I installed the batch procedure module. The status says “New” (Neither faulted nor running ). Tried to restart the module but it goes into error. Any solution to this?
Log from Wrapper below
INFO   | jvm 1    | 2022/04/20 09:27:14 | I [g.ModuleManager               ] [03:57:14]: Restarting module “batchgateway”
INFO   | jvm 1    | 2022/04/20 09:27:14 | W [g.ModuleManager               ] [03:57:14]: Module “batchgateway” depends on “xopc”, but it doesn’t exist.
INFO   | jvm 1    | 2022/04/20 09:27:14 | E [o.a.w.DefaultExceptionMapper  ] [03:57:14]: Unexpected error occurred
INFO   | jvm 1    | 2022/04/20 09:27:14 | org.apache.wicket.WicketRuntimeException: Method onLinkClicked of interface org.apache.wicket.markup.html.link.ILinkListener targeted at [Link [Component id = confirm]] on component [Link [Component id = confirm]] threw an exception
INFO   | jvm 1    | 2022/04/20 09:27:14 | 	at org.apache.wicket.RequestListenerInterface.internalInvoke(RequestListenerInterface.java:268)
INFO   | jvm 1    | 2022/04/20 09:27:14 | 	at org.apache.wicket.RequestListenerInterface.invoke(RequestListenerInterface.java:216)
INFO   | jvm 1    | 2022/04/20 09:27:14 | 	at org.apache.wicket.core.request.handler.ListenerInterfaceRequestHandler.invokeListener(ListenerInterfaceRequestHandler.java:243)
INFO   | jvm 1    | 2022/04/20 09:27:14 | 	at org.apache.wicket.core.request.handler.ListenerInterfaceRequestHandler.respond(ListenerInterfaceRequestHandler.java:236)
INFO   | jvm 1    | 2022/04/20 09:27:14 | 	at org.apache.wicket.request.cycle.RequestCycle$HandlerExecutor.respond(RequestCycle.java:890)
INFO   | jvm 1    | 2022/04/20 09:27:14 | 	at org.apache.wicket.request.RequestHandlerStack.execute(RequestHandlerStack.java:64)
INFO   | jvm 1    | 2022/04/20 09:27:14 | 	at org.apache.wicket.request.cycle.RequestCycle.execute(RequestCycle.java:261)
INFO   | jvm 1    | 2022/04/20 09:27:14 | 	at org.apache.wicket.request.cycle.RequestCycle.processRequest(RequestCycle.java:218)
INFO   | jvm 1    | 2022/04/20 09:27:14 | 	at org.apache.wicket.request.cycle.RequestCycle.processRequestAndDetach(RequestCycle.java:289)
INFO   | jvm 1    | 2022/04/20 09:27:14 | 	at org.apache.wicket.protocol.http.WicketFilter.processRequestCycle(WicketFilter.java:259)
INFO   | jvm 1    | 2022/04/20 09:27:14 | 	at org.apache.wicket.protocol.http.WicketFilter.processRequest(WicketFilter.java:201)
INFO   | jvm 1    | 2022/04/20 09:27:14 | 	at org.apache.wicket.protocol.http.WicketFilter.doFilter(WicketFilter.java:282)
INFO   | jvm 1    | 2022/04/20 09:27:14 | 	at org.eclipse.jetty.servlet.FilterHolder.doFilter(FilterHolder.java:201)
INFO   | jvm 1    | 2022/04/20 09:27:14 | 	at org.eclipse.jetty.servlet.ServletHandler$Chain.doFilter(ServletHandler.java:1601)
INFO   | jvm 1    | 2022/04/20 09:27:14 | 	at org.eclipse.jetty.servlet.ServletHandler.doHandle(ServletHandler.java:548)
INFO   | jvm 1    | 2022/04/20 09:27:14 | 	at org.eclipse.jetty.server.handler.ScopedHandler.handle(ScopedHandler.java:143)
INFO   | jvm 1    | 2022/04/20 09:27:14 | 	at org.eclipse.jetty.security.SecurityHandler.handle(SecurityHandler.java:600)
INFO   | jvm 1    | 2022/04/20 09:27:14 | 	at org.eclipse.jetty.server.handler.HandlerWrapper.handle(HandlerWrapper.java:127)
INFO   | jvm 1    | 2022/04/20 09:27:14 | 	at org.eclipse.jetty.server.handler.ScopedHandler.nextHandle(ScopedHandler.java:235)
INFO   | jvm 1    | 2022/04/20 09:27:14 | 	at org.eclipse.jetty.server.session.SessionHandler.doHandle(SessionHandler.java:1624)
INFO   | jvm 1    | 2022/04/20 09:27:14 | 	at org.eclipse.jetty.server.handler.ScopedHandler.nextHandle(ScopedHandler.java:233)
INFO   | jvm 1    | 2022/04/20 09:27:14 | 	at org.eclipse.jetty.server.handler.ContextHandler.doHandle(ContextHandler.java:1440)
INFO   | jvm 1    | 2022/04/20 09:27:14 | 	at org.eclipse.jetty.server.handler.ScopedHandler.nextScope(ScopedHandler.java:188)
INFO   | jvm 1    | 2022/04/20 09:27:14 | 	at org.eclipse.jetty.servlet.ServletHandler.doScope(ServletHandler.java:501)
INFO   | jvm 1    | 2022/04/20 09:27:14 | 	at org.eclipse.jetty.server.session.SessionHandler.doScope(SessionHandler.java:1594)
INFO   | jvm 1    | 2022/04/20 09:27:14 | 	at org.eclipse.jetty.server.handler.ScopedHandler.nextScope(ScopedHandler.java:186)
INFO   | jvm 1    | 2022/04/20 09:27:14 | 	at org.eclipse.jetty.server.handler.ContextHandler.doScope(ContextHandler.java:1355)
INFO   | jvm 1    | 2022/04/20 09:27:14 | 	at org.eclipse.jetty.server.handler.ScopedHandler.handle(ScopedHandler.java:141)
INFO   | jvm 1    | 2022/04/20 09:27:14 | 	at com.inductiveautomation.catapult.handlers.RemoteHostNameLookupHandler.handle(RemoteHostNameLookupHandler.java:121)
INFO   | jvm 1    | 2022/04/20 09:27:14 | 	at org.eclipse.jetty.rewrite.handler.RewriteHandler.handle(RewriteHandler.java:322)
INFO   | jvm 1    | 2022/04/20 09:27:14 | 	at org.eclipse.jetty.server.handler.HandlerList.handle(HandlerList.java:59)
INFO   | jvm 1    | 2022/04/20 09:27:14 | 	at org.eclipse.jetty.server.handler.HandlerCollection.handle(HandlerCollection.java:146)
INFO   | jvm 1    | 2022/04/20 09:27:14 | 	at org.eclipse.jetty.server.Server.handle(Server.java:516)
INFO   | jvm 1    | 2022/04/20 09:27:14 | 	at org.eclipse.jetty.server.HttpChannel.lambda$handle$1(HttpChannel.java:487)
INFO   | jvm 1    | 2022/04/20 09:27:14 | 	at org.eclipse.jetty.server.HttpChannel.dispatch(HttpChannel.java:732)
INFO   | jvm 1    | 2022/04/20 09:27:14 | 	at org.eclipse.jetty.server.HttpChannel.handle(HttpChannel.java:479)
INFO   | jvm 1    | 2022/04/20 09:27:14 | 	at org.eclipse.jetty.server.HttpConnection.onFillable(HttpConnection.java:277)
INFO   | jvm 1    | 2022/04/20 09:27:14 | 	at org.eclipse.jetty.io.AbstractConnection$ReadCallback.succeeded(AbstractConnection.java:311)
INFO   | jvm 1    | 2022/04/20 09:27:14 | 	at org.eclipse.jetty.io.FillInterest.fillable(FillInterest.java:105)
INFO   | jvm 1    | 2022/04/20 09:27:14 | 	at org.eclipse.jetty.io.ChannelEndPoint$1.run(ChannelEndPoint.java:104)
INFO   | jvm 1    | 2022/04/20 09:27:14 | 	at org.eclipse.jetty.util.thread.strategy.EatWhatYouKill.runTask(EatWhatYouKill.java:338)
INFO   | jvm 1    | 2022/04/20 09:27:14 | 	at org.eclipse.jetty.util.thread.strategy.EatWhatYouKill.doProduce(EatWhatYouKill.java:315)
INFO   | jvm 1    | 2022/04/20 09:27:14 | 	at org.eclipse.jetty.util.thread.strategy.EatWhatYouKill.tryProduce(EatWhatYouKill.java:173)
INFO   | jvm 1    | 2022/04/20 09:27:14 | 	at org.eclipse.jetty.util.thread.strategy.EatWhatYouKill.run(EatWhatYouKill.java:131)
INFO   | jvm 1    | 2022/04/20 09:27:14 | 	at org.eclipse.jetty.util.thread.ReservedThreadExecutor$ReservedThread.run(ReservedThreadExecutor.java:409)
INFO   | jvm 1    | 2022/04/20 09:27:14 | 	at org.eclipse.jetty.util.thread.QueuedThreadPool.runJob(QueuedThreadPool.java:883)
INFO   | jvm 1    | 2022/04/20 09:27:14 | 	at org.eclipse.jetty.util.thread.QueuedThreadPool$Runner.run(QueuedThreadPool.java:1034)
INFO   | jvm 1    | 2022/04/20 09:27:14 | 	at java.base/java.lang.Thread.run(Unknown Source)
INFO   | jvm 1    | 2022/04/20 09:27:14 | Caused by: java.lang.reflect.InvocationTargetException: null
INFO   | jvm 1    | 2022/04/20 09:27:14 | 	at jdk.internal.reflect.GeneratedMethodAccessor51.invoke(Unknown Source)
INFO   | jvm 1    | 2022/04/20 09:27:14 | 	at java.base/jdk.internal.reflect.DelegatingMethodAccessorImpl.invoke(Unknown Source)
INFO   | jvm 1    | 2022/04/20 09:27:14 | 	at java.base/java.lang.reflect.Method.invoke(Unknown Source)
INFO   | jvm 1    | 2022/04/20 09:27:14 | 	at org.apache.wicket.RequestListenerInterface.internalInvoke(RequestListenerInterface.java:258)
INFO   | jvm 1    | 2022/04/20 09:27:14 | 	… 50 common frames omitted
INFO   | jvm 1    | 2022/04/20 09:27:14 | Caused by: java.lang.NoSuchFieldError: MESUnit
INFO   | jvm 1    | 2022/04/20 09:27:14 | 	at com.sepasoft.batch.gateway.BatchGatewayHook.(BatchGatewayHook.java:19)
INFO   | jvm 1    | 2022/04/20 09:27:14 | 	at java.base/jdk.internal.reflect.NativeConstructorAccessorImpl.newInstance0(Native Method)
INFO   | jvm 1    | 2022/04/20 09:27:14 | 	at java.base/jdk.internal.reflect.NativeConstructorAccessorImpl.newInstance(Unknown Source)
INFO   | jvm 1    | 2022/04/20 09:27:14 | 	at java.base/jdk.internal.reflect.DelegatingConstructorAccessorImpl.newInstance(Unknown Source)
INFO   | jvm 1    | 2022/04/20 09:27:14 | 	at java.base/java.lang.reflect.Constructor.newInstance(Unknown Source)
INFO   | jvm 1    | 2022/04/20 09:27:14 | 	at com.inductiveautomation.ignition.gateway.modules.ModuleManagerImpl$LoadedModule.loadHook(ModuleManagerImpl.java:2336)
INFO   | jvm 1    | 2022/04/20 09:27:14 | 	at com.inductiveautomation.ignition.gateway.modules.ModuleManagerImpl$LoadedModule.load(ModuleManagerImpl.java:2036)
INFO   | jvm 1    | 2022/04/20 09:27:14 | 	at com.inductiveautomation.ignition.gateway.modules.ModuleManagerImpl.startupModule(ModuleManagerImpl.java:1222)
INFO   | jvm 1    | 2022/04/20 09:27:14 | 	at com.inductiveautomation.ignition.gateway.modules.ModuleManagerImpl$4.call(ModuleManagerImpl.java:882)
INFO   | jvm 1    | 2022/04/20 09:27:14 | 	at com.inductiveautomation.ignition.gateway.modules.ModuleManagerImpl.executeModuleOperation(ModuleManagerImpl.java:948)
INFO   | jvm 1    | 2022/04/20 09:27:14 | 	at com.inductiveautomation.ignition.gateway.modules.ModuleManagerImpl.restartModuleInternal(ModuleManagerImpl.java:862)
INFO   | jvm 1    | 2022/04/20 09:27:14 | 	at com.inductiveautomation.ignition.gateway.modules.ModuleManagerImpl.restartModule(ModuleManagerImpl.java:854)
INFO   | jvm 1    | 2022/04/20 09:27:14 | 	at com.inductiveautomation.ignition.gateway.web.pages.config.ModulePage$RestartAction.execute(ModulePage.java:575)
INFO   | jvm 1    | 2022/04/20 09:27:14 | 	at com.inductiveautomation.ignition.gateway.web.components.ConfirmationPanel$1.onClick(ConfirmationPanel.java:50)
INFO   | jvm 1    | 2022/04/20 09:27:14 | 	at org.apache.wicket.markup.html.link.Link.onLinkClicked(Link.java:190)
INFO   | jvm 1    | 2022/04/20 09:27:14 | 	… 54 common frames omitted
INFO   | jvm 1    | 2022/04/20 09:29:11 | I [g.ModuleManager               ] [03:59:11]: Restarting module “batchgateway”
INFO   | jvm 1    | 2022/04/20 09:29:11 | W [g.ModuleManager               ] [03:59:11]: Module “batchgateway” depends on “xopc”, but it doesn’t exist.
INFO   | jvm 1    | 2022/04/20 09:29:11 | E [o.a.w.DefaultExceptionMapper  ] [03:59:11]: Unexpected error occurred
INFO   | jvm 1    | 2022/04/20 09:29:11 | org.apache.wicket.WicketRuntimeException: Method onLinkClicked of interface org.apache.wicket.markup.html.link.ILinkListener targeted at [Link [Component id = confirm]] on component [Link [Component id = confirm]] threw an exception
INFO   | jvm 1    | 2022/04/20 09:29:11 | 	at org.apache.wicket.RequestListenerInterface.internalInvoke(RequestListenerInterface.java:268)
INFO   | jvm 1    | 2022/04/20 09:29:11 | 	at org.apache.wicket.RequestListenerInterface.invoke(RequestListenerInterface.java:216)
INFO   | jvm 1    | 2022/04/20 09:29:11 | 	at org.apache.wicket.core.request.handler.ListenerInterfaceRequestHandler.invokeListener(ListenerInterfaceRequestHandler.java:243)
INFO   | jvm 1    | 2022/04/20 09:29:11 | 	at org.apache.wicket.core.request.handler.ListenerInterfaceRequestHandler.respond(ListenerInterfaceRequestHandler.java:236)
INFO   | jvm 1    | 2022/04/20 09:29:11 | 	at org.apache.wicket.request.cycle.RequestCycle$HandlerExecutor.respond(RequestCycle.java:890)
INFO   | jvm 1    | 2022/04/20 09:29:11 | 	at org.apache.wicket.request.RequestHandlerStack.execute(RequestHandlerStack.java:64)
INFO   | jvm 1    | 2022/04/20 09:29:11 | 	at org.apache.wicket.request.cycle.RequestCycle.execute(RequestCycle.java:261)
INFO   | jvm 1    | 2022/04/20 09:29:11 | 	at org.apache.wicket.request.cycle.RequestCycle.processRequest(RequestCycle.java:218)
INFO   | jvm 1    | 2022/04/20 09:29:11 | 	at org.apache.wicket.request.cycle.RequestCycle.processRequestAndDetach(RequestCycle.java:289)
INFO   | jvm 1    | 2022/04/20 09:29:11 | 	at org.apache.wicket.protocol.http.WicketFilter.processRequestCycle(WicketFilter.java:259)
INFO   | jvm 1    | 2022/04/20 09:29:11 | 	at org.apache.wicket.protocol.http.WicketFilter.processRequest(WicketFilter.java:201)
INFO   | jvm 1    | 2022/04/20 09:29:11 | 	at org.apache.wicket.protocol.http.WicketFilter.doFilter(WicketFilter.java:282)
INFO   | jvm 1    | 2022/04/20 09:29:11 | 	at org.eclipse.jetty.servlet.FilterHolder.doFilter(FilterHolder.java:201)
INFO   | jvm 1    | 2022/04/20 09:29:11 | 	at org.eclipse.jetty.servlet.ServletHandler$Chain.doFilter(ServletHandler.java:1601)
INFO   | jvm 1    | 2022/04/20 09:29:11 | 	at org.eclipse.jetty.servlet.ServletHandler.doHandle(ServletHandler.java:548)
INFO   | jvm 1    | 2022/04/20 09:29:11 | 	at org.eclipse.jetty.server.handler.ScopedHandler.handle(ScopedHandler.java:143)
INFO   | jvm 1    | 2022/04/20 09:29:11 | 	at org.eclipse.jetty.security.SecurityHandler.handle(SecurityHandler.java:600)
INFO   | jvm 1    | 2022/04/20 09:29:11 | 	at org.eclipse.jetty.server.handler.HandlerWrapper.handle(HandlerWrapper.java:127)
INFO   | jvm 1    | 2022/04/20 09:29:11 | 	at org.eclipse.jetty.server.handler.ScopedHandler.nextHandle(ScopedHandler.java:235)
INFO   | jvm 1    | 2022/04/20 09:29:11 | 	at org.eclipse.jetty.server.session.SessionHandler.doHandle(SessionHandler.java:1624)
INFO   | jvm 1    | 2022/04/20 09:29:11 | 	at org.eclipse.jetty.server.handler.ScopedHandler.nextHandle(ScopedHandler.java:233)
INFO   | jvm 1    | 2022/04/20 09:29:11 | 	at org.eclipse.jetty.server.handler.ContextHandler.doHandle(ContextHandler.java:1440)
INFO   | jvm 1    | 2022/04/20 09:29:11 | 	at org.eclipse.jetty.server.handler.ScopedHandler.nextScope(ScopedHandler.java:188)
INFO   | jvm 1    | 2022/04/20 09:29:11 | 	at org.eclipse.jetty.servlet.ServletHandler.doScope(ServletHandler.java:501)
INFO   | jvm 1    | 2022/04/20 09:29:11 | 	at org.eclipse.jetty.server.session.SessionHandler.doScope(SessionHandler.java:1594)
INFO   | jvm 1    | 2022/04/20 09:29:11 | 	at org.eclipse.jetty.server.handler.ScopedHandler.nextScope(ScopedHandler.java:186)
INFO   | jvm 1    | 2022/04/20 09:29:11 | 	at org.eclipse.jetty.server.handler.ContextHandler.doScope(ContextHandler.java:1355)
INFO   | jvm 1    | 2022/04/20 09:29:11 | 	at org.eclipse.jetty.server.handler.ScopedHandler.handle(ScopedHandler.java:141)
INFO   | jvm 1    | 2022/04/20 09:29:11 | 	at com.inductiveautomation.catapult.handlers.RemoteHostNameLookupHandler.handle(RemoteHostNameLookupHandler.java:121)
INFO   | jvm 1    | 2022/04/20 09:29:11 | 	at org.eclipse.jetty.rewrite.handler.RewriteHandler.handle(RewriteHandler.java:322)
INFO   | jvm 1    | 2022/04/20 09:29:11 | 	at org.eclipse.jetty.server.handler.HandlerList.handle(HandlerList.java:59)
INFO   | jvm 1    | 2022/04/20 09:29:11 | 	at org.eclipse.jetty.server.handler.HandlerCollection.handle(HandlerCollection.java:146)
INFO   | jvm 1    | 2022/04/20 09:29:11 | 	at org.eclipse.jetty.server.Server.handle(Server.java:516)
INFO   | jvm 1    | 2022/04/20 09:29:11 | 	at org.eclipse.jetty.server.HttpChannel.lambda$handle$1(HttpChannel.java:487)
INFO   | jvm 1    | 2022/04/20 09:29:11 | 	at org.eclipse.jetty.server.HttpChannel.dispatch(HttpChannel.java:732)
INFO   | jvm 1    | 2022/04/20 09:29:11 | 	at org.eclipse.jetty.server.HttpChannel.handle(HttpChannel.java:479)
INFO   | jvm 1    | 2022/04/20 09:29:11 | 	at org.eclipse.jetty.server.HttpConnection.onFillable(HttpConnection.java:277)
INFO   | jvm 1    | 2022/04/20 09:29:11 | 	at org.eclipse.jetty.io.AbstractConnection$ReadCallback.succeeded(AbstractConnection.java:311)
INFO   | jvm 1    | 2022/04/20 09:29:11 | 	at org.eclipse.jetty.io.FillInterest.fillable(FillInterest.java:105)
INFO   | jvm 1    | 2022/04/20 09:29:11 | 	at org.eclipse.jetty.io.ChannelEndPoint$1.run(ChannelEndPoint.java:104)
INFO   | jvm 1    | 2022/04/20 09:29:11 | 	at org.eclipse.jetty.util.thread.strategy.EatWhatYouKill.runTask(EatWhatYouKill.java:338)
INFO   | jvm 1    | 2022/04/20 09:29:11 | 	at org.eclipse.jetty.util.thread.strategy.EatWhatYouKill.doProduce(EatWhatYouKill.java:315)
INFO   | jvm 1    | 2022/04/20 09:29:11 | 	at org.eclipse.jetty.util.thread.strategy.EatWhatYouKill.tryProduce(EatWhatYouKill.java:173)
INFO   | jvm 1    | 2022/04/20 09:29:11 | 	at org.eclipse.jetty.util.thread.strategy.EatWhatYouKill.run(EatWhatYouKill.java:131)
INFO   | jvm 1    | 2022/04/20 09:29:11 | 	at org.eclipse.jetty.util.thread.ReservedThreadExecutor$ReservedThread.run(ReservedThreadExecutor.java:409)
INFO   | jvm 1    | 2022/04/20 09:29:11 | 	at org.eclipse.jetty.util.thread.QueuedThreadPool.runJob(QueuedThreadPool.java:883)
INFO   | jvm 1    | 2022/04/20 09:29:11 | 	at org.eclipse.jetty.util.thread.QueuedThreadPool$Runner.run(QueuedThreadPool.java:1034)
INFO   | jvm 1    | 2022/04/20 09:29:11 | 	at java.base/java.lang.Thread.run(Unknown Source)
INFO   | jvm 1    | 2022/04/20 09:29:11 | Caused by: java.lang.reflect.InvocationTargetException: null
INFO   | jvm 1    | 2022/04/20 09:29:11 | 	at jdk.internal.reflect.GeneratedMethodAccessor51.invoke(Unknown Source)
INFO   | jvm 1    | 2022/04/20 09:29:11 | 	at java.base/jdk.internal.reflect.DelegatingMethodAccessorImpl.invoke(Unknown Source)
INFO   | jvm 1    | 2022/04/20 09:29:11 | 	at java.base/java.lang.reflect.Method.invoke(Unknown Source)
INFO   | jvm 1    | 2022/04/20 09:29:11 | 	at org.apache.wicket.RequestListenerInterface.internalInvoke(RequestListenerInterface.java:258)
INFO   | jvm 1    | 2022/04/20 09:29:11 | 	… 50 common frames omitted
INFO   | jvm 1    | 2022/04/20 09:29:11 | Caused by: java.lang.NoSuchFieldError: MESUnit
INFO   | jvm 1    | 2022/04/20 09:29:11 | 	at com.sepasoft.batch.gateway.BatchGatewayHook.(BatchGatewayHook.java:19)
INFO   | jvm 1    | 2022/04/20 09:29:11 | 	at java.base/jdk.internal.reflect.NativeConstructorAccessorImpl.newInstance0(Native Method)
INFO   | jvm 1    | 2022/04/20 09:29:11 | 	at java.base/jdk.internal.reflect.NativeConstructorAccessorImpl.newInstance(Unknown Source)
INFO   | jvm 1    | 2022/04/20 09:29:11 | 	at java.base/jdk.internal.reflect.DelegatingConstructorAccessorImpl.newInstance(Unknown Source)
INFO   | jvm 1    | 2022/04/20 09:29:11 | 	at java.base/java.lang.reflect.Constructor.newInstance(Unknown Source)
INFO   | jvm 1    | 2022/04/20 09:29:11 | 	at com.inductiveautomation.ignition.gateway.modules.ModuleManagerImpl$LoadedModule.loadHook(ModuleManagerImpl.java:2336)
INFO   | jvm 1    | 2022/04/20 09:29:11 | 	at com.inductiveautomation.ignition.gateway.modules.ModuleManagerImpl$LoadedModule.load(ModuleManagerImpl.java:2036)
INFO   | jvm 1    | 2022/04/20 09:29:11 | 	at com.inductiveautomation.ignition.gateway.modules.ModuleManagerImpl.startupModule(ModuleManagerImpl.java:1222)
INFO   | jvm 1    | 2022/04/20 09:29:11 | 	at com.inductiveautomation.ignition.gateway.modules.ModuleManagerImpl$4.call(ModuleManagerImpl.java:882)
INFO   | jvm 1    | 2022/04/20 09:29:11 | 	at com.inductiveautomation.ignition.gateway.modules.ModuleManagerImpl.executeModuleOperation(ModuleManagerImpl.java:948)
INFO   | jvm 1    | 2022/04/20 09:29:11 | 	at com.inductiveautomation.ignition.gateway.modules.ModuleManagerImpl.restartModuleInternal(ModuleManagerImpl.java:862)
INFO   | jvm 1    | 2022/04/20 09:29:11 | 	at com.inductiveautomation.ignition.gateway.modules.ModuleManagerImpl.restartModule(ModuleManagerImpl.java:854)
INFO   | jvm 1    | 2022/04/20 09:29:11 | 	at com.inductiveautomation.ignition.gateway.web.pages.config.ModulePage$RestartAction.execute(ModulePage.java:575)
INFO   | jvm 1    | 2022/04/20 09:29:11 | 	at com.inductiveautomation.ignition.gateway.web.components.ConfirmationPanel$1.onClick(ConfirmationPanel.java:50)
INFO   | jvm 1    | 2022/04/20 09:29:11 | 	at org.apache.wicket.markup.html.link.Link.onLinkClicked(Link.java:190)
INFO   | jvm 1    | 2022/04/20 09:29:11 | 	… 54 common frames omitted
