Connecting Tecnomatix Plant Simulation to Ignition OPCUA Server
I am trying to connect Ignition OPCUA server to my Technomatix Plant Simulation OPCUA Client. I have attached the image of the OPCUA module Endpoint URL in Technomatix Plant Simulation. Also, attached is the server setting in Ignition. But i am not able to make the connection. What might be the issue? Is the Endpoint URL wrong, or the server settings?
Also, how do I read parameter data from Technomatix and view it in my server once the connection takes place?
Note : I am trying to use 3rd party UA Expert Client to connect with the Ignition Server too.
You already have a topic on this subject open. Multiple postings are against this forum's rules.
Continue the discussion in the one topic.
