While using Designer in Ignition v8.1.13 and v8.1.14 I am running into a recurring “TimeoutException” error. Once the first error pops up I can’t get anything to show in the main editor panel of Designer and almost any subsequent action causes the error pop-up to display again after a delay (including attempts to save or exit). If I restart designer the issue goes away for a while but will come back again, when its least convenient, of course.
I have the Ignition Demo VM running (v8.1.13) as I am using it for reference/ideas and I have Ignition v8.1.14 running as a Linode (Ubuntu 20.04). I am accessing both “remotely” using designer launcher from my Windows laptop.
I suspect (but don’t know) if the problem would go away if I used designer directly on the Ignition server but this is a development setup for what will be a headless server (no graphical desktop).
It’s happening often enough to me that I expect it might be a common problem. Any suggestion on configuration settings that might reduce or eliminate the issue? For example should I be increasing a timeout delay somewhere?
There are older threads reporting similar issues with older versions of Ignition, those do not appear to have been resolved positively.
https://forum.inductiveautomation.com/t/unknown-designer-timeout-exception/27274
Here is a dump of error details from the instance running the Ignition Demo VM (v8.1.13):
java.util.concurrent.TimeoutException
at java.base/java.util.concurrent.CompletableFuture.timedGet(Unknown Source)
at java.base/java.util.concurrent.CompletableFuture.get(Unknown Source)
at com.inductiveautomation.perspective.designer.workspace.ViewResourceEditor.getObjectForSave(ViewResourceEditor.java:487)
at com.inductiveautomation.perspective.designer.workspace.ViewResourceEditor.getObjectForSave(ViewResourceEditor.java:68)
at com.inductiveautomation.ignition.designer.tabbedworkspace.ResourceEditor.commit(ResourceEditor.java:166)
at com.inductiveautomation.perspective.designer.workspace.ViewResourceEditor.notifyDeactivated(ViewResourceEditor.java:594)
at com.inductiveautomation.perspective.designer.workspace.PerspectiveWorkspaceListener.editorSelected(PerspectiveWorkspaceListener.java:73)
at com.inductiveautomation.ignition.designer.tabbedworkspace.TabbedResourceWorkspace$3.stateChanged(TabbedResourceWorkspace.java:115)
at java.desktop/javax.swing.DefaultSingleSelectionModel.fireStateChanged(Unknown Source)
at com.jidesoft.swing.JideTabbedPane$IgnoreableSingleSelectionModel.fireStateChanged(Unknown Source)
at java.desktop/javax.swing.DefaultSingleSelectionModel.setSelectedIndex(Unknown Source)
at java.desktop/javax.swing.JTabbedPane.setSelectedIndexImpl(Unknown Source)
at java.desktop/javax.swing.JTabbedPane.setSelectedIndex(Unknown Source)
at com.jidesoft.swing.JideTabbedPane.setSelectedIndex(Unknown Source)
at com.jidesoft.plaf.basic.BasicJideTabbedPaneUI$MouseHandler.mousePressed(Unknown Source)
at java.desktop/java.awt.AWTEventMulticaster.mousePressed(Unknown Source)
at com.jidesoft.docking.DockingUtils.a(Unknown Source)
at com.jidesoft.docking.DefaultDockingManager.handleEvent(Unknown Source)
at com.jidesoft.docking.DefaultDockingManager$56.eventDispatched(Unknown Source)
at java.desktop/java.awt.Toolkit$SelectiveAWTEventListener.eventDispatched(Unknown Source)
at java.desktop/java.awt.Toolkit$ToolkitEventMulticaster.eventDispatched(Unknown Source)
at java.desktop/java.awt.Toolkit.notifyAWTEventListeners(Unknown Source)
at java.desktop/java.awt.KeyboardFocusManager.redispatchEvent(Unknown Source)
at java.desktop/java.awt.DefaultKeyboardFocusManager.typeAheadAssertions(Unknown Source)
at java.desktop/java.awt.DefaultKeyboardFocusManager.dispatchEvent(Unknown Source)
at java.desktop/java.awt.KeyboardFocusManager.dispatchAndCatchException(Unknown Source)
at java.desktop/java.awt.KeyboardFocusManager.processCurrentLightweightRequests(Unknown Source)
at java.desktop/java.awt.KeyboardFocusManager$4.run(Unknown Source)
Ignition v8.1.13 (b2021122109)
Java: Azul Systems, Inc. 11.0.13
