Ignition 8.1.3.
It is missing after the disabled restore, see picture below:
Also, I cannot enable it either as Edge does not have this config:
How can i enable the “edge” tag provider?
Edit: I was going to send in a support ticket, bit thought it might be more efficient using the forums
I believe this is a known bug:
Did you happen to restore a .gwbk (possibly disabled?) We’re currently missing a way to re-enable the tag provider on Edge (whoops).
If that’s the case, Support can probably get things straightened out for you - the procedure to re-enable isn’t too complicated, but it’s in a theoretically “dangerous” area where you could break things.
I think you may be able to re-enable it by editing the internal db, if you're comfortable with that. Otherwise, it sounds like you're stuck calling support.
