Equipment scedule
anyone to guide on to use eqipment shedule component in perspetive for daily production detail view for monthly oee purpose
I recently explained the basics of using the Perspective Equipment Schedule in this post:
Monthly OEE to me indicates you have some data already that can be used to define the availability of the devices and are interested in having it tracked in the component. I think it's worth noting there is no correct way to use the component for OEE. The dashboard would likely include more than this component. The minimum properties you use in the component are items and scheduledEvents.
So to use the component you would need to have ranges of time stored in the database that represent either up-time, or specific events that you are expecting related to the production process or devices. For OEE specifically, you'd likely take advantage of the downtimeEvents property to signify any time the device should have been running but wasn't.
You could potentially represent performance using the percentDone, where a completed bar at the bottom of the up-time or event translates to 100% performance.
I am not sure how one would visualize quality especially if there is a time lag between the process and quality information being returned. You could potentially use the leadTime as a static color indicator rather than it's original purpose, and change between good and bad colors to represent general quality during events.
If anyone in general wants to learn more about OEE check out our beginner video!
