Ignition 7.9.2 Upgrade
I have a gateway that is 7.9.2. (continuation from my last topic)
I am having an issue launching the jnlp because of the expired cert.
I've tried adding the gateway's IP to the Java security exception list but the application still fails to execute (java.security.cert.CertificateException: java.security.cert.CertPathValidatorException: OCSP response error: MALFORMED_REQUEST )
I found another post that mentioned upgrading to the latest version of 7.9.
So, the next question: is that upgrade free if I have a 7.9.2 license? If yes, that's because it's a minor revision?
Yeah, you can upgrade to 7.9.21 or whatever the last release was, for free.
FWIW, I think this is probably something on the network you're on interfering.
But you'd be better off in the long term upgrading and then using the native client launcher instead.
