Clarification on Evaluation Instance Runtime Limitation for Commercial Use
Hello everyone,
I need some clarification regarding the use of the Evaluation Instance of Inductive Automation's software. According to the license agreement, the Evaluation Instance can be used without charge but is limited to a two-hour runtime per session. My questions are:
  1. Does this mean we can only use the Evaluation Instance for two hours in total, or can we reset it and continue using it beyond the two-hour limit by restarting the software?
  2. If we can reset it, is it permissible to use the Evaluation Instance repeatedly in a commercial setup by restarting it every two hours for continuous evaluation?
Any insights or official guidance on this matter would be greatly appreciated.
Thank you!
Pramod Singh
The documentation clearly answers your questions and has videos explaining further.
This is exactly the same question that I answered sixteen hours ago over here:
Are you the same person? Or working together? Either way, duplicate posts are forbidden by the rules of this forum.
Hey pturmel,
Yes we are working together. I will delete my question. Thank you for your reply.
Thank you, Daniel.
