Hi, I was trying to see if we can use ignition to view Outlook or Gmail calendar using Month View (Component Palette).
Please let me know if you have used/created something like that before?
There isn't much on the forum about this, one post i found talked about Google API
I spent a couple minutes fooling around with exporting an outlook calendar, and you can export it in csv format, then read the contents of the csv. From there it would just be modifying the csv dataset to match the format of the moth view calendar events dataset.
This is as far as i took it, since im not sure this is even the direction you are interested in.
import csv
path = "C:\calcsv.CSV"
csvData = csv.reader(open(path))
header = csvData.next()
dataset = system.dataset.toDataSet(header, list(csvData))
Oof, i feel like this is poorly done, but it works.
import csv
from java.util import Date
from java.lang import String
from datetime import datetime
from com.inductiveautomation.ignition.common.util import DatasetBuilder
path = "C:\calcsv1.CSV"
csvList = list(csvData)
header = ['startDate', 'endDate', 'displayColor', 'display']
newDS = DatasetBuilder.newBuilder().colNames(header).colTypes(Date, Date, String, String).build()
for x in range(len(csvList)):
	row = []
	if x > 0:
		row.append(csvList[x][1] + " " + datetime.strftime(datetime.strptime(csvList[x][2], "%I:%M:%S %p"), "%H:%M:%S"))
		row.append(csvList[x][3] + " " + datetime.strftime(datetime.strptime(csvList[x][4], "%I:%M:%S %p"), "%H:%M:%S"))
		row.append('blue')
		row.append(csvList[x][0])
		newDS = system.dataset.addRow(newDS,row )
event.source.parent.getComponent('Month View').events = newDS
This will import an outlook calendar if exported to CSV. One caveat is you need to format the date columns in the csv to a 24 hour format. I am sure you could do it in the script though.
