[FEATURE REQUEST] Microphone access
Hello,
I have opened this feature request to allow microphone access requests in the Perspective apps.
Adding support for user-grantable mic access (whether through a native popup or trusted iframe context), would open up powerful use cases for intercoms, voice commands, and other audio-enabled functionality directly in Perspective views.
If you’d like to see this supported, please consider voting for the feature request.
Thanks!
Sounds familiar:
Basically, when we get WebRTC support, the microphone will be part of it.
Is that something that is already planned in an upcoming version? Or do you mean a custom module could handle that?
There are already experimental implementations, IIRC. Search this forum for WebRTC.
I see, though I don't think the implementations will work without the Perspective Workstation and Ignition Perspective apps handling the mic permission requests.
I as able to get mic input from a custom iframe module but this only works on a browser.
On the Workstation app I see errors indicating that there is no handler to request the permissions.
Furthermore, I unpacked the apk and saw the AndroidManifest.xml does not include the lines for the permissions:
    <uses-permission android:name="android.permission.RECORD_AUDIO"/>
    <uses-permission android:name="android.permission.MODIFY_AUDIO_SETTINGS"/>
So until the apps can request the permissions from the OS, the implementation of WebRTC and the like are limited to iframes in the browser.
