Could someone help me with using and expression tag to convert something like:
91.50 minutes into 01:31:30
Is it even possible??
Not pretty, but it seems to work:
numberFormat(floor({GenericSim/Writeable/WriteableFloat1} / 60),"#0")+":"+numberFormat(60*(({GenericSim/Writeable/WriteableFloat1} / 60)-floor({GenericSim/Writeable/WriteableFloat1} / 60)),â00â)+":" + numberFormat(60*({GenericSim/Writeable/WriteableFloat1} - floor({GenericSim/Writeable/WriteableFloat1})),â00â)
Let me know if you want the parts broken down and explained.
I have a script for it:
def convert(type, input):
import datetime
if type=='min':
return str(datetime.timedelta(minutes=input))
if type=='sec':
return str(datetime.timedelta(seconds=input))
You can either import the attached file into app, or shared scripts if you have 7.7.
Your expression tag becomes
[code]runscript(app.hms.convert(âminâ, value_to_convert))
-OR-
runscript(shared.hms.convert(âminâ, value_to_convert))[/code]
It can also convert seconds:
-OR-
hms.py (181 Bytes)
Thanks Kathy and Jordan, I will give both of them a try.
I tested and worked fine this one: runscript(âshared.hms.convert(âsecâ, 120)â)
BUT when I try to run using a property value like this:
runscript(âshared.hms.convert(âsecâ, {Pozo_ICH_v3.TiempoOFF.intValue})â)
I got the following error message:
Exception: Error executing expression binding on
Pozo_ICH_v3.Pozo_ICH_v3.Label 24.text
caused by ExpressionException: Error parsing script for runScript() expression: SyntaxError: (âmismatched input â}â expecting COLONâ, (âexpression:runScriptâ, 1, 68, â__RESULT = shared.hms.convert(âsecâ, {Pozo_ICH_v3.TiempoOFF.intValue})\nâ))
caused by SyntaxError: ("mismatched input '}' expecting COLON", ('<expression:runScript>', 1, 68, "__RESULT = shared.hms.convert('sec', {Pozo_ICH_v3.TiempoOFF.intValue})\n"))
Ignition v7.9.9 (b2018081621)
Java: Oracle Corporation 1.8.0_144
{Pozo_ICH_v3.TiempoOFF.intValue} ends up as a literal string. Youâll need to concatenate the value into it. Try:
runscript(concat("shared.hms.convert('sec', ", toString({Pozo_ICH_v3.TiempoOFF.intValue}), ")"))
Thank you... works perfect!
You can also use the newer runScript syntax to avoid the tricky/brittle concatentation:
runScript("shared.hms.convert", 0, "sec", {Pozo_ICH_v3.TiempoOFF.intValue})
Better idea... thanks!
IMO, it can just as easily be done without script.
This doesnât work if the hours value can reach more than 24 hours, but apart from that, itâs quite concise and easy to understand IMO.
dateFormat(
addSeconds(
getDate(1970,1,1),
toInt({Root Container.value} * 60)
"HH:mm:ss"
When I wrote it four years ago, not all of those expression functions existed.
We just assumed you could see into the future.
