Hello,
Reaching out to see if anyone has developed an ad hoc historical tag browser that supports filtering, this would be coupled with a power chart to add pens. This is for a large system with a lot of pens being historized. I do not want to try and reinvent something if someone also has a solution.
Thanks,
Frank
Sounds like a good Exchange project
I was working on this a while back, but it's only halfway there atm
This is an example of what I’d like to see for the tag browser (what’s shown is currently still in dev, but almost there):
wbaker
August 26, 2023, 11:05am
4
Looks like it’s on its way with yesterdays change log update!
Nightly Changelog: 8.1.32-SNAPSHOT-b20230825
Alarming
Alarm Status
IGN-8276: IGN-2145 Causes No Default State for an Alarm causing multiple Backend Alarms tasks to behave very differently
Fixed an issue with alarms not undergoing “initial base” event state. In addition, these specific events will no longer be stored to the journal system.
Tags
Tags & UDTs
IGN-8227: System.tag.writeBlocking will timeout when run within a system.tag.writeAsync callback function in gateway scope
Fixed a bug tha…
lrose
August 26, 2023, 5:48pm
5
Technically that says Tag Browse tree, not Power chart, they are separate components. So maybe it is maybe it isn’t.
I forget if you can filter only tags with history with the tag tree if you can, then you could use this
I don’t believe the tag tree browser object would work for this application.
