Is there a way to see where a memory tag is getting its value from?
Do you have auditing enabled?
https://docs.inductiveautomation.com/display/DOC81/Audit+Log+and+Profiles
You can also search the project for the tag name to see if it exists on any pages and then check those pages over to see if there's any tag writes / bidirectional bindings to your memory tag
I do not have auditing setup. I guess that is the best way to see that information? Seems like it should be available when you edit the tag under the diagnostics. Would be a nice feature.
As far as I know, auditing is the easiest method, unless you wish to do manual searches.
Not sure if this is for vision, or perspective. But Perspective since 8.1.22 has a handy tool to inspect a view configuration that might help (if using perspective)
