I have a Click PLC with a Modbus TCP connection with the following MODBUS addresses
This goes from DF1 to DF100, where the MODBUSS address increments by 2 the entire way.
I tried to make them like this but am getting an error that my modbus value is too high
What am I doing wrong?
Using 8.1.7
Try removing the 4- prefix from your address. 1, 2, 3, and 4 are used as prefixes in some Modbus address notations to indicate the data area to read from. 4 is Holding Register.
edit: misspoke, it’s actually 0, 1, 3, and 4 for Coils, Discrete Inputs, Input Registers, Holding Registers. 2 is not used.
So I have a new error (progress!). That worked in that it created 100 tags, but none of them are showing the values I expected, so I must have something in my configuration off. Is there a way to delete the addresses I just added so I can try again? Or do I need to delete the device and recreate the connection to try again?
You may now have an off-by-one error. Ignition address notation starts from 1, which is 0 on the wire. Some notations actually start at 0. Try toggling the One/Zero-based address setting. If that doesn’t work try it in combination with the Word Order setting.
@Kevin.Herron ya did it again. It was the Zero-based addressing option I tried first and that worked for me.
Login into your gateway. Then configuration->Device Connections->Edit your device, then you have to select the checkbox for "Show advanced properties" and it should be there.
Years later, thank you Kevin.
