When the post says to "add a Control logix gateway", do they mean that the tags will need to be read into the Control Logix or is there a way to navigate through the gateway to the other devices to pull tags?
That would seem like a lot of traffic on the controlnet, so they mean just whatever is on the control logix will get pulled in right?
Sorry to ask such simple questions. I don't want to make any painful or expensive mistakes.
The link about the connection paths did not work for me.
So I think maybe if I had that, it would make more sense to me.
http://inductiveautomation.com/support/kb/149
Just shows me the main support page
Old stuff
Can't read a compact logix control net system
Anyone have a better option than this adapter?
https://www.anybus.com/products/gateway-index/anybus-xgateway/detail/anybus-x-gateway-iiot---powerlink-slave-mqtt-and-opc-ua
controlnet to OPC UA
450 bytes
5Mb baud rate
Requires setting the tags that are desired to pass through it though.
https://docs.inductiveautomation.com:8443/display/DOC79/Browsing+and+Creating+OPC+Tags
this link did not work for me
I wanted to see what it said though. It was in one of the similar posts.
Thought maybe I could get a solution there.
