Generate QR Codes from Ignition
This python library (or something similar) should be included in Ignition:
https://launchpad.net/qr-tools/+milestone/python-qrtools-1.0
This way QR codes could be dynamically generated for scanning. You could build QR codes out of tags or database queries without needing access to the internet for locked down systems. How cool would that be for a palletizing or sortation system?
Using our Module SDK, a module that adds scripting functions for working with/generating QR codes could be added fairly easily…
I believe there are already a couple of people (maybe just one…) using modules to add custom scripting functions.
Here you go…
Adds a QR Code component to the Display palette.
QRCode-module-signed.modl (125 KB)
Wow, that’s awesome! Thank you!
See here for updates
http://www.inductiveautomation.com/forum/viewtopic.php?f=81&t=6785
Wow. A+
Hello Everyone,
I Installed this module and it says “Faulted Required Major Version Mismatch”. Is there another file that I need to install before this?
Did you follow the instructions in this post/comment?
This post is a decade old. What Ignition version are you using, and where do you want to display a QR code?
There’s native support in Vision, Perspective and Reporting now.
