Error executing query against logs database
After updating from version 8.1.19 to 8.1.22 the logging issue came with errors
What could be the reason and is there something what could be done.
Same issue was found few years back on early access thread:
Gateway log: Error executing query against logs database
INFO   | jvm 1    | 2022/12/05 12:52:59 | True
INFO   | jvm 1    | 2022/12/05 12:52:59 | Good
INFO   | jvm 1    | 2022/12/05 12:52:59 | Mon Dec 05 12:52:29 EET 2022
INFO   | jvm 1    | 2022/12/05 12:52:59 | True arvo
INFO   | jvm 1    | 2022/12/05 12:53:00 | Scheduling logfile maintenance. Last maintenance: Mon Dec 05 12:51:58 EET 2022, events since then: 1
INFO   | jvm 1    | 2022/12/05 12:53:00 | Starting logfile maintenance. Max entries: 50000, Max filesize: 104857600
INFO   | jvm 1    | 2022/12/05 12:53:03 | E [c.i.i.g.l.SQLiteAppenderReader] [10:53:03]: Error executing query against logs database. route-group=status, route-path=/logs
INFO   | jvm 1    | 2022/12/05 12:53:03 | java.sql.SQLException: Unable to build a valid query with the parameters provided.
INFO   | jvm 1    | 2022/12/05 12:53:03 | 	at com.inductiveautomation.ignition.gateway.logging.SQLiteAppenderReader.buildPrepStatement(SQLiteAppenderReader.java:129)
INFO   | jvm 1    | 2022/12/05 12:53:03 | 	at com.inductiveautomation.ignition.gateway.logging.SQLiteAppenderReader.query(SQLiteAppenderReader.java:154)
INFO   | jvm 1    | 2022/12/05 12:53:03 | 	at com.inductiveautomation.ignition.gateway.logging.GatewayLoggingManagerImpl.queryLogEvents(GatewayLoggingManagerImpl.java:144)
INFO   | jvm 1    | 2022/12/05 12:53:03 | 	at com.inductiveautomation.ignition.gateway.web.pages.status.routes.LoggingRoutes.getLogs(LoggingRoutes.java:561)
INFO   | jvm 1    | 2022/12/05 12:53:03 | 	at com.inductiveautomation.ignition.gateway.dataroutes.Route.service(Route.java:254)
INFO   | jvm 1    | 2022/12/05 12:53:03 | 	at com.inductiveautomation.ignition.gateway.dataroutes.RouteGroupImpl.service(RouteGroupImpl.java:61)
INFO   | jvm 1    | 2022/12/05 12:53:03 | 	at com.inductiveautomation.ignition.gateway.dataroutes.RouteGroupCollectionServlet.serviceInternal(RouteGroupCollectionServlet.java:59)
INFO   | jvm 1    | 2022/12/05 12:53:03 | 	at com.inductiveautomation.ignition.gateway.dataroutes.AbstractRouteGroupServlet.service(AbstractRouteGroupServlet.java:38)
INFO   | jvm 1    | 2022/12/05 12:53:03 | 	at javax.servlet.http.HttpServlet.service(HttpServlet.java:790)
INFO   | jvm 1    | 2022/12/05 12:53:03 | 	at org.eclipse.jetty.servlet.ServletHolder$NotAsync.service(ServletHolder.java:1450)
INFO   | jvm 1    | 2022/12/05 12:53:03 | 	at org.eclipse.jetty.servlet.ServletHolder.handle(ServletHolder.java:799)
INFO   | jvm 1    | 2022/12/05 12:53:03 | 	at org.eclipse.jetty.servlet.ServletHandler$ChainEnd.doFilter(ServletHandler.java:1631)
INFO   | jvm 1    | 2022/12/05 12:53:03 | 	at org.eclipse.jetty.servlet.ServletHandler.doHandle(ServletHandler.java:548)
INFO   | jvm 1    | 2022/12/05 12:53:03 | 	at org.eclipse.jetty.server.handler.ScopedHandler.handle(ScopedHandler.java:143)
INFO   | jvm 1    | 2022/12/05 12:53:03 | 	at org.eclipse.jetty.security.SecurityHandler.handle(SecurityHandler.java:600)
INFO   | jvm 1    | 2022/12/05 12:53:03 | 	at org.eclipse.jetty.server.handler.HandlerWrapper.handle(HandlerWrapper.java:127)
INFO   | jvm 1    | 2022/12/05 12:53:03 | 	at org.eclipse.jetty.server.handler.ScopedHandler.nextHandle(ScopedHandler.java:235)
INFO   | jvm 1    | 2022/12/05 12:53:03 | 	at org.eclipse.jetty.server.session.SessionHandler.doHandle(SessionHandler.java:1624)
INFO   | jvm 1    | 2022/12/05 12:53:03 | 	at org.eclipse.jetty.server.handler.ScopedHandler.nextHandle(ScopedHandler.java:233)
INFO   | jvm 1    | 2022/12/05 12:53:03 | 	at org.eclipse.jetty.server.handler.ContextHandler.doHandle(ContextHandler.java:1440)
INFO   | jvm 1    | 2022/12/05 12:53:03 | 	at org.eclipse.jetty.server.handler.ScopedHandler.nextScope(ScopedHandler.java:188)
INFO   | jvm 1    | 2022/12/05 12:53:03 | 	at org.eclipse.jetty.servlet.ServletHandler.doScope(ServletHandler.java:501)
INFO   | jvm 1    | 2022/12/05 12:53:03 | 	at org.eclipse.jetty.server.session.SessionHandler.doScope(SessionHandler.java:1594)
INFO   | jvm 1    | 2022/12/05 12:53:03 | 	at org.eclipse.jetty.server.handler.ScopedHandler.nextScope(ScopedHandler.java:186)
INFO   | jvm 1    | 2022/12/05 12:53:03 | 	at org.eclipse.jetty.server.handler.ContextHandler.doScope(ContextHandler.java:1355)
INFO   | jvm 1    | 2022/12/05 12:53:03 | 	at org.eclipse.jetty.server.handler.ScopedHandler.handle(ScopedHandler.java:141)
INFO   | jvm 1    | 2022/12/05 12:53:03 | 	at com.inductiveautomation.catapult.handlers.RemoteHostNameLookupHandler.handle(RemoteHostNameLookupHandler.java:121)
INFO   | jvm 1    | 2022/12/05 12:53:03 | 	at org.eclipse.jetty.rewrite.handler.RewriteHandler.handle(RewriteHandler.java:322)
INFO   | jvm 1    | 2022/12/05 12:53:03 | 	at org.eclipse.jetty.server.handler.HandlerList.handle(HandlerList.java:59)
INFO   | jvm 1    | 2022/12/05 12:53:03 | 	at org.eclipse.jetty.server.handler.HandlerCollection.handle(HandlerCollection.java:146)
INFO   | jvm 1    | 2022/12/05 12:53:03 | 	at org.eclipse.jetty.server.Server.handle(Server.java:516)
INFO   | jvm 1    | 2022/12/05 12:53:03 | 	at org.eclipse.jetty.server.HttpChannel.lambda$handle$1(HttpChannel.java:487)
INFO   | jvm 1    | 2022/12/05 12:53:03 | 	at org.eclipse.jetty.server.HttpChannel.dispatch(HttpChannel.java:732)
INFO   | jvm 1    | 2022/12/05 12:53:03 | 	at org.eclipse.jetty.server.HttpChannel.handle(HttpChannel.java:479)
INFO   | jvm 1    | 2022/12/05 12:53:03 | 	at org.eclipse.jetty.server.HttpConnection.onFillable(HttpConnection.java:277)
INFO   | jvm 1    | 2022/12/05 12:53:03 | 	at org.eclipse.jetty.io.AbstractConnection$ReadCallback.succeeded(AbstractConnection.java:311)
INFO   | jvm 1    | 2022/12/05 12:53:03 | 	at org.eclipse.jetty.io.FillInterest.fillable(FillInterest.java:105)
INFO   | jvm 1    | 2022/12/05 12:53:03 | 	at org.eclipse.jetty.io.ssl.SslConnection$DecryptedEndPoint.onFillable(SslConnection.java:555)
INFO   | jvm 1    | 2022/12/05 12:53:03 | 	at org.eclipse.jetty.io.ssl.SslConnection.onFillable(SslConnection.java:410)
INFO   | jvm 1    | 2022/12/05 12:53:03 | 	at org.eclipse.jetty.io.ssl.SslConnection$2.succeeded(SslConnection.java:164)
INFO   | jvm 1    | 2022/12/05 12:53:03 | 	at org.eclipse.jetty.io.ChannelEndPoint$1.run(ChannelEndPoint.java:104)
INFO   | jvm 1    | 2022/12/05 12:53:03 | 	at org.eclipse.jetty.util.thread.strategy.EatWhatYouKill.runTask(EatWhatYouKill.java:338)
INFO   | jvm 1    | 2022/12/05 12:53:03 | 	at org.eclipse.jetty.util.thread.strategy.EatWhatYouKill.doProduce(EatWhatYouKill.java:315)
INFO   | jvm 1    | 2022/12/05 12:53:03 | 	at org.eclipse.jetty.util.thread.strategy.EatWhatYouKill.tryProduce(EatWhatYouKill.java:173)
INFO   | jvm 1    | 2022/12/05 12:53:03 | 	at org.eclipse.jetty.util.thread.strategy.EatWhatYouKill.run(EatWhatYouKill.java:131)
INFO   | jvm 1    | 2022/12/05 12:53:03 | 	at org.eclipse.jetty.util.thread.ReservedThreadExecutor$ReservedThread.run(ReservedThreadExecutor.java:409)
INFO   | jvm 1    | 2022/12/05 12:53:03 | 	at org.eclipse.jetty.util.thread.QueuedThreadPool.runJob(QueuedThreadPool.java:883)
INFO   | jvm 1    | 2022/12/05 12:53:03 | 	at org.eclipse.jetty.util.thread.QueuedThreadPool$Runner.run(QueuedThreadPool.java:1034)
INFO   | jvm 1    | 2022/12/05 12:53:03 | 	at java.base/java.lang.Thread.run(Unknown Source)
INFO   | jvm 1    | 2022/12/05 12:53:03 | Caused by: org.sqlite.SQLiteException: [SQLITE_BUSY] The database file is locked (database is locked)
INFO   | jvm 1    | 2022/12/05 12:53:03 | 	at org.sqlite.core.DB.newSQLException(DB.java:1141)
INFO   | jvm 1    | 2022/12/05 12:53:03 | 	at org.sqlite.core.DB.newSQLException(DB.java:1152)
INFO   | jvm 1    | 2022/12/05 12:53:03 | 	at org.sqlite.core.DB.throwex(DB.java:1112)
INFO   | jvm 1    | 2022/12/05 12:53:03 | 	at org.sqlite.core.NativeDB.prepare_utf8(Native Method)
INFO   | jvm 1    | 2022/12/05 12:53:03 | 	at org.sqlite.core.NativeDB.prepare(NativeDB.java:117)
INFO   | jvm 1    | 2022/12/05 12:53:03 | 	at org.sqlite.core.DB.prepare(DB.java:267)
INFO   | jvm 1    | 2022/12/05 12:53:03 | 	at org.sqlite.core.CorePreparedStatement.<init>(CorePreparedStatement.java:44)
INFO   | jvm 1    | 2022/12/05 12:53:03 | 	at org.sqlite.jdbc3.JDBC3PreparedStatement.<init>(JDBC3PreparedStatement.java:30)
INFO   | jvm 1    | 2022/12/05 12:53:03 | 	at org.sqlite.jdbc4.JDBC4PreparedStatement.<init>(JDBC4PreparedStatement.java:25)
INFO   | jvm 1    | 2022/12/05 12:53:03 | 	at org.sqlite.jdbc4.JDBC4Connection.prepareStatement(JDBC4Connection.java:34)
INFO   | jvm 1    | 2022/12/05 12:53:03 | 	at org.sqlite.jdbc3.JDBC3Connection.prepareStatement(JDBC3Connection.java:155)
INFO   | jvm 1    | 2022/12/05 12:53:03 | 	at org.sqlite.jdbc3.JDBC3Connection.prepareStatement(JDBC3Connection.java:135)
INFO   | jvm 1    | 2022/12/05 12:53:03 | 	at com.inductiveautomation.ignition.gateway.logging.SQLiteAppenderReader.buildPrepStatement(SQLiteAppenderReader.java:110)
INFO   | jvm 1    | 2022/12/05 12:53:03 | 	... 52 common frames omitted
INFO   | jvm 1    | 2022/12/05 12:53:05 | Cleaned up 500 rows in 5504 ms. Vacuum performed: true*
Now when the log file size is smaller and within boundaries the errors are stopped.
INFO   | jvm 1    | 2022/12/05 13:29:33 | Scheduling logfile maintenance. Last maintenance: Mon Dec 05 13:28:32 EET 2022, events since then: 0
INFO   | jvm 1    | 2022/12/05 13:29:33 | Starting logfile maintenance. Max entries: 50000, Max filesize: 104857600
INFO   | jvm 1    | 2022/12/05 13:29:36 | Cleaned up 500 rows in 2918 ms. Vacuum performed: true*
In the future, don't post the same question in multiple places. You posted this over here first:
Double-posting is against this forum's rules.
