Hi all,
Does anyone have any experience using the GradleUp Shadow plugin in combination with the IA Gradle plugin? Recently, I discovered that one of our modules is running into the following error on 8.1.47:
BasicExecutionEngine 05May2025 15:41:00 One-shot task com.inductiveautomation.ignition.gateway.redundancy.RedundancyManagerImpl$ExecuteTask@4d8e047a threw uncaught exception.
java.lang.IllegalAccessError: class io.netty.buffer.UnsafeDirectLittleEndian cannot access its superclass io.netty.buffer.WrappedByteBuf (io.netty.buffer.UnsafeDirectLittleEndian is in unnamed module of loader com.inductiveautomation.ignition.gateway.modules.ModuleClassLoader @4ca563c0; io.netty.buffer.WrappedByteBuf is in unnamed module of loader 'app')
at java.base/java.lang.ClassLoader.defineClass1(Native Method)
at java.base/java.lang.ClassLoader.defineClass(Unknown Source)
at java.base/java.security.SecureClassLoader.defineClass(Unknown Source)
at java.base/java.net.URLClassLoader.defineClass(Unknown Source)
at java.base/java.net.URLClassLoader$1.run(Unknown Source)
at java.base/java.security.AccessController.doPrivileged(Unknown Source)
at java.base/java.net.URLClassLoader.findClass(Unknown Source)
at com.inductiveautomation.ignition.gateway.modules.ModuleClassLoader.findClass(ModuleClassLoader.java:37)
at com.inductiveautomation.ignition.gateway.modules.ModuleClassLoader.loadClass(ModuleClassLoader.java:104)
at java.base/java.lang.ClassLoader.loadClass(Unknown Source)
at io.netty.buffer.PooledByteBufAllocatorL.(PooledByteBufAllocatorL.java:49)
at org.apache.arrow.memory.NettyAllocationManager.(NettyAllocationManager.java:51)
at org.apache.arrow.memory.DefaultAllocationManagerFactory.(DefaultAllocationManagerFactory.java:26)
at java.base/java.lang.Class.forName0(Native Method)
at java.base/java.lang.Class.forName(Unknown Source)
at org.apache.arrow.memory.DefaultAllocationManagerOption.getFactory(DefaultAllocationManagerOption.java:108)
at org.apache.arrow.memory.DefaultAllocationManagerOption.getDefaultAllocationManagerFactory(DefaultAllocationManagerOption.java:98)
at org.apache.arrow.memory.BaseAllocator$Config.getAllocationManagerFactory(BaseAllocator.java:773)
at org.apache.arrow.memory.ImmutableConfig.access$801(ImmutableConfig.java:24)
at org.apache.arrow.memory.ImmutableConfig$InitShim.getAllocationManagerFactory(ImmutableConfig.java:83)
at org.apache.arrow.memory.ImmutableConfig.(ImmutableConfig.java:47)
at org.apache.arrow.memory.ImmutableConfig.(ImmutableConfig.java:24)
at org.apache.arrow.memory.ImmutableConfig$Builder.build(ImmutableConfig.java:485)
at org.apache.arrow.memory.BaseAllocator.(BaseAllocator.java:62)
I suspect this has something to do with the fact that the library we're using has transitive dependencies for io.netty. These packages were recently added to 8.1.47, and I think it's causing the issue I'm seeing now.
One of the things I've tried was using exclude on the modlImplementation configuration. The module that compiled didn't include the netty jars, but I still ran into the same issue as before. I found a post (Module class loading) referring to a similar problem, but I didn't see a solution. I've been trying to apply the shadowJar task to our project but haven't had any luck.
