Icon rotation in Ignition Perspective
I was trying to rotate the icon [material/autorenew] in forward direction continuously until my motor value becomes zero.
I was tried the value change script with loop functions, but it's rotating even after the value becomes zero. loop function not breaking.
val = currentValue.value
while   val  > 0:
	for degree in range (0, 361, 10):
		self.getSibling("Icon").props.style.transform =  "rotate(" + str(degree) + "deg)"
		if val == 0:
			break
	if val == 0 :
		break
any suggestions please let me know
or any alternate way to show the running indication with icon please post it here.
Thanks in advance.
Dayaraju
Use an SVG version of the icon and use CSS animation to implement the rotation animation.
A reference thread:
Scripts run on the gateway and that means that your animation would require continuous updates from the the gateway to the browser. This won't work well. In addition, open-ended while loops are not a good idea.
Instead use CSS animation which is all handled by the browser. On your icon style properties add style.animation. Create an expression binding on the new style,
if({../tagMotorRunning},
    "spin 2s linear infinite",
This has the small problem that the animation snaps back to 0° when the motor stops. Someone may have a fix for that.
Thanks, its working and that too one line of code :+1:
