Edit UDT Definition in script
Is it possible to edit a UDT definition in a script?
I want to either create a UDT definition in a script from scratch and/or add/remove UDT member tags from the UDT definition.
Or is there an automated way to import a tag export (.xml) file?
system.tag.configure
Probably easiest to build by hand a UDT that resembles what you want and inspect it using system.tag.getConfiguration. That will get you familiar with the structure you need for system.tag.configure.
