Little goofy behavior that I haven’t figured out yet. If I put a date time input object on a popup with a specific format property the calendar will show up behind the popup that the object is on. If I change the format it will show up on the popup.
This format works fine on a popup
If I change the format to “ll” and click on the object the blue box shows up like it is selected but the calendar isn’t shown. I dragged the popup over and saw the calendar behind it.
If you navigate to this view rather than open it as a popup it works fine with both format types.
