All Time series chart is default with one x axes and Y axes but for me botton legend for 5 bars is the name of the downtime event and Y axes should represent the duration in min. How to do this in ignition
Welcome to the forums!
I am going to assume perspective but please put tags in your post so you can be better assisted.
Perspective Route:
You are saying time series chart, but I imagine with downtime you will want to display in either a bar chart or in a pie chart.
Below is an example of a state chart I have. This is using Musson Industrial’s Embr-Charts Module but I am just giving as an example.
Are one of these types of charts what you are expecting to see?
It may also be worth giving an example of your data so we can provide better examples and ideas to you.
Hi Benjamin,
Yes, I am planning to work with Perspective and OEE module is built on top of it. where i am trying to display the Top 5 downtime reasons in a day. like for example in a day many downtimes can happened to the respective machines in that Top 5 downtime reasons alone i want to update in the Dashboard.like how you plot the bar graph in response. Y axes should represent the name of downtime reason and x axes should be the duration of that downtime. exactly same as in the response plot
