EasyChart 2 marks at Mrk mode
At my application, we have trends that shows the pressure at an HPU.
I'm using the EasyChart to trend the pressure.
I would like to do a second mark at the trend where I could calculate the deviation and show it automatically.
You should check out Phil's Note Chart Module:
It has this functionality built in.
While I believe it to be technically possible with the first party chart components, the task is far from trivial.
Thanks, Irose, I'll check Phil's note.
You could create any number of marks you want using value, range, and interval markers.
Examples:
• Two X-Trace on Easy Chart
• Overlaying non-associated Alarms on Trends
• Vision Chart - Multiple markers and movable
• Change background color of Vision chart
If you want to display words in the plot of the chart, search the forum for XYTextAnnotations
