[feature-13751]Perspective Auto Logout
Does anyone have any suggestions on how to auto-logout users in perspective based on inactivity?
Does system.util.getInactivitySeconds work in perspective? I’m struggling to get it to work and I’m wondering if this functionality isn’t there in perspective.
No, that function doesn’t work in Perspective - we’ll have to add some kind of analogue for it.
Any idea if that is in the works?
I filed an internal ticket, but it hasn’t been triaged for priority yet - no estimates.
Do you know if this has a priority now / is this likely to be implemented?
Medium priority, but hasn’t actually been assigned out to any developers. We’re definitely going to implement something, I just won’t make any guarantee of a timetable.
I would like to reinforce the need for this feature.
Adding my vote for this feature (getInactivitySeconds) for Perspective.
Any update on this topic? is there any workaround available. Thanks.
No workaround, unless you want to implement a custom module; there’s no way in Ignition to run arbitrary code on the browser frontend, which is what you would need to get this.
The feature is currently held up because an inactivity timeout is somewhat at odds with the way identity providers do SSO (single-sign on). For example, if you’re authenticated with Google, and Ignition tries to invalidate your login…Google will just immediately bounce you back, because you’re still signed in. So it might be possible to make something that works with Ignition’s IdP, but that still leaves the feature in a frustrating or misleading state - if you don’t know the ins and outs of identity providers, or you’re using a corporate mandated one, or whatever other complication, then it would just look like the feature isn’t working.
Noted with thanks.
Sorry I may be deviating from this topic, is there any alternate for system.security.validateUser possible in perspective? one of my project requires plant operators to approve gatepass from one common system and I would require them to key in their password on every approval.
I would like to move this project to perspective, Is there any workaround for this?
Paul, I am not sure I understand. If we can detect an inactivity timeout why can’t we just issue a system.perspective.logout command. Most of the users I want to logout are just leaving the browser window open indefinitely and I want to log them out.
My problem up till now has been detecting inactivity accurately.
Have you had any success with auto logging a user out or changing the user to a guest with no permissions?
Is there an update on this topic yet ?
I know this exists in 8.0.16+ under the Project Properties -> Perspective -> Inactivity.
Thank you ! @code_skin
I have the same request, but my client is using 8.0.8 and will not upgrade (they tried upgrading to 8.0.9 and it broke content they were depending on, hence their reluctance). Is there a way to do this in 8.0.8? This is in a 21CFR Part 11 compliant facility and they have to have tight controls as well as lots of transaction logging to include user credentials. If the system cannot auto logout the user on inactivity then they may have issues with inaccurate transaction logging (wrong user ID).
Thoughts, ideas?
An inactivity timeout was added in 8.0.16. Are you asking about something else?
What update are you expecting? It is solved in 8.0.16+. Mike didn’t get an answer for 8.0.8, and I doubt he’ll get one.
