java.util.concurrent.ExecutionException: java.lang.Exception: Unable to get the view config: View config is undefined.
at java.base/java.util.concurrent.CompletableFuture.reportGet(Unknown Source)
at java.base/java.util.concurrent.CompletableFuture.get(Unknown Source)
at com.inductiveautomation.perspective.designer.workspace.ViewResourceEditor.getObjectForSave(ViewResourceEditor.java:341)
at com.inductiveautomation.perspective.designer.workspace.ViewResourceEditor.getObjectForSave(ViewResourceEditor.java:57)
at com.inductiveautomation.ignition.designer.tabbedworkspace.ResourceEditor.commit(ResourceEditor.java:160)
at com.inductiveautomation.perspective.designer.workspace.ViewResourceEditor.notifyDeactivated(ViewResourceEditor.java:432)
at com.inductiveautomation.perspective.designer.workspace.PerspectiveWorkspaceListener.editorSelected(PerspectiveWorkspaceListener.java:63)
at com.inductiveautomation.ignition.designer.tabbedworkspace.TabbedResourceWorkspace$2.stateChanged(TabbedResourceWorkspace.java:86)
at java.desktop/javax.swing.DefaultSingleSelectionModel.fireStateChanged(Unknown Source)
at com.jidesoft.swing.JideTabbedPane$IgnoreableSingleSelectionModel.fireStateChanged(Unknown Source)
at java.desktop/javax.swing.DefaultSingleSelectionModel.setSelectedIndex(Unknown Source)
at java.desktop/javax.swing.JTabbedPane.setSelectedIndexImpl(Unknown Source)
at java.desktop/javax.swing.JTabbedPane.setSelectedIndex(Unknown Source)
at com.jidesoft.swing.JideTabbedPane.setSelectedIndex(Unknown Source)
at com.inductiveautomation.perspective.designer.PerspectiveNavNode.onSelected(PerspectiveNavNode.java:28)
at com.inductiveautomation.ignition.designer.navtree.model.AbstractNavTreeNode.dispatchSelectionEvent(AbstractNavTreeNode.java:685)
at com.inductiveautomation.ignition.designer.navtree.NavTreePanel$SelectionListener.valueChanged(NavTreePanel.java:531)
at java.desktop/javax.swing.JTree.fireValueChanged(Unknown Source)
at java.desktop/javax.swing.JTree$TreeSelectionRedirector.valueChanged(Unknown Source)
at java.desktop/javax.swing.tree.DefaultTreeSelectionModel.fireValueChanged(Unknown Source)
at java.desktop/javax.swing.tree.DefaultTreeSelectionModel.notifyPathChange(Unknown Source)
at java.desktop/javax.swing.tree.DefaultTreeSelectionModel.addSelectionPaths(Unknown Source)
at java.desktop/javax.swing.tree.DefaultTreeSelectionModel.addSelectionPath(Unknown Source)
at java.desktop/javax.swing.JTree.addSelectionPath(Unknown Source)
at java.desktop/javax.swing.JTree.setExpandedState(Unknown Source)
at java.desktop/javax.swing.JTree.collapsePath(Unknown Source)
at java.desktop/javax.swing.plaf.basic.BasicTreeUI.toggleExpandState(Unknown Source)
at java.desktop/javax.swing.plaf.basic.BasicTreeUI.handleExpandControlClick(Unknown Source)
at java.desktop/javax.swing.plaf.basic.BasicTreeUI.checkForClickInExpandControl(Unknown Source)
at java.desktop/javax.swing.plaf.basic.BasicTreeUI$Handler.handleSelection(Unknown Source)
at java.desktop/javax.swing.plaf.basic.BasicTreeUI$Handler.mousePressedDND(Unknown Source)
at java.desktop/javax.swing.plaf.basic.BasicTreeUI$Handler.mousePressed(Unknown Source)
at java.desktop/java.awt.AWTEventMulticaster.mousePressed(Unknown Source)
at java.desktop/java.awt.EventQueue$5.run(Unknown Source)
Caused by: java.lang.Exception: Unable to get the view config: View config is undefined.
at com.inductiveautomation.perspective.designer.workspace.JavaJsBridge.onSaveError(JavaJsBridge.java:110)
at com.teamdev.jxbrowser.chromium.JSContext.a(SourceFile:1624)
at com.teamdev.jxbrowser.chromium.JSContext$a.onMessageReceived(SourceFile:666)
at com.teamdev.jxbrowser.chromium.internal.ipc.q.a(SourceFile:1085)
at com.teamdev.jxbrowser.chromium.internal.ipc.r.run(SourceFile:69)
at com.teamdev.jxbrowser.chromium.internal.s.run(SourceFile:79)
Ignition v8.0.0 (b2019040718)
Java: Azul Systems, Inc. 11.0.2
