Get Remote Tag Provider Info via Script
Any Change to get Remote Gateway Information via script
From Image I would like to get both Gateway and Provider
I’m afraid that I have to query internaldb
I think you're right.
I haven’t done something like that yet. Any example you can provide please!
The correct classes to use maybe :expressionless:
Cant import com.inductiveautomation.gateway.tags. I think that is the module I need, right?
com.inductiveautomation.ignition.common.script.JythonExecException
  File "<function:runAction>", line 4, in runAction
ImportError: No module named gateway
	caused by org.python.core.PyException
This may help
This is looking better, almost there.
After that, how do you collect results from session?
Not sure sorry, no personal experience. Pinging @nminchin
session.rawQueryMaps will return a dataset
Ohh True, I did not notice it.
Do you know how to import Subclasses?
Do you mean like:
from library.thing import sub-thing
Can you import this one? :open_mouth:
RemoteHistorianSettingsRecord (inductiveautomation.com)
Should be able to use:
from com.inductiveautomation.gateway.tags.history.distributed.client import RemoteHistorianSettingsRecord
You’ll need to know how to actually use it though… which is the hard/impossible part without IA’s proper documentation / help from IA guys/gals
That’s the thing. Some classes are not importable because a lack of module name.
But those non importable are subclasses of importable classes.
Take a look to the one I sent, its super is com…PersistentRecord, which is importable.
Yeah, I still fumble my way around the javadocs with a fairly low hit-rate until I get help from the forum from the IA guys. It feels more like stabbing in the dark in space trying to hit pluto, until you get help
  File "<function:runAction>", line 3, in runAction
Like that haha
haha agree. Ok I’ll take the one from the other post. Thanks
just FYI, you can only get the gateway context (IgnitionGateway) from the gateway scope (so you can’t run this in a Vision client)
Oh yeah, already knew that. Thanks
Also note that not all gateway classes are exposed to scripting at all. Specifically, classes supplied by modules instead of the platform. Module classes are only accessible via deliberate scripting support from the module, or rather intricate reflection techniques.
HI!
Does anyone know if there is an easier way to get this info (now that we are 5 years later)?
I need to read the gateway name from the remote tag provider so I can properly use the historian module (historian module needs system name, provider and full path).
Thanks!
