Css to change datepicker calender to be mon->sun instead of sun->sat
For those who want it, here is the magic! its not perfect but eh:
for theme.css
.iaDateRangePicker .calendarBar { grid-template-columns: none; } .calendarBar > div:nth-child(1) { grid-area: 1/8/1/8 !important; } .iaDateRangePicker .calendar{grid-template-columns: none;} .calendar > div[style$="2;"]{ grid-column-start: 8 !important; grid-column-end: 8 !important;}.calendar > div[style^="grid-area: 1"]{ grid-row-start: 2 !important;}.calendar > div[style^="grid-area: 2"]{ grid-row-start: 3 !important;}.calendar > div[style^="grid-area: 3"]{ grid-row-start: 4 !important;}.calendar > div[style^="grid-area: 4"]{ grid-row-start: 5 !important;}.calendar > div[style^="grid-area: 5"]{ grid-row-start: 6 !important;}.calendar > div[style^="grid-area: 6"]{ grid-row-start: 7 !important;} .calendar > div[style$="2;"][style^="grid-area: 1"]{ grid-row-start: 1 !important;}.calendar > div[style$="2;"][style^="grid-area: 2"]{ grid-row-start: 2 !important;}.calendar > div[style$="2;"][style^="grid-area: 3"]{ grid-row-start: 3 !important;}.calendar > div[style$="2;"][style^="grid-area: 4"]{ grid-row-start: 4 !important;}.calendar > div[style$="2;"][style^="grid-area: 5"]{ grid-row-start: 5 !important;}.calendar > div[style$="2;"][style^="grid-area: 6"]{ grid-row-start: 6 !important;} .iaTimePickerInput--wrapper{ margin-top: 30px; }
this also works for the other datepicker
(or for injection in a style class)
} .iaDateRangePicker .calendarBar { grid-template-columns: none; } .calendarBar > div:nth-child(1) { grid-area: 1/8/1/8 !important; } .iaDateRangePicker .calendar{grid-template-columns: none;} .calendar > div[style$="2;"]{ grid-column-start: 8 !important; grid-column-end: 8 !important;}.calendar > div[style^="grid-area: 1"]{ grid-row-start: 2 !important;}.calendar > div[style^="grid-area: 2"]{ grid-row-start: 3 !important;}.calendar > div[style^="grid-area: 3"]{ grid-row-start: 4 !important;}.calendar > div[style^="grid-area: 4"]{ grid-row-start: 5 !important;}.calendar > div[style^="grid-area: 5"]{ grid-row-start: 6 !important;}.calendar > div[style^="grid-area: 6"]{ grid-row-start: 7 !important;} .calendar > div[style$="2;"][style^="grid-area: 1"]{ grid-row-start: 1 !important;}.calendar > div[style$="2;"][style^="grid-area: 2"]{ grid-row-start: 2 !important;}.calendar > div[style$="2;"][style^="grid-area: 3"]{ grid-row-start: 3 !important;}.calendar > div[style$="2;"][style^="grid-area: 4"]{ grid-row-start: 4 !important;}.calendar > div[style$="2;"][style^="grid-area: 5"]{ grid-row-start: 5 !important;}.calendar > div[style$="2;"][style^="grid-area: 6"]{ grid-row-start: 6 !important;} .iaTimePickerInput--wrapper{ margin-top: 30px; }{
Thank you for this, I used it.
I have also modified the popup datepicker, to be 2x bigger for the touchscreen interaction.
Hello, It didn't work for me. What is the theme file to modify ? what is the component propertie to modify to do it in a style class ? does it work for Ignition 8.1.18 ? Thanks !
What didn't work for you? What did you try? Did you modify <theme>.css?
First I tried adding the code to the file of my theme: "common/date-range-picker.css" since I didn't know very well what file you refer whem typing .css. It didn work after restar Ignition.
Aftewards I tried to do it adding background-image properties to the date picker control as you indicate (look at the image) but it didn't work either:
The image is showing a style class. Not the style properties.
It's a lot easier to add in css in the newest version
That's useful! Thanks Victor!
It Worked !!! Awesome, great job !
Hi @victordcq
Did you manage to find any solution for choosing start date and end date in single date calendar
This feature only available in power chart
Did you crack anything?
This does not seem to be related to this post, where was the original question for this? plz post there
See what's going on in this thread:
Hi @victordcq - been reading a lot of your posts lately, thanks for all your contributions.
Starting recently (not exactly sure when), the code above is causing the body of the calendar to be offset from the month/date selector. Has anyone else seen this? Any fixes for it?
Also, with this code, the month of June displays 7 weeks, which forces scrollbars on the component. Any ideas how to get around this?
Code included below for completeness, but it is a literal copy/paste of what has been posted above.
.ia_DateRangePicker .calendarBar { grid-template-columns: none; }
    .ia_DateRangePicker .calendar{grid-template-columns: none;}
    .ia_TimePickerInput--wrapper{ margin-top: 30px; }
Hehe welcome to the depths of css :stuck_out_tongue:
The code you provided is not the same as mine, my css does not have this offset.
.iaDateRangePicker .calendarBar { grid-template-columns: none;}
.calendarBar>div:nth-child(1) { grid-area: 1/8/1/8 !important;}
.iaDateRangePicker .calendar { grid-template-columns: none;}
.calendar>div[style$="2;"] {grid-column-start: 8 !important; grid-column-end: 8 !important;}
.calendar>div[style^="grid-area: 1"] { grid-row-start: 2 !important;}
.calendar>div[style^="grid-area: 2"] { grid-row-start: 3 !important;}
.calendar>div[style^="grid-area: 3"] { grid-row-start: 4 !important;}
.calendar>div[style^="grid-area: 4"] { grid-row-start: 5 !important;}
.calendar>div[style^="grid-area: 5"] { grid-row-start: 6 !important;}
.calendar>div[style^="grid-area: 6"] { grid-row-start: 7 !important;}
.calendar>div[style$="2;"][style^="grid-area: 1"] { grid-row-start: 1 !important;}
.calendar>div[style$="2;"][style^="grid-area: 2"] { grid-row-start: 2 !important;}
.calendar>div[style$="2;"][style^="grid-area: 3"] { grid-row-start: 3 !important;}
.calendar>div[style$="2;"][style^="grid-area: 4"] { grid-row-start: 4 !important;}
.calendar>div[style$="2;"][style^="grid-area: 5"] { grid-row-start: 5 !important;}
.calendar>div[style$="2;"][style^="grid-area: 6"] { grid-row-start: 6 !important;}
.iaTimePickerInput--wrapper { margin-top: 30px;}
Gitting rid of the extra week is not possible in css...
Well it can if its a filler, but not if day one of the month is sunday
And while its possible to fix the height with css, it might just be safer to give the component a heigher standard size from the beginning, so that the sudden increase doesnt affect other components
this is wrong, there is not _ here
same as here
ia naming convention is not really consistent sometimes :stuck_out_tongue:
:see_no_evil:
Bringing this back from the dead to post a complete solution with no scrollbar.
We have used this for ages (Thanks heaps @victordcq)
To remove the scrollbar, you can just override the height property of .iaDateRangePicker to auto.
It's set to a fixed height by default so it can't handle the extra row.
As this is a popup, it won't mess with your page when it grows. It works with just date or date and time. There's a bit of blank space but it's acceptable IMO.
It would be nice if this component could have this feature added.
Maybe a gateway checkbox that says, "I'm not in the USA" so all the default date formats are set sensibly and this control works properly :winking_face_with_tongue:
UPDATE. fix day header alignment.
/*Change date time picker to start on a monday, this is a total hack*/
.iaDateRangePicker{	height: auto;}
.iaDateRangePicker .calendarBar {grid-template-columns: none;}
.calendarBar > div:nth-child(1) { grid-area: 1/8/1/8 !important;}
In your screenshot the headers (Mo,Tu..) are not lined up correctly, any idea why?
xD
Btw since than, there is a new css feature ":has" which can probably hide the access date row on top.
I might look into it next week if i got time
Good pickup, I don't know how I missed that.
The calendarBar needs grid-template-columns set to none.
I've edited my post with the corrected css.
Thanks again.
ah, just forgot to copy the first line.
no problem
