Camera Access from Laptop
Hello!
Is there any way to access the Laptop Camera to scan the Barcode, the same way we do it with the Mobile Camera?
Thanks and Regards,
Rahul P
You have tagged this as Vision and Perspective, the methodology will differ for each.
Vision has an IP camera component but to my knowledge cannot natively process barcodes.
In vision I have used keyence scanner for 2D barcodes, but using a PLC as a middle-man.
And what about Perspective ?
Even if a Perspective session in the browser could access your laptop camera it wouldn't be able to scan barcodes. Barcode recognition is a function of iOS and Android, which is why you only find it in the mobile apps.
On a PC you need to use an external barcode scanner.
