Open Source Modules
Device Drivers
| Name | Author | Description | 8.1 | 8.3 |
| HiveMQ Ignition Module | system24seven | MQTT Subscription as a device driver. | v1.0.0 |
v1.2.3 |
| Embr-SNMP | mussonindustrial | Add SNMP devices to your OPCUA tags | v0.7.2 |
v0.5.3 |
| Modbus Server Driver | kevinherron | A Modbus server driver for Ignition's OPC UA server | v1.0.1 |
v2.0.1 |
| MTConnect Module | JonathanGrocott | Read-only MTConnect integration that polls MTConnect agents and exposes data as Ignition tags via a managed tag provider. | v0.1.2 |
Vision Components
| Cautious-memory | jimender | Modern Ignition Vision PDF Viewer | v1.0.0 |
Perspective Components
| Embr Charts Module | mussonindustrial | A collection of enhanced Perspective charting components. | ||
| Embr Periscope Module | mussonindustrial | Design extensions and enhancements for Perspective. | ||
| Ignition Branching Module | Mustry Solutions | Perspective component with a branching option, good for track and trace | v1.1.1 |
| Ignition-NivoCharts | ah1191999 | A module that adds Nivo Charts to the Perspective module. | v1.0.0 |
| Ignition AI Module | EckmanTechLLC | Integrates Claude AI with comprehensive tools for reading project resources, querying tags/alarms, and analyzing system data. | ||
Gateway Modules
| Embr Thermodynamics Module | mussonindustrial | Scripting and expression functions for computing properties of water and steam via an IF97 implementation. | v3.2.2 |
| Embr Server Sent Events Module | mussonindustrial | Provides an API for high-speed streaming of tag changes via SSE (server-sent events). | v0.8.2 |
| Ignition Git | AXONE-IO | Git for Ignition 8.1 projects | ||
| SNMP-Ignition-Module | kiilez | Adds SNMP scripting functions to query network devices. | ||
| Webroutes-Ignition | jimender | Demo module for adding a webroute in Ignition | ||
| HydraMQTT | m-r-mccormick | It facilitates the utilization of non-Sparkplug MQTT. | v0.4.0-rc1 |
| Ignition-API-Client | Kyvis Labs | An Ignition module that provides an easy way to interface with REST APIs without having to write scripts in Ignition. | v1.03 |
| Ignition CICD | Design-Group | An Ignition Module to add features that enhance CICD capabilities for tags. | v2.02 |
| Ignition-Neo4J | keith-gamble | Neo4J Driver module for ignition | v0.2.0 |
| Ignition Extensions | Paul Griffith | A (hopefully) community driven Ignition module project to house utilities that are often useful, but just too niche (or potentially risky) to go into Ignition itself. | v0.8.0 |
| Ignition Bitwarden Secrets Module | Kyvis Labs | Allows for retrieving secrets from Bitwarden Secrets Manager | ||
| Ignition ESPHome Module | Kyvis Labs | Provides a device driver to communicate with the ESPHome API | ||
| Ignition Pushover Module | Kyvis Labs | Adds support for sending alarm notifications through Pushover | v1.1.0 |
| Ignition Ntfy Module | Kyvis Labs | Adds support for sending alarm notifications through a ntfy server | v1.1.2 |
| Ignition Gotify Module | Kyvis Labs | Adds support for sending alarm notifications through a Gotify server | v1.0.0 |
| JSON Schema to UDT | Jonathan Wise | Tag provider module for Ignition: finds JSON schemas and provides them as UDTs. | ||
| Ignition Process Filters Module | kmchoi1540 | Custom Ignition module for real-time signal filtering and data buffering — includes stateful expression functions (storeData, customFilter) with WMA, CWMA, and Butterworth IIR, Kalman filters. | ||
| Ignition MQTT UNS Publisher Module | JonathanGrocott | Publishes tag data to an MQTT broker using a Unified Namespace (UNS) structure with configurable JSON payloads. | ||
| Ignition MQTT SparkPlug B Publisher Module | JonathanGrocott | Publishes tag data to an MQTT broker using SparkplugB payloads. | ||
| Ignition MCP | JonathanGrocott | Ignition module that exposes a tools-only MCP server | ||
| Webdev Compatibility Module | JonathanGrocott | Ignition module that directly replaces the built-in Web Dev servlet |
Designer Modules
| Gateway Logs Viewer | system24seven | Designer window to live display gateway logs | v0.1.1 |
Event Streams
| Name | Author | Description | 8.3 |
| MQTT Stream Source | system24seven | MQTT Events as Event Stream Source | v1.2.0 |
| SNMP Stream Source | system24seven | SNMP Traps as an Event Stream Source | v1.0.0 |
| Barcode Stream Source | system24seven | TCP Barcode Readers as an Event Stream Source | v1.0.0 |
Closed Source Modules
| Name | Author | Description | 8.1 | 8.3 | Edge |
| Plotly Module | BIJC | An implementation of the plotly.js library as a perspective component | v3.3.1 |
v3.3.1 |
| Artek Utilities | Artek | Integrates Apache PDFBox to perform various pdf manipulations (merging, splitting, add watermark, etc) |
Gateway Modules
| Opto22 Module | Avadine | Provides the ability to configure and integrate with the Opto22 groov EPIC | |||
| Blob Server | Automation Professionals | Deliver DB Binary Blobs as URLs via Named Queries |
Vision Components
| Name | Author | Description | 8.1 | 8.3 | Module |
Utilities
| Integration Toolkit | Automation Professionals | Scripting and Expression Functions, plus Tag Actors |
² When purchasing an Edge driver from Automation Professionals.
