Ignition on Azure Kubernetes Service
Hello All,
Just wanted to post a quick deployment here written for Azure Kubernetes Service to solicit feedback and hopefully help others who are also exploring Ignition on k8s. Our deployment is designed for an autoscaling node pool across 3 zones in US Central, for 3 Ignition instances that are responsible for data acquisition, enterprise functions, and MQTT relay. We utilize PersistentVolumes by seeding them as adapted from the example that Kevin Collins posted, but do not explicitly declare the volumes and instead let AKS provision them using a premium storage class. Our cluster is private (not exposed to the public internet), so we accomplish tie back to premise using the Azure Internal Load Balancer with private IP space in the same vNet. That vNet is peered back to a central hub vNet which has a gateway built back to premise.
Ideally here we'd want to take this a step further for the passwords using Azure Key Vault / CSI Driver, and we will also want to attach an additional volume for the enterprise instance which will collect and retain backups for all gateways across the org. I hope to follow this post up with those implementations soon.
Please take a look. Critical feedback welcome and appreciated!
Here's one of the three deployments, for enterprise. The other two are similar with some naming conventions changed.
apiVersion: apps/v1
kind: Deployment
metadata:
  namespace: ignition-enterprise
spec:
  selector:
    matchLabels:
      app: ignition-enterprise-application
  strategy:
    type: Recreate
  template:
    metadata:
      labels:
    spec:
      initContainers:
      - name: seed-volume
        image: inductiveautomation/ignition:8.1.17
        resources:
          limits:
            memory: "256Mi"
            cpu: "1000m"
        command:
        - sh
        - -c
          if [ ! -f /data/.ignition-seed-complete ]; then
            touch /data/.ignition-seed-complete ;
            cp -dpR /usr/local/bin/ignition/data/* /data/ ;
          fi
        volumeMounts:
        - mountPath: /data
      containers:
      - name: ignition
        resources:
          limits:
            memory: "4096Mi"
            cpu: "1000m"
        args:
        - -m
        - "4096"
        - -n
        - "Ignition-Enterprise"
        env:
        - name: ACCEPT_IGNITION_EULA
          value: "Y"
        - name: TZ
          value: “America/Chicago”
        - name: IGNITION_EDITION
          value: standard
        ports:
        - name: ignition-http
          containerPort: 8088
        - name: ignition-https
          containerPort: 8043
        volumeMounts:
        - mountPath: /usr/local/bin/ignition/data
        readinessProbe:
          exec:
            command:
            - health-check.sh
            - -t
            - "3"
          initialDelaySeconds: 60
          periodSeconds: 10
          failureThreshold: 10
          timeoutSeconds: 3
      volumes:
      - name: ignition-pv-enterprise-volume
        persistentVolumeClaim:
         claimName: ignition-pv-enterprise-claim
PersistentVolume claim
apiVersion: v1
kind: PersistentVolumeClaim
metadata:
spec:
  accessModes:
  - ReadWriteOnce
  storageClassName: managed-csi-premium
  resources:
    requests:
      storage: 10Gi
and the Azure Internal Load Balancer
apiVersion: v1
kind: Service
metadata:
  annotations:
    service.beta.kubernetes.io/azure-load-balancer-internal: "true"
spec:
  type: LoadBalancer
  loadBalancerIP: X.X.X.251 #*Redacted*
  ports:
  - name: http
    port: 80
    targetPort: 8088
    port: 443
    targetPort: 8043
  selector:
Note: I realize the formatting for the YAML isn't displaying correctly on the forums above. Not sure how to fix that.
The trick is to enclose it in triple backticks/use the preformatted text </> icon:
I updated your original post, though I might have lost a space or something inadvertently.
Kudos for posting/giving something like this back to the community.
Are there Helm Charts for deploying the Ignition container to AKS? Also, we have several custom libraries/modules that are part of our Ignition implementation (e.g. Sepasoft). Would we just copy them to the volume storage account in Azure and Ignition will find them or will we need to created additional PVCs?
