Can't Display webpage on InlineFrame
I am using an Inline Frame to try and display a cameras live view. When I copy the desired URL into the src property I get a "refuse to connect" in the Inline Frame. I am able to open the page, in a new tab, if I set the target of a button to the same URL. Not sure why I am getting this error.
If it works in its own page but not in an iframe, it might be an CSP/X-frame issue with the camera server.
See this similar topic:
EDIT: Not CORS, sorry, that's something different
I am currently working with a Cognex In-Sight 9000 Camera and trying to get the HMI to be displayed through an IFrame component in Perspective. Whenever I fill in the src prop with the correct path, I get this.
Does anyone know of anyway to make this work?
Or if there is any other way to display this HMI, with another perspective component or workaround?
Any information would be helpful.
Does the URL work fine in a browser? If so, maybe it's related to this:
EDIT: Oh, I realized you posted before with a similar sounding issue:
Is this the same problem as back then? If it is, you can (and should, as multiple posting on the same subject is against the rules) bump that thread instead of posting a new one if you're still having issues with it.
Yeah, it is still the same issue.
I have also seen that thread before, but I was hoping that someone has found a solution since it was posted.
In that case, I definitely recommend you bump the old thread instead with additional info, something like "I read that linked thread but [we're not allowed to set up a proxy/we tried to set up a proxy and it didn't work/some other issue] so I was hoping for a different workaround."
You can start from the browser console where this isn't working. There might be some kind of a clearer indication of what the problem is.
I have the same/similar issue. The developer of the webpage has the webpage restricted from being embedded.
You can find the information about this in the user manual for Inline Frame under the description section, Perspective - Inline Frame | Ignition User Manual
look at the x-frame-options under the response headers through a normal browser in web developer tools (network tab) to see how yours is set.
My experience:
When trying to load URLs in a Perspective inlineFrame, I often encounter the dreaded "refused to connect" error if the URL roots don’t match. This happens when the inlineFrame source URL uses a root address that differs from the session gateway address — for example, one using an IP address and the other using a domain name.
Example:
  • Session gateway address: http://computer_name.team.com:8088/file.html
  • inlineFrame source URL: http://computer_name:8088/file.html
Both URLs work fine in separate Chrome tabs, but the inlineFrame will not connect if they don’t match exactly.
Solution: Always ensure the inlineFrame source URL matches the session address:
  • inlineFrame source URL: http://computer_name.team.com:8088/file.html
    or
  • Session gateway address: http://computer_name:8088/file.html
    or
  • Session gateway address: http://10.10.10.9:8088/file.html
  • inlineFrame source URL: http://10.10.10.9:8088/file.html
self.session.props.gateway.address
This is default behavior of modern browsers, for limiting malware. This behavior can be overridden by the server of the inner page (the one inside the IFrame) by having it set desired X-Frame-Options and/or Content-Security-Policy headers.
Hello, what id the inner page was a perspective application ? there is no way to edit Content-Security-Policy!
