How to use the source filter of Alarm Status Table in the popup window
I build several different sensors in the main window, and they could be clicked to open a popup window.
I want each popup window could show the alarms form the selected sensor. I use the source filter to filt the Alarm Status Table.
I have tried Sensor{Root Container.SensorNumber} or indirect tag Sensor{1} {1} = Root Container.SensorNumber
All incorrect.
Is there anyone could give me some advise?
Youll need to put wildcards (*) around your tag path filter, and, depending on version you’re running, you might also need some other stuff at the start as well. See this post system.alarm.queryStatus broken in 7.9.5? - #3 by nminchin
