I can 't connect the database to ignition
I am using the demo version to validate the communication of a new PLC with this SCADA software. But I am having trouble connecting a database to Ignition that stores historical data from a PLC. I have followed all the instructions in the manual at this link:
https://docs.inductiveautomation.com/display/DOC80/Connecting+to+Microsoft+SQL+Server+Express#ConnectingtoMicrosoftSQLServerExpress-DifferentWaysofConnectingtoSQLServer
But I have not been successful. Constantly the status of the connection is trying to connect but it always ends in error and displays the following error message:
Cannot create PoolableConnectionFactory (Failed to make TCP / IP connection to host localhost, port 1433. Error:
"Connection timed out: no more information … Check connection properties, check
that there is an instance of SQL Server running on the host and accepting TCP / IP connections on the port and check that it is not
There is no firewall blocking TCP connections on the port. ".)
I hope someone can support me.
Welcome!
hope this helps!
I had the same problem for a while and then I fixed it based on these links. I also created a new login user for only that database so that I can use it with Ignition only (I put the link below).
If you did everything that the manual said, my recommendation is to create a new login.
https://support.inductiveautomation.com/hc/en-us/articles/360047131512-Microsoft-SQL-Server-MSSQL-Connection-Guide-for-Ignition
Matrix_ Engineering.
Thanks for your support.!
pkhoshroo…
I fix my problem creating a new loggin to connect Ignition.
:grinning:
Awsome! Glad you could fix it :slight_smile:
