How to remove sample tags provider from Power Chart "Browse Tags" tree?
I don’t want to show sample tags in Power Chart. Please tell me how to do that.
The Perspective Power Chart does not have sample tags. When the component is added to a view there are no tags and so there are no pens.
Can you be more clear about what problem you are trying to solve? Add a nicely sized and cropped screen grab.
I believe that they are talking about the Sample_Tags Provider ( I think it is installed with a fresh install of V8).
Something similar here:
I just set the props.config.tagBrowserStartPath with the correct path, but I also only have 1 historical provider.
@lrose, that’s probably it. I’ve never seen it.
I’ve edited the question title to something more appropriate.
To be entirely clear - if you choose (on a brand new installation) the 'Quick Start' feature, it'll create a sample project, tag provider, SQLite connection, etc.
If you don't want that anymore, you can delete it. If you are still using the SQLite connection but just want to remove the sample provider's history, you'll have to clean up the tag historian tables yourself.
I would recommend against running a production system using SQLite to store tag history data; this might be a good chance to make a clean break and migrate to a proper RDBMS (ideally, on a different VM or physical host) if you're using SQLite to store history data.
Chart
Hello Everyone,
Thanks for the reply.
Please see the attached screenshot. Actually I wanted to remove this “realistics” tags from Chart.
Those tags came with Sample tags.
Have you found an answer for this. I am wanting to do something similar.
As @lrose said:
Copied from:
tagBrowserStartPath: A path to a nested Tag History provider structure from which browsing will start. The path is expected to contain key-value pairs separated by ":/" characters. Value is string.Example:
histprov:Sample_SQLite_Database:/drv:My_Gateway:My_Tag_Provider:/tag:My_Folder/Another_Folder.
    • histprov: The name of the Tag Historian Provider.
    • drv: The historian driver, which is typically a combination of a Gateway name and Tag Provider name separated by a colon. Example: gateway:tagProvider
    • tag: A path to a node that has children. Typically should lead to either a folder or the root node of a UDT instance. If omitted, then the path will lead to the root of the drv.
      While providing a path to this property, the tag component can be omitted, which will set the starting path for the Tag Browser panel to the root of a particular driver. For example, histprov:Sample_SQLite_Database:/drv:My_Gateway:My_Tag_Provider:/.
Or better, remove that tag provider altogether, along with the historic tables for it
