I have a dropdown menu that is populated with alarm pipeline names using a script. When the operator selects a pipeline from the list I write this string to a memory tag inside a UDT. Problem is that for some reason the string value from the dropdown comes into the tag with quotation marks around it. When a alarm triggers, because of the quotes, the alarm doesn’t know what pipeline to use. When I first created this widget it worked perfectly. I recently upgraded the server top 8.15. Now I get quotes? Any help to understand this would be greatly appreciated
I think this is a known bug:
