Ignition Scripting API now available via pypi
In the past I have shared with this community the Ignition repo I maintain at GitHub:
And inspired by a comment made by @kgamble and someone’s fork, I created the ignition-api package available to anyone interested.
Currently I have only created releases for versions 8.0.17 (8.0 branch from the repo), 8.1.9, and 8.1.10 (main branch from the repo).
I recommend using Python 2.7.18, and to install you may use any of the following:
To get the latest and/or upgrade:
$ python2 -m pip install --upgrade ignition-api
Or to get a specific version:
$ python2 -m pip install ignition-api==8.0.17.post1
or
$ python2 -m pip install ignition-api==8.1.9
For the 7.9 branch I am relying on Python 2.5 (since Ignition relies on Jython 2.5.3), so pip doesn’t appear to work, but you may still do the following:
$ git clone --single-branch --branch 7.9 https://github.com/thecesrom/Ignition.git 7.9
$ cd 7.9
$ python2 setup.py install --record files.txt
Note: Starting with release 7.9.19 all you’d have to do is download the source code for its release, un[zip|tar] it and use the setup.py from each release.
The --record option is so you create a receipt of all installed files in case you want to uninstall it by running:
$ cat files.txt | xargs rm -rf
As for the jython branch, the process is somewhat similar to 7.9's but with certain distinctions.
Note: I recommend installing Jython with pip included to make it a lot easier to install/uninstall packages.
Starting with the 8.1.10-jython release, just run the following:
$ jython -m pip install https://github.com/thecesrom/Ignition/archive/refs/tags/v8.1.10-jython.zip
DEPRECATION: A future version of pip will drop support for Python 2.7.
Collecting https://github.com/thecesrom/Ignition/archive/refs/tags/v8.1.10-jython.zip
  Using cached https://github.com/thecesrom/Ignition/archive/refs/tags/v8.1.10-jython.zip
Installing collected packages: ignition-api-jython
  Running setup.py install for ignition-api-jython ... done
Successfully installed ignition-api-jython-8.1.10
Just replace v#.#.#-jython.zip using the latest stable version.
And to uninstall:
$ jython -m pip uninstall ignition-api -y
And that’s it.
Happy coding!
This has been tested using Python 2.7.18, 2.5.6, and Jython 2.7.1 and 2.7.2, as well as PyCharm. All of this was so it could also work on Visual Studio Code, but unfortunately it does not.
See here:
If at some point jython -m pip install ignition-api-jython from PyPI works, I have also created that package.
Alternatively if you wish to install it, you may use the latest release from the jython branch.
For release 8.1.10-jython you would do the following:
  Downloading https://github.com/thecesrom/Ignition/archive/refs/tags/v8.1.10-jython.zip
     \ 225kB 1.6MB/s
$ jython -m pip list
Package             Version
ignition-api-jython 8.1.10
pip                 19.1
setuptools          41.0.1
This will allow you to do something like:
$ jython
Jython 2.7.2 (v2.7.2:925a3cc3b49d, Mar 21 2020, 10:03:58)
[OpenJDK 64-Bit Server VM (Azul Systems, Inc.)] on java11.0.11
Type "help", "copyright", "credits" or "license" for more information.
>>> import system.gui
>>> system.gui.warningBox("This one is a warning.")
Just make sure you change the version number from the URL, i.e. v#.#.#-jython.zip to the latest. But note that the ignition-api-jython package is for version 8.1.10 onwards.
An update.
After pip-installing ignition-api I am able to get code completion on Visual Studio Code, so I can mark the following feature request as implemented.
The following versions now include the com.inductiveautomation package, just consider that it is not a one-to-one implementation. I have only created the necessary code for some use cases.
Latest versions and how to install them:
8.1.10
8.0.17
$ python2 -m pip install ignition-api==8.0.17.post3
7.9.18
$ python2 -m pip install ignition-api==7.9.18.post2
Code completion works on PyCharm 2021.2.2 (also when running the code from its Python Console) and Visual Studio Code 1.60.2 for the following versions:
7.9.18 (from 7.9 branch)
8.0.17 (from 8.0 branch)
8.1.10 (from main branch)
As for 8.1.10-jython, Visual Studio Code does not appear to support Jython as an interpreter, and on PyCharm these are the features that work:
Code completion (a.k.a. intellisense)
Python Console (see: PY-44759, PY-50491)
And apparently Jython appears to struggle when trying to import anything under com.inductiveautomation.
So, considering all of the above, the jython branch, as fun as it was to work on it, will no longer be maintained. It will be kept until 8.1.11 is released just in case something or someone steps in.
How would I leverage this package to read memory tags from an ignition gateway?
You wouldn’t, that’s not its purpose. It’s a bunch of mocks that can be used when editing code in an editor with auto completion, so that mocks for Ignition’s system functions also auto complete.
Start a new topic about what you’re asking.
Ok understood. Thank you!
My new topic is Accessing Ignition tags from external micro service
Hi guys, can somebody guide me how to use this in the visual studio code, i have tried cloning the repo and i was able to see all those in my vs code editor and then i created a python file, but no auto completion or code execution is happening.
python version is 2.7.18
even for system function its showing to import
somebody please guide. Am i missing something, any configurations in the vs code editor?
Hello, @John_S1.
You should either install ignition-api on Python 2.7.18 or a virtual environment created with Python 2.7.18.
  1. Install virtualenv:
    python2 -m pip install virtualenv
  2. Create virtual environment:
    python2 -m virtualenv .venv
  3. Activate virtual environment:
    a. Linux/macOS
    source .venv/bin/activate
    b. Windows
    .\.venv\Scripts\Activate.ps1
  4. On Visual Studio Code, select ./.venv/bin/python as your project's interpreter.
  5. Install ignition-api:
    python -m pip install ignition-api
  6. Get code completion:
devcontainer.json all-in-one
	"name": "Ignition",
	"dockerComposeFile": [
		"docker-compose.yaml",
		"docker-compose.stack.yaml"
	"service": "Ignition",
	"workspaceFolder": "/usr/local/bin/ignition", // /data”,
	"features": {
		"ghcr.io/rocker-org/devcontainer-features/apt-packages:1": {
			"upgradePackages": true,
			"packages": "build-essential libssl-dev zlib1g-dev libbz2-dev libreadline-dev libsqlite3-dev wget curl llvm libncurses5-dev libncursesw5-dev xz-utils tk-dev libffi-dev liblzma-dev git ca-certificates"
	"postCreateCommand": "bash -c 'curl https://pyenv.run | bash && export PYENV_ROOT=\"$HOME/.pyenv\" && [[ -d $PYENV_ROOT/bin ]] && export PATH=\"$PYENV_ROOT/bin:$PATH\" && eval \"$(pyenv init -)\" && eval \"$(pyenv virtualenv-init -)\" && pyenv install 2.7.18 && pyenv global 2.7.18 && pip install ignition-api && pip install --upgrade pip'",
    "customizations": {
        "vscode": {
            "extensions": [
                "donjayamanne.python-extension-pack",
				"donjayamanne.git-extension-pack"
            "settings": {
				"python.autoComplete.extraPaths": [
					"/root/.pyenv/versions/2.7.18/lib/python2.7/site-packages/"
				"python.analysis.extraPaths": [
	"remoteUser": "root"
For dev containers I use quay.io/ignition-devs/devcontainer-base, which uses quay.io/coatldev/six as base.
And devcontainer.json:
Also have to import system
Do you know if there is a way around this? would love to have intellisense in VScode. But adding all imports to the file just for intellisense seems redundant since it's not needed in Ignition.
FWIW, I’m almost certain I solved this with some combination of python.analysis.include/extraPaths/etc settings in VSCode, and perhaps an __init__.py file, but of course I’ve since wiped that local environment after assuming I fully understood the fix and had it sorted in my devcontainer… only to be unable to replicate it. My VSCode settings.json file is a commented mess and I eventually gave up. I’m all for explicit imports myself, but wish I could get this to work for existing code. :confused:
Are you VS Code users just ignoring the syntax highlighting errors / false positives / false negatives / whatever caused by pylance not supporting Python 2?
# type: ignore - VSCode :laughing:
it’s relatively rare in my experience/almost always pretty easy to get 0 issues, even with "python.analysis.typeCheckingMode": "standard", // “basic"
Suppose that doesn’t cover “false negatives” though…
Hello, @Joost_t.
I get your point that you don't have to explicitly import system on the Ignition Designer, since it's a builtin module, which is not the case in the Python world.
I'm so used to it that it does not bother me.
I thought that with Pylance taking over Jedi my projects would be full of red squiggly lines, but it did not.
As far as the python.defaultInterpreterPath points at the Python 2 virtual env, there are no highlighting errors.
