Ignition Designer Starts Late
Are these workstations isolated from the internet? If so, you may need to disable certificate revocation checking.
Just to add to the mix here, I am not seeing any slowdown when running Designer from a Linux client. My Windows client however does take several minutes to start Designer, so I am guessing something specific to Windows. Anyone with a Mac having issues?
We are also having issues with designers getting stuck loading "Starting module: perspective" for several minutes.
Vision clients also get stuck "Starting..." for several minutes after login.
These problems have been intermittent for us; Sometimes opening immediately, sometimes taking 3-10 minutes.
This is effecting connections to our central gateway and all of our edge machines. (Both local and remote connections are effected)
Perspective sessions do not seem effected.
(running on Windows systems)
I am observing Windows Defender (Antimalware Service Executable) CPU activity greater than 90% during Designer project launches. Potentially a Windows Defender policy update causing this behavior?
I was just testing this on a VM. I think I was able to replicate this by triggering a targeted Windows Defender scan on the jxbrowser directory in the .ignition cache when Perspective starts to initialize.
Edit: The scan completed but it seems to have still stalled Perspective from loading (finished after 4 minutes). I didn't see any load times greater than 20 seconds until running the scan even with a painfully slow VM
Alright, it looks like this was confirmed to be related to the packaged Chromium browser extraction for the Designer due to some change in Windows Defender.
Yes, it was the solution for me and it opened very quickly. Thanks for your help. :slight_smile:
