GOOD_OVERLOAD, should I ignore it?
Hi!
I'm getting every 2min or something like that a read that is GOOD_OVERLOAD.
If this quality is "good", am I ok ignoring it?
I'm not sure what consecuence would have not taking into account those types of (good) quality.
Thx in advance!
You might try slowing down your polling rate. Or ignore. However, i believe if the tag quality, even with the same value, changes, then a tag change event will occur if you have any configured and extra entries into Historian can occur.
Your source OPC server is telling you that it isn't keeping up with the workload you've given it. It definitely should not be ignored.
The ignored suggestion comes from IA.
It isn't IA's problem. It is a problem to be addressed by you or the provider of OPC server. If neither is possible, then that's all that IA can offer for advice.
