topics, Temperature.props = {} and temperature = {value:mysuff}.
Any idea what the temperature.props = {} is used for and if I need it or can remove it?
Thanks again!
