Hello all
Ive started the journey into module development and im currently facing the following issue. My module is using the AWS sdk and ive included the following in my build.gradle.kts gateway scope:
modlApi(platform("software.amazon.awssdk:bom:2.29.47"))
modlApi("software.amazon.awssdk:sdk-core")
modlApi("software.amazon.awssdk:auth")
modlApi("software.amazon.awssdk:aws-core")
modlApi("software.amazon.awssdk:s3")
When running some of the functions from a button event script im encountering an error:
NoSuchFieldError: java.lang.NoSuchFieldError:AUTH_SCHEME_PROVIDER
I added some additional logging to my gateway module hook to identify where the classes are being loaded from and found the following
| GatewayHook | 11Jan2025 20:02:54 | Successfully loaded: software.amazon.awssdk.services.s3.S3Client from file:/usr/local/ignition/data/jar-cache/com.inductiveautomation.ignition.examples.scripting.ScriptingFunctionG/__957923360__s3-2.29.47.jar |
| GatewayHook | 11Jan2025 20:02:54 | Successfully loaded: software.amazon.awssdk.core.SdkClient from file:/usr/local/ignition/lib/core/gateway/sdk-core-2.20.7.jar |
| GatewayHook | 11Jan2025 20:02:54 | Successfully loaded: software.amazon.awssdk.auth.credentials.DefaultCredentialsProvider from file:/usr/local/ignition/data/jar-cache/com.inductiveautomation.ignition.examples.scripting.ScriptingFunctionG/__957923360__auth-2.29.47.jar |
It appears that classes in software.amazon.awssdk.core are being loaded from lib/core/gateway/sdk-core which is the igntion sdk core. I suspect this a name clash between the aws sdk-core jar and igntion sdk-core jar. Is there a way to fix this issue. Ive included my module.xml file for reference
Summary
<?xml version="1.0" encoding="UTF-8"?>
<modules>
<module>
<name>Scripting Function G</name>
<id>com.inductiveautomation.ignition.examples.scripting.ScriptingFunctionG</id>
<version>0.0.1-SNAPSHOT</version>
<description>A short sentence describing what it does, but not much longer than this.</description>
<requiredIgnitionVersion>8.1.11</requiredIgnitionVersion>
<freeModule>false</freeModule>
<hook scope="G">com.inductiveautomation.ignition.examples.scripting.gateway.GatewayHook</hook>
<hook scope="C">com.inductiveautomation.ignition.examples.scripting.client.ClientHook</hook>
<hook scope="D">com.inductiveautomation.ignition.examples.scripting.designer.DesignerHook</hook>
<requiredFrameworkVersion>8</requiredFrameworkVersion>
<jar scope="CD">client-0.0.1-SNAPSHOT.jar</jar>
<jar scope="CDG">common-0.0.1-SNAPSHOT.jar</jar>
<jar scope="D">designer-0.0.1-SNAPSHOT.jar</jar>
<jar scope="G">s3-2.29.47.jar</jar>
<jar scope="G">aws-xml-protocol-2.29.47.jar</jar>
<jar scope="G">aws-query-protocol-2.29.47.jar</jar>
<jar scope="G">protocol-core-2.29.47.jar</jar>
<jar scope="G">arns-2.29.47.jar</jar>
<jar scope="G">aws-core-2.29.47.jar</jar>
<jar scope="G">auth-2.29.47.jar</jar>
<jar scope="G">regions-2.29.47.jar</jar>
<jar scope="G">sdk-core-2.29.47.jar</jar>
<jar scope="G">profiles-2.29.47.jar</jar>
<jar scope="G">crt-core-2.29.47.jar</jar>
<jar scope="G">http-auth-2.29.47.jar</jar>
<jar scope="G">http-auth-aws-2.29.47.jar</jar>
<jar scope="G">http-auth-spi-2.29.47.jar</jar>
<jar scope="G">identity-spi-2.29.47.jar</jar>
<jar scope="G">checksums-2.29.47.jar</jar>
<jar scope="G">checksums-spi-2.29.47.jar</jar>
<jar scope="G">retries-2.29.47.jar</jar>
<jar scope="G">retries-spi-2.29.47.jar</jar>
<jar scope="G">apache-client-2.29.47.jar</jar>
<jar scope="G">netty-nio-client-2.29.47.jar</jar>
<jar scope="G">http-client-spi-2.29.47.jar</jar>
<jar scope="G">metrics-spi-2.29.47.jar</jar>
<jar scope="G">json-utils-2.29.47.jar</jar>
<jar scope="G">utils-2.29.47.jar</jar>
<jar scope="G">endpoints-spi-2.29.47.jar</jar>
<jar scope="G">http-auth-aws-eventstream-2.29.47.jar</jar>
<jar scope="G">annotations-2.29.47.jar</jar>
<jar scope="G">reactive-streams-1.0.4.jar</jar>
<jar scope="G">slf4j-api-1.7.36.jar</jar>
<jar scope="G">eventstream-1.0.1.jar</jar>
<jar scope="G">third-party-jackson-core-2.29.47.jar</jar>
<jar scope="G">httpclient-4.5.13.jar</jar>
<jar scope="G">httpcore-4.4.16.jar</jar>
<jar scope="G">commons-codec-1.17.1.jar</jar>
<jar scope="G">netty-codec-http2-4.1.115.Final.jar</jar>
<jar scope="G">netty-codec-http-4.1.115.Final.jar</jar>
<jar scope="G">netty-handler-4.1.115.Final.jar</jar>
<jar scope="G">netty-codec-4.1.115.Final.jar</jar>
<jar scope="G">netty-transport-classes-epoll-4.1.115.Final.jar</jar>
<jar scope="G">netty-transport-native-unix-common-4.1.115.Final.jar</jar>
<jar scope="G">netty-transport-4.1.115.Final.jar</jar>
<jar scope="G">netty-buffer-4.1.115.Final.jar</jar>
<jar scope="G">netty-resolver-4.1.115.Final.jar</jar>
<jar scope="G">netty-common-4.1.115.Final.jar</jar>
<jar scope="G">commons-logging-1.2.jar</jar>
<jar scope="G">gateway-0.0.1-SNAPSHOT.jar</jar>
</module>
</modules>
