Gateway is Faulted, Web server is running
While attempting to restore the Inductive university backup, the GCU reported that the Gateway is faulted. I cannot seem to find any indication that is wrong? Any help on this matter would be appreciated. To clarify
Check the wrapper.log, in Program Files/Inductive Automation/Ignition/logs/wrapper.log. If you’re not sure what you’re looking at, feel free to upload the file here.
I am unable to load the file being a new user, however, I believe this is the issue?
Yeah, that’s it. There was something wrong with the gateway backup, so the restore process failed - which left a file hanging around that’s preventing future startup from working. If you delete the ‘restore__disabled.gwbk’ file in Inductive Automation/Ignition/data you should be able to start the system correctly.
Thank you! That seem to have fixed it. Just for future reference, which line exactly indicated this was the issue? I’m looking at the language and I’m not entirely sure?
The key line is the ‘Error during context startup’. Because I can cheat and look at the source code, I can then use the stack trace on the next few lines to know what the system is trying to do at that time, and figure out what went wrong. Mostly this is just a piece of institutional knowledge, though - anyone in our support department would also have been able to help out. It is a fairly cryptic error on the scale of things, though, which we try to avoid; it’ll get reworked at some point in the future.
Mine has done the same thing as above.
Yours is a different underlying error. You need to update your MySQL JDBC driver.
The problem I’m having is that the gateway doesn’t start. Just the web server, the gateway attempted to start but it goes to faulted and then stopped state or just tries to start and then it stops.
I started “Anydesk” application and the running Ignition application- Vision Client crashed. I tried re-installing Java, Ignition, Designer, Vision client but nothing helped to restore the system.
Uploading the wrapper.log file. Kindly guide, how to restore the Ignition Gateway, Designer & Vision Client.
I've looked into config.idb but it was empty, and I later found the log file saying sqlite error, however, I don't recall installing any sqlite with my ignition.
Ignition comes with a sqlite database (.../data/config.idb) which stores a lot of its config (tags, gw config, etc.). Looks like yours might be corrupted or missing? It says it can't find table SRFEATURES. Not sure what data this table holds, but i'd first check if your config.idb database file exists.
What's changed for your project to have this occur?
config.idb does exist but contains zero bytes.
I didn't modify my project and this issue occurred when I attempted accessing gateway this morning.
Something must have corrupted it.. Was there a power outage or something? Do you have a backup? check in the auto backup folder in the data folder for auto backups you might be able to replace the zero byte one with.
If this has happened though, then it potentially doesn't just affect the idb file so a gateway restore might be your best option. Hopefully you setup automatic scheduled regular backups from the gateway web portal.
