They can be custimzed with theme.css
And i bet there is a complex list of selectors that could get this to work. but its mostlikely gonna be more complexe than the one i made for datepicker. While my "sticky canvas" solution isnt all that complicated
damn, Java Docs are well documented. But this? how are you even doing it.
Css magic and inspector
Thank you very much, Zack. Appreciate the information!
Can you please elaborate on how it’s possible in Vision?
I’m searching the forum, but couldn’t find anything…
I’m in need to freeze the first 8 rows in a power table…
Sorry, didn’t realize on your question. Rows? well I’m sure it is posible with rows but it should be. Freezing columns is well known in oracle devs, this was my reference How to freeze row and column in JTable — oracle-tech. I remember I did this with the power table and works just fine. Just translate it to Jython and have fun.
I’ve implemented a working solution using CSS.
As shown in the screenshots, you need to configure the column with position, left, and background-color settings.
Make sure to also add the CSS to the stylesheet.
@Inductive Automation, please update the global stylesheet to include default CSS for sticky classes. This will ensure that using only position: sticky in selection will function as expected.
I don't understand, has this been solved?
This is what i got, only header of first column is stickied:
view's json:
freeze first column.json (37.5 KB)
You need to add the css in the Advanced Style sheet from the post above yours.
i added below on advance stylesheet:
/* The following rules are for Sticky columns in tables */
.tc[style*="position: sticky"] {
z-index: 1 !important;
.ia_table__headerCell[style*="position: sticky"] {
div.flexBodyInnerScrollContainer,
div.ia_table__rowGroup,
div.ia_table__row {
overflow: clip !important;
background-color: #FFFFFF;
Still not working:
Simple steps for sticky columns in Perspective Table:
Select your Table
Go to:
Table.props.columns
Choose the columns you want fixed
Example: SEDE and CONCEPTO.
In the columns transform, add this style to those columns
"style": {
"position": "sticky",
"left": "0px",
"zIndex": 10,
"backgroundColor": "#FFFFFF"
For the second sticky column, increase left
Example if SEDE width is 144px:
"style": {
"left": "144px",
"zIndex": 10,
Make sure both columns have fixed width
"width": 144,
"resizable": False
For headers, also add sticky style inside header.style
"header": {
"title": "SEDE",
"style": {
"left": "0px",
"zIndex": 20,
Important: left must match the total width of previous sticky columns.
You can aply this css properties directly on the script transform
